Problem with Hotspot
Hi, the following topic is about a problem that is being more frecuently on my hotspot.
Sometimes, some users can do the login at the hotspot, but then, they can not use internet.
When i do an “ARP Ping” and i leave it running, they can use internet and navigate perfectly with that specific user.
Do you have any ideas ??
Regards,
Lucas :smiley: :smiley:
Remove the universal NAT feature by setting the address pool on the Hotspot server to ‘none’. Then try again.
Thanks fewi for the answer… i did what you said, but the problem continous..
Something else that i could try ?
Thx again !
