I’ve problems with gateway ping time and pinging from MT router it self pings jumps to 1000-3000 ms sometime it drops … but no problems with pinging from INTERNAL network to global WWW and LOCAL pinging just any ping the router (CPU LOAD <= 50% CHR 6.42.10). There are several VLANS with same config but problems is just at 2 of them …
Any sugestion what can goes wrong … config doesnt change (any huge changes) for long time but problems apears at last 3 days …
There is no way to update it many billing code made to control that router and I’ve no time now to fix all isues after update (it should be many changes at any new update)…
which part of config you want to share to you ?
You can close topic i found answer gateway was limited by shaper rule queque simple …
I have shape all limited to 128K (192.168.88.0/24)
and + personal limitation 10M (192.168.88.100)
user with IP 192.168.88.100 has problems with pinging 192.168.88.1 when some one reach limit of 192.168.88.0/24 but any other ips he can ping without problems …
