Hi!
Does anyone knows if there is a compatibility problem betwen the hap ax2 Router and the CRS112-8P Switch ?
In my network, if i connect an hap ax2 router WAN port 1 to a CRS112-8P switch, it dosent work. Seams to be blocked by something. It dosent get IP and even if i set the router IP to manual, it dosent work.
But If i connect it to a to a CRS354-48P swicth on the same network and whithout changing anything, it works fine.
Also, everything else connected to the CRS112-8P works fine, even routers from other brands
I tried several units and the problem the problem is the same.
Any clues about what could be the problem ?
