Problem with Intra-VLAN Routing (CCR1036, VRRP)
Dear all,
We just got two CCR-1036-Routers that I have each configured as follows using WinBox:
  • Ports 5-8 and 9-12 are Bonded together and Bridged (with 802.11ad LACP and RSTP - The routers have been inserted into the loop that is connecting our central switches).
  • A number of VLANs have been created on top of the Bridge-Interface, (example-IP-Range: 172.20.1.0/24 for VLAN1). WAN-GW is 172.20.1.1 (Cisco ASA, available via VLAN1)
  • Each Router has an IP in each VLAN, ending with .251 for CCR-1 and .252 for CCR-2
  • VRRP-Interfaces have been created on top of the VLANs on each router. The routers are supposed to Load-Share, so Odd-numbered VLANs have priority 200 and even VLANs are 100 on CCR-1 (opposite setup for CCR-2). Each VRRB has an individual ID (identical per VLAN)
  • VRRP-Interfaces have been assigned IPs in each VLAN, ending with .254
Of course, everything else (DNS; DHCP-Forwards, Routes, etc.) is configured as well. BFD,BGP, Filters, OSPF and RIP are still Factory Default. Firewall-Rules (Allow all) have been made for testing.
The situation is now that the router can reach hosts in all different VLANs and that hosts in all subnets can ping the routers. However, the routers are not forwarding data.
What have I missed?
Please advise.
Thanks a lot in advance!
  • Colin
