I have problem with Mikrotik 1000
Is there a way to save the graphic even after reboot.
check that the ‘store on disk’ option is enabled in the graphing setup.
there where issue that graphs did not save interface and queue related graphing data. that will be resolved in 5.22
I have the same problem. Is new version of RouterOS released?
i’m running rc6.14 and if i reboot i miss the graphic history
‘store on disk’ is enabled for everything, and store interval is set to 5 min.
Same problem on RB450G. 5-minute interval, store on disk for every graph. After reboot, resource graphs are retained, interface graphs are missing. Using RouterOS 6rc14.
This problem is also in 6.0, 5.24. Graphic are lost and stats for queues also are reset…
