I have a script is to build an OpenVPN compatible address pool. It does so by going through the possible combinations and build up a “Ranges” variable containing a comma separated liost of all valid /30 ranges.
The /ip pool add fails with: value of range must have ip address after ‘-’
The ewrror does also happen if I do the for loop only for 2 entries (0 to 1), but works for one single entry (no comma). The strange thins is that I :put the Ranges variable to the console and enter the “/ip pool add” manually copy/pastiong the range string (assembling it to a single line first) the add works, Also if I copy/paste the ranges to teh script by preceding the :put Ranges by a :set Ranges “10.9.9.1-10.9.9.2,10.9.9.5-10.9.9.6,10.9.9.9-10.9.9.10,…” the script will work. The put typeof copnfirms that Ranges is of str type each time.
Script:
:local PoolName "ovpn-pool";
:local OpenVPNNetwork "10.9.9";
:local Ranges "";
:for i from=0 to=63 do={
:if ( $i = 0 ) do={
:set Ranges { "$OpenVPNNetwork." . ( 1 + $i * 4 ) . "-" . $OpenVPNNetwork . "." . ( 1 + $i * 4 + 1 ) };
} else={
:set Ranges { "$Ranges," . $OpenVPNNetwork . "." . ( 1 + $i * 4 ) . "-" . $OpenVPNNetwork . "." . ( 1 + $i * 4 + 1 ) };
:put $Ranges;
:put [ :typeof Ranges ]
/ip pool add name=$PoolName ranges=$Ranges
