Problem with Hotspot and One-to-One NAT
hi, i just installed a hotspot with mikrotik 2.9 and i dunno how to disable the unversal cliente or one-to-one nat, i created a dhcp pool for the dhcp server , and its working fine , and just as the user manual i put in the hotspot setup the address pool = none as the manual for dont lease another ip for the client cos with the adress pool enable a user that got the ip for an exemple 192.168.0.3 with the dhcp server when he logs trough the hotspot auth page it gets another ip like 192.168.0.10…
address-pool (name | none; default: none) - IP address pool name for performing one-to-one NAT. You can choose not to use the one-to-one NAT
none - do not perform one-to-one NAT for the clients of this HotSpot interface
and when i use the pool for hotspot = none
when user type his username and password the auth page says " cannot assign ip address " i really dont want to assing another ip adrees for the hotspot , just use the dhcp server ip !
anyone here know how to solve that problem?
