Hi, all.
MikroTik RB450G router I have running since the year 2010 with simple configuration:
interfaces:
ether1: name=localnet (link to home network switch)
ether2: name=internet_wan1_link (link to GPON ONT (Interner Port))
ether3: name=internet_wan2 (link to reserved provider)
ether4: name=iptv_rt (link to GPON ONT (IPTV Port))
ether5: disabled=yes master-port=localnet name=reserved (no link)
I have installed this packages:
/system package print
# NAME VERSION
0 system 6.33
1 security 6.33
2 multicast 6.33
3 advanced-tools 6.33
4 dhcp 6.33
5 ntp 6.33
6 ppp 6.33
7 ups 6.33
Everything worked fine until today, now I bought a new router RB850Gx2 (second revision with SN 5*). I have Installed the same packages, copied configuration from my old router (/export ==> /import), switch all cables - everything works the same way as before.
Turn on the STB IPTV and notice that started intermittently image artifacts. If I turning on HD-channel - artifacts becomes significantly more. CPU utilization of the router have on the level of 3-5%. Turn off RB850Gx2, connect RB450G-everything works fine, no artifacts, CPU load in the area of 30%. Turn off RB450G, connect RB850Gx2 - artifacts comes again. Configuration is identical in both routers.
What could it be and how to fix it?
The complete configuration:
# nov/16/2015 16:44:32 by RouterOS 6.33
# software id = DVR8-SSFW
set [ find default-name=ether1 ] name=localnet
set [ find default-name=ether2 ] name=internet_wan1_link
set [ find default-name=ether3 ] name=internet_wan2
set [ find default-name=ether4 ] name=iptv_rt
set [ find default-name=ether5 ] disabled=yes master-port=localnet name=\
reserved
/interface pppoe-client
add disabled=no interface=internet_wan1_link name=internet_wan1
/interface pptp-client
add connect-to=vpn.work disabled=no name=vpn_work
/ip firewall layer7-protocol
add name=dns-forward-vpn-work regexp=".work.ru|[0-9]+.[0-9]+.[0-9]+.10.in-addr.arpa"
add name=dns-forward-iptv-rt regexp=".iptv.provider.ru|[0-9]+.[0-9]+.20.172.in-addr.arpa"
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=localnet-dhcp-pool ranges=192.168.200.200-192.168.200.254
add address-pool=localnet-dhcp-pool disabled=no interface=localnet \
lease-time=1d name=localnet-dhcp
add address=192.168.200.1/24 interface=localnet network=192.168.200.0
add address=4.4.4.4/24 interface=internet_wan2 network=4.4.4.0
/ip dhcp-client
add add-default-route=no disabled=no interface=iptv_rt use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.200.2 comment=nas.local.domain.ru mac-address=\
00:11:22:33:44:55
add address=192.168.200.3 comment=nas2.local.domain.ru mac-address=\
00:11:22:33:44:66
add address=192.168.200.0/24 dns-server=192.168.200.1 domain=local.domain.ru \
gateway=192.168.200.1 ntp-server=192.168.200.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.200.1 name=gate.local.domain.ru
add address=192.168.200.2 name=nas.local.domain.ru
add address=192.168.200.3 name=nas2.local.domain.ru
/ip firewall address-list
add address=192.168.200.0/24 list=Allowed-Internet
add address=192.168.200.221 list=WAN1_preferred
add address=192.168.200.222 list=WAN2_preferred
add address=91.102.16.156 list=Blocked-IPs
add address=91.240.163.39 list=Blocked-IPs
add address=193.65.64.241 list=Blocked-IPs
add address=60.169.78.38 list=Blocked-IPs
add address=192.168.200.0/24 list=Allowed-VPN
add address=192.168.200.0/24 list=Allowed-IPTV
add action=drop chain=input src-address-list=Blocked-IPs
add chain=input connection-state=established
add chain=input connection-state=related
add action=drop chain=input dst-port=53 in-interface=internet_wan1 protocol=\
udp
add action=drop chain=input dst-port=53 in-interface=internet_wan2 protocol=\
udp
add action=drop chain=input dst-port=22 in-interface=internet_wan1 protocol=\
tcp src-address-list=!Allowed-SSH
add action=drop chain=input dst-port=22 in-interface=internet_wan2 protocol=\
add action=drop chain=input dst-port=8291 in-interface=internet_wan1 \
protocol=tcp src-address-list=!Allowed-WinBox
add action=drop chain=input dst-port=8291 in-interface=internet_wan2 \
add chain=input protocol=icmp
add action=drop chain=input dst-address=239.255.255.250 protocol=igmp
add chain=input protocol=igmp
add chain=input dst-port=5000 protocol=udp
add chain=input
add action=drop chain=forward src-address-list=Blocked-IPs
add chain=forward connection-state=established
add chain=forward connection-state=related
add chain=forward
add chain=output
/ip firewall mangle
add action=mark-routing chain=output comment=\
"Mark routing for router's replies" connection-mark=WAN1_connection \
new-routing-mark=WAN1_traffic
add action=mark-routing chain=output connection-mark=WAN2_connection \
new-routing-mark=WAN2_traffic
add action=mark-connection chain=prerouting comment=\
"Mark all connections that are initiated from outside" connection-mark=\
no-mark in-interface=internet_wan1 new-connection-mark=WAN1_connection
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface=internet_wan2 new-connection-mark=WAN2_connection
add action=mark-routing chain=prerouting comment=\
"Mark special address lists routing" connection-mark=no-mark dst-port=\
22,25,143,465,993 in-interface=localnet new-routing-mark=WAN2_traffic \
protocol=tcp
add action=mark-routing chain=prerouting connection-mark=no-mark \
in-interface=localnet new-routing-mark=WAN1_traffic src-address-list=\
WAN1_preferred
in-interface=localnet new-routing-mark=WAN2_traffic src-address-list=\
WAN2_preferred
"Mark routing for upload packets from marked connections" \
connection-mark=WAN1_connection new-routing-mark=WAN1_traffic \
src-address-list=Allowed-Internet
add action=mark-routing chain=prerouting connection-mark=WAN2_connection \
new-routing-mark=WAN2_traffic src-address-list=Allowed-Internet
add action=mark-packet chain=prerouting comment="DNS (Forward Domains)" \
dst-port=53 layer7-protocol=dns-forward-vpn-work new-packet-mark=\
DNS-VPN-WORK_traffic protocol=udp
add action=mark-packet chain=prerouting dst-port=53 layer7-protocol=\
dns-forward-iptv-rt new-packet-mark=DNS-IPTV-RT_traffic protocol=udp
add action=masquerade chain=srcnat comment="Internet NAT" out-interface=\
internet_wan1 src-address-list=Allowed-Internet
add action=masquerade chain=srcnat out-interface=internet_wan2 \
add action=masquerade chain=srcnat comment="VPN NAT" out-interface=vpn_work \
src-address-list=Allowed-VPN
add action=masquerade chain=srcnat comment="IPTV NAT" out-interface=iptv_rt \
src-address-list=Allowed-IPTV
add action=dst-nat chain=dstnat comment="DNS (Forward Domains)" dst-port=53 \
packet-mark=DNS-VPN-WORK_traffic protocol=udp to-addresses=10.0.0.1 \
to-ports=53
add action=dst-nat chain=dstnat dst-port=53 packet-mark=DNS-IPTV-RT_traffic \
protocol=udp to-addresses=10.100.0.1 to-ports=53
add check-gateway=ping distance=2 gateway=internet_wan1 routing-mark=\
WAN1_traffic
add check-gateway=ping distance=2 gateway=4.4.4.1 routing-mark=\
WAN2_traffic
add check-gateway=ping distance=3 gateway=internet_wan1
add check-gateway=ping distance=4 gateway=4.4.4.1
add distance=2 dst-address=10.0.0.0/8 gateway=vpn_work
add distance=1 dst-address=10.100.0.0/16 gateway=10.100.0.1
add distance=1 dst-address=5.5.0.0/16 gateway=iptv_rt
/ip service
set telnet disabled=yes
set ftp address=192.168.200.0/24
set www address=192.168.200.0/24
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=localnet type=internal
add interface=internet_wan1 type=external
add disabled=yes interface=internet_wan2 type=external
/routing igmp-proxy
set query-interval=1m
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=iptv_rt upstream=yes
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Moscow
/system clock manual
set time-zone=+03:00
/system ntp client
set enabled=yes primary-ntp=85.21.78.23 secondary-ntp=216.171.120.36
/system ntp server
set enabled=yes
/system ups
add alarm-setting=none name=ups port=serial0
/tool romon port
set [ find default=yes ] cost=100 forbid=no interface=all secrets=""
add cost=100 disabled=yes forbid=no interface=all secrets=""
