Problem with IoT device on hAP ax2
I upgraded my home network to 2 hAP ax2 routers, one acting as a router, one acting as a AP.
I have multiple SSID’s on multiple VLAN’s and everythig is working fine until 2 days ago when i noticed that my thermostat for central heating is reporting that heating gateway is unreachable and when i tried to connect heating gateway back to network it was spitting out various errors such as DNS error or just an unknown error.
I also have my air conditioner, smart plugs, washing machine connected to the same WLAN and these devices have no problems at all… I tried to connect with my laptop to the WLAN and i have internet access, there is no DNS problem…
I tried to connect heating gateway to the LTE router from mikrotik and there device is working… I also tried to make new WLAN on main router, and i choose 2 GHz N and then G thinking that maybe device don’t like ax but no luck… I can even see that router assign IP address to the device but device refuse to complete wizard and throw an error.
Here is AP config, maybe there is something wrong… Only diference is that ax2 is wifi wave2 and it’s using default VLAN 1
# jan/10/1970 03:09:39 by RouterOS 7.7
# software id = xxxx-xxxx
# model = C52iG-5HaxD2HaxD
# serial number =xxxxxxxxxxxx
add name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] comment="Trunk port (Uplink)"
set [ find default-name=ether2 ] comment="IPTV (VLAN40)"
set [ find default-name=ether3 ] comment="SECURITY_1 (VLAN20)"
set [ find default-name=ether4 ] comment="SECURITY_2 (VLAN20)"
set [ find default-name=ether5 ] comment="HOME (VLAN88)"
/interface vlan
add interface=bridge name=VLAN10_TEA_PC vlan-id=10
add interface=bridge name=VLAN20_SECURITY vlan-id=20
add interface=bridge name=VLAN30_IOT vlan-id=30
add interface=bridge name=VLAN40_IPTV vlan-id=40
add interface=bridge name=VLAN88_HOME vlan-id=88
add include=all name=LAN
add name=Home
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk name=Home
add authentication-types=wpa-psk,wpa2-psk name=Security
add authentication-types=wpa-psk,wpa2-psk encryption="" name=IoT
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency="" .width=\
    20/40/80mhz comment=VLAN88_HOME configuration.country=Croatia .mode=ap \
    .ssid="Gazdin novi WiFi" disabled=no mtu=1500 security=Home
set [ find default-name=wifi2 ] channel.band=2ghz-ax .frequency=2412 .width=\
    20/40mhz comment=VLAN88_HOME configuration.country=Croatia .mode=ap \
    .ssid="Gazdin novi WiFi" disabled=no security=Home
add comment=VLAN30_IoT configuration.country=Croatia .mode=ap .ssid=IoT \
    disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=\
    wifi3 security=IoT
add comment=VLAN20_Security configuration.country=Croatia .mode=ap .ssid=\
    WiFi_CCTV disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=\
    wifi2 name=wifi4 security=Security
/port
set 0 name=serial0
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether1
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
    interface=ether2 pvid=40
    interface=ether3 pvid=20
    interface=ether4 pvid=20
    interface=*6 pvid=88
    interface=*7 pvid=88
    interface=ether5 pvid=88
    interface=wifi1 pvid=88
    interface=wifi2 pvid=88
    interface=wifi3 pvid=30
    interface=wifi4 pvid=20
set discover-interface-list=Home
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge tagged=ether1,bridge vlan-ids=10
add bridge=bridge tagged=ether1,bridge untagged=ether3,ether4,wifi4 vlan-ids=\
    20
add bridge=bridge tagged=ether1,bridge untagged=wifi3 vlan-ids=30
add bridge=bridge tagged=ether1,bridge untagged=ether2 vlan-ids=40
add bridge=bridge tagged=bridge,ether1 untagged=ether5,wifi1,wifi2 vlan-ids=\
    88
add interface=bridge list=LAN
add interface=VLAN10_TEA_PC list=LAN
add interface=VLAN20_SECURITY list=LAN
add interface=VLAN30_IOT list=LAN
add interface=VLAN40_IPTV list=LAN
add interface=VLAN88_HOME list=LAN
add interface=VLAN88_HOME list=Home
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system identity
set name=hAP_ax2_DB
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=Home
Update: I tried to use cAP ac, but no luck, still device won’t connect… Other devices are working just fine but this thermostat is reporting DNS error. I tried to enter DNS servers from working router but nothing…
So i tired to dig a little deeper, first i connected thermostat to the working router, checked dns cache to see what came up when i tried to connect thermostat and i saw 2 entries:
First entry:
Type: CNAME
Data: nv2.trafficmanager.net.
TTL: 00:50:26
Second entry:
Type: A
Data: 51.105.243.149
TTL: 00:09:28
Then on non-working router i have this:
First entry:
Type: CNAME
TTL: 00:27:30
Second entry:
Type: A
TTL: 00:06:48
As you can see, everything is the same but it won’t work for some reason…
Two things in regards to Wifi:
  • don’t use WPA-PSK
  • don’t use extension channels on the 2.4GHz radio
Not sure if it is related to your problem or if it is a problem by itself
I left WPA in case if i ever need to connect something older (WPA is only on IoT and security)
I set channel width to 20 MHz for 2.4 GHz radio and 20/40 for 5 GHz radio. Frequencies are set so channels don’t overlap.
Now i tried to connect older laptop, mobile phone and few devices that are configured by mobile app, just to see if problem will show up on any of them and they work just fine…
You will find there are 2.4 radio chips that “just don’t like Mikrotik.” If you run into one…
You can try NO encryption. But if that doesn’t work… its over… move on.
A weird one I ran into was a device that used a mix of uppercase and lowercase letters for its identification,
the capac corrected the values to all lower case so the device didnt recognize the return traffic for itself.
The trick was to bypass the capac dns services (or router dns services) and use in dhcp server network settings, 1.1.1.1 or whatever DNS provider you trust.
Not sure but thought that was eventually fixed on mt wifi???
The reason it works as DNS providers just copy what they get for domain names etc and spit it back ( and dont try and change a name to conform to the standard )
I ended up removing ax2 because I had problem with wired link… no 1Gbps on some links… ac3 working just fine… Now after netinstaling both routers i don’t have default configuration nor wifi interfaces :frowning: :frowning: :frowning: :frowning:
It, most likely, is related to wave2 implementation. So config is a bit different. Try to tag wifi interfaces on Wireless tab, not bridge port. I have ax3, setup in capsman v2, and its working fine. Only thing I had to adjust was removing WPA3 from IoT interface as some devices had issues.
