I have an IAS server set up and running on a windows 2003 domain member server. The mikrotik that is in the same subnet as this server has no problem authenticating over it. The problem starts when i try to use the same radius server with a mikrotik that is in the different subnet. All devices can access and ping all of them.
Error:
: waiting for call
----terminating…- user XX authentication failed - radius timeout
Run Wireshark on the RADIUS server and check that the IP addresses it sees requests as coming from match what you’re expecting. NAT can change IP addresses.
Also verify all network and host firewalls to ensure you’re not dropping traffic somewhere. Just because ICMP goes through doesn’t mean UDP/1812 and 1813 are.
Just to add to fewi’s reply, you will need to enter another client with that ip: http://support.microsoft.com/kb/317588
Look for this in that doc:
Configure IAS Client Computers
In the router, the radius ports are 1812 and 1813.
/radius print detail
To change the ports
/radius
set X authentication-port=1812 accounting-port=1813
Use the new ports, of course.
ADD: If that is a typo, which it probably is, then you should check “/ip firewall nat” for any masquerade rules that might affect either interface. That would be one without “out-interface=ether1” or some other interface.
I am down to the small stuff now. You did change the radius server ip in “/radius” to the new localnet ip of the ISA server?
Nothing to block connections in “/ip firewall filter”?
I have changed the client IP on the windows 2003 ISA server to the ip from the new subnet and retyped the secret. I have also disabled all firewall filter rules and restarted both server and client. No luck.
I have an issue something like this. The IAS timeouts.
The problem is that logging on IAS can’t handle the NAS Port values sent by Mikrotik, since they are too large (though they are as defined in the corresponding RFC). If logging is disabled, there is no more timeout, authentication is succesful. Unfortunately, disabled logging is not an option in production.
Maybe you should try this and post the results please.
