Problem with internet access on router
I’m having problems with outbound internet connectivity from my RouterOS 7.18.2 device. NTP isn’t working (stuck on “waiting”) and the update server can’t be reached. On the other hand, ICMP/ping and DNS are working perfectly. Client devices behind the RouterOS device don’t have any problems with internet connectivity.
I’ve tried resetting the configuration, but it didn’t help.
Can anyone help?
[admin@MikroTik] >
[admin@MikroTik] > /tool
[admin@MikroTik] /tool> ping time.cloudflare.com
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 162.159.200.1                              56  60 2ms353us
    1 162.159.200.1                              56  60 2ms309us
    2 162.159.200.1                              56  60 2ms396us
    3 162.159.200.1                              56  60 2ms409us
    sent=4 received=4 packet-loss=0% min-rtt=2ms309us avg-rtt=2ms366us max-rtt=2ms409us
[admin@MikroTik] /tool> fetch https://www.google.com/
  status: failed
failure: Address not available
[admin@MikroTik] /tool> /system
[admin@MikroTik] /system> package/
[admin@MikroTik] /system/package> update check-for-updates
            channel: stable
  installed-version: 7.18.2
             status: ERROR: could not connect - Address not available
[admin@MikroTik] /system/package> /system/ntp/client
[admin@MikroTik] /system/ntp/client> print
     enabled: yes
        mode: unicast
     servers: time.cloudflare.com
              time1.google.com
         vrf: main
  freq-drift: 0 PPM
      status: waiting
The configuration is as follows:
[admin@MikroTik] > /ip
[admin@MikroTik] /ip> address print
Flags: D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
#   ADDRESS            NETWORK       INTERFACE
;;; defconf
0   192.168.88.1/24    192.168.88.0  bridge
1 D 31.146.156.184/24  31.146.156.0  ether1
[admin@MikroTik] /ip> arp print
Flags: D - DYNAMIC; C - COMPLETE
Columns: ADDRESS, MAC-ADDRESS, INTERFACE, STATUS
#    ADDRESS         MAC-ADDRESS        INTERFACE  STATUS
0 DC 192.168.88.253  7E:83:F1:82:77:83  bridge     stale
1 DC 31.146.156.1    00:00:00:00:02:37  ether1     reachable
2 DC 192.168.88.254  F8:4D:89:7D:ED:5F  bridge     reachable
[admin@MikroTik] /ip> dns print
                      servers: 1.1.1.1
                               1.0.0.1
              dynamic-servers:
               use-doh-server:
              verify-doh-cert: no
   doh-max-server-connections: 5
   doh-max-concurrent-queries: 50
                  doh-timeout: 5s
        allow-remote-requests: yes
          max-udp-packet-size: 4096
         query-server-timeout: 2s
          query-total-timeout: 10s
       max-concurrent-queries: 100
  max-concurrent-tcp-sessions: 20
                   cache-size: 2048KiB
                cache-max-ttl: 1w
      address-list-extra-time: 0s
                          vrf: main
           mdns-repeat-ifaces:
                   cache-used: 56KiB
[admin@MikroTik] /ip> dhcp-client print
Columns: INTERFACE, USE-PEER-DNS, ADD-DEFAULT-ROUTE, STATUS, ADDRESS
# INTERFACE  USE-PEER-DNS  ADD-DEFAULT-ROUTE  STATUS  ADDRESS
;;; defconf
0 ether1     no            yes                bound   31.146.156.184/24
[admin@MikroTik] /ip> route print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, d - DHCP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
    DST-ADDRESS      GATEWAY       DISTANCE
DAd 0.0.0.0/0        31.146.156.1         1
DAc 31.146.156.0/24  ether1               0
DAc 192.168.88.0/24  bridge               0
[admin@MikroTik] /ip> firewall filter print
Flags: X - disabled, I - invalid; D - dynamic
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked
 2    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
 3    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp
 4    ;;; defconf: accept to local loopback (for CAPsMAN)
      chain=input action=accept dst-address=127.0.0.1
 5    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN
 6    ;;; defconf: accept in ipsec policy
      chain=forward action=accept ipsec-policy=in,ipsec
 7    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
 8    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection hw-offload=yes connection-state=established,related
 9    ;;; defconf: accept established,related, untracked
      chain=forward action=accept connection-state=established,related,untracked
10    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
11    ;;; defconf: drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
You often need to src-nat the port from your ntp-client (So it looks like it’s coming from a high port rather than port 123)
As ISP’s, ntp servers will often block ntp from port 123, (which Mikrotik’s ntp client uses).
Something like:
add action=src-nat chain=srcnat out-interface={YOURWAN} protocol=udp src-port=123 to-ports=12300-12400
(Maybe put it near the top of any srcnat/masquerade rules)
Thanks for the tip. I tried adding that src-nat rule, but the problem still persists.
Other protocols are affected also, including the fetch tool and package updates:
[admin@MikroTik] > /ip/firewall/nat print
 0    chain=srcnat action=src-nat to-ports=12300-12400 protocol=udp out-interface-list=WAN src-port=123 log=no log-prefix=""
 1    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > /system/ntp/client print
     enabled: yes
        mode: unicast
              time1.google.com
         vrf: main
  freq-drift: 0 PPM
      status: waiting
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > /tool fetch https://mikrotik.com/download
  status: failed
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > /system/package/update check-for-updates
            channel: stable
[admin@MikroTik] >
rplant ur killen me, whats your address will send you the game whackamole.
Please ask for config LOL
/export file=anynameyouwish ( minus router serial number, any public WANIP information, vpn keys etc.)(
THanks for your efforts, guys. I exported the config.
It’s all factory defaults except for the wifi, DNS client and NTP client.
# 2025-03-11 18:01:04 by RouterOS 7.18.2
# software id = IPFH-BJIP
# model = C52iG-5HaxD2HaxD
add admin-mac=F4:1E:57:D0:0F:13 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] poe-out=off
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.country=Georgia .mode=ap \
    .ssid="Lasciate ogni speranza..." disabled=no \
    security.authentication-types=wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz configuration.country=Georgia .mode=ap .ssid=\
    "Lasciate ogni speranza..." disabled=no security.authentication-types=\
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/ipv6 settings
set disable-ipv6=yes
    192.168.88.0
/ip dhcp-client
add comment=defconf default-route-tables=main interface=ether1 use-peer-dns=\
    no use-peer-ntp=no
    192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.cloudflare.com
add address=time1.google.com
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
anynameyouwish.rsc (6.98 KB)
This seems very strange indeed. Can you ping 1.1.1.1 or 8.8.8.8 from the router itself? Seems like this is a DNS issue…
Problem solved, thanks everyone for your help.
It turned out to be something completely unrelated to the router: the ISP authenticates LAN clients via a VPN running on the modem. The other LAN devices had connectivity because they were already configured. Nobody told me about that. :smiley:
Rplant’s advice was very useful; connections from UDP port 123 were indeed blocked.
