The example on the wiki although usefull for people who can’t get ECMP working properly will do nothing for people who use a transparent proxy. Do you have a good load balancing example that uses Mikrotik’s internal proxy server?
–THREAD SOLVED AND SOLUTION TESTED –
ok i tested it (SEE WIKI LINK ABOVE) and it works GREAT!! exactly as advertised / needed…again i think the missing key in everyones attempts before this (and there were ALOT of ppl trying to get this right) was the new-connection filter on the mangle rule
i didnt have any instant messengers around but i tested it with ftp, a few banking and investing secure sites…large http downloads…all ok..i’m getting 2 x 12 mbit cable modems and balencing all my users p2p traffic over that, and keepine very thing else on my fast dsl line
anyway…this should be made a stiki post. Oh and i only had 2 connections but i dont see why you cant expand this for “infinite” connections…amazing! when 8 months ago i paid 1500$ for a 3port load balencer that did not even work right.
Before you get too happy please remember that traffic originating from the local proxy server goes via the output chain so still this example does nothing for people who use a Mikrotik as a transparent proxy.
Hi. I haven’t been around here much lately. For me, I’d GLADLY hire a consultant or attend training, BUT can someone from MikroTik confirm that the current versions of MT work with both Transparent Caching Proxy and with Multiple Gateways at the same time?
It worked perfectly for us in version 2.7, but our cache drive occasional was having errors and having to have it’s index rebuilt. The MT suggested solutions was to upgrade to 2.8, which did fix that issue, but Load Balancing with Transparent Proxy has never worked since.
Can anyone confirm that the current instructions do in fact allow proper load balancing with transparent proxy?
Why would that be? Again, being new here, is that a general Mikrotik doesn’t answer questions thing, or just a ‘‘when asking about transparent proxy / load balancing’’ thing?
OK, thanx. This problem would fall into the old/difficult category then. That’s OK then - I just wanted to know if any solution had come up. It used to work perfectly for us in 2.7, but has never since then.
Well I would still suggest you try it. I have heard some isolated reports where is works. It could really depend on your network configuration. For example, I have heard this works:
Internet ↔ Public IP Router 1 ↔ MT with transparent proxy, NAT and ECMP ↔ Clients
Internet ↔ Public IP Router 2 ↔
but this definitely does not work for me, i.e. broken downloads:
Internet ↔ NAT Router 1 ↔ MT with transparent proxy and ECMP ↔ Cilents
Internet ↔ NAT Router 2 ↔
