Hello my friends, Im using mikrotik V3.30, I use hotspot and is working fine, but when I setup webproxy it makes cache and works good and then the problem begins, my users cant autenthicate with login and password when I activate the NAT rule that redirects to port 8080 (used by default by webproxy). I hope you people help me out with this! Good luck everybody!
i think you dont have to redirect your hotspot in webproxy via nat, just loook in the hotspot/profile at the bottom u can see a box name >>> transprent proxy and check it.
