Problem with Internet Connectivity
Dear Sir/Madam,
I have configured my new Routerboard 750 (v5.14) for a fibre connection.
My ISP gave me the Network range of IPs, the Subnet (/29) and the Gateway and DNS.
I have carried out a number of troubleshooting tests:
  • From the router I get a reply when I ping an Internet site (eg http://www.google.com)
  • From a workstation on the subnet 192.168.88.0/24 when I ping an Internet site, DNS works fine though I receive no reply
  • From a workstation on the subnet 192.168.88.0/24 when I tracert I get the internal router IP (192.168.88.1) and stop there, i.e. I am not managing to reach the external IP. On the other hand from a workstation I can ping my external IP and my gateway.
I believe the issue is related to NAT or Routing. Below find details for the firewall/router config (please note that I have masked the Public IPs)
Thanks and Regards,
Keith
[admin@MikroTik] /ip route> print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 [GATEWAY] 1
1 ADC 192.168.88.0/24 192.168.88.1 ether2-master-l… 0
2 ADC [NETWORK] [PUBLIC IP] ether1-gateway 0
[admin@MikroTik] /ip firewall filter> print
0 ;;; default configuration
chain=input action=accept protocol=icmp
1 ;;; default configuration
chain=input action=accept connection-state=established
2 ;;; default configuration
chain=input action=accept connection-state=related
3 ;;; default configuration
chain=input action=drop in-interface=ether1-gateway
[admin@MikroTik] /ip firewall nat> print
chain=srcnat action=masquerade protocol=0 src-address=192.168.88.0/24
dst-address=[Gateway Address]out-interface=ether1-gateway
[admin@MikroTik] /interface> print
NAME TYPE MTU L2MTU MAX-L2MTU
0 R ether1-gateway ether 1500 1520 1520
1 R ether2-master-local ether 1500 1520 1520
2 X ether3-slave-local ether 1500 1520 1520
3 X ether4-slave-local ether 1500 1520 1520
4 X ether5-slave-local ether 1500 1520 1520
I would try this masquerade instead of yours.
add chain=srcnat action=masquerade out-interface=ether1-gateway
Done thanks, I changed masquerade and working fine now. :smiley:
Will remove post!
