Hello All,
I am using an R411 (1 Ether & 1 WLAN) and have configured with the hotspot setup wizard after setting the WAN connection. The ethernet is configured for the WAN with a static IP (72.94.xxx.xxx) instead of a DHCP connection.
I am able to ping external IP from the RouterOS or a wireless connected pc but can not browse or redirect to the login screen. When I reconfigure the WAN with a DHCP connection I am able to get to the login page, ping and browse with no problems. As soon as I use a static IP WAN I can no longer browse.
I think it is a firewall issue but I am not saavy enough to figure it out. Any suggestions would be appreciated.
Thank You
