Hi i’m trying to configure a VPN L2PT for connect my outside device to my Mikrotik
I receive this message when i’m trying to connect
“failed to pre-process ph2 packet”
“peer sent packet for dead phase 2”
This is /export
set allow-remote-requests=yes
/ip dns static
add address=192.168.98.4 name=router
add action=accept chain=input dst-port=500,1701,4500 protocol=udp
add action=accept chain=input dst-port=500,4500,1701 ingress-priority=0 priority=0 protocol=tcp
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input protocol=ipsec-ah
add action=accept chain=forward connection-state=established,related dst-address=192.168.54.0/24 src-address=192.168.98.0/24
add action=accept chain=forward connection-state=established,related dst-address=192.168.98.0/24 src-address=192.168.54.0/24
add action=accept chain=forward dst-address=192.168.5.0/24 src-address=192.168.98.0/24
add action=accept chain=forward dst-address=192.168.98.0/24 src-address=192.168.5.0/24
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related” connection-state=established,related
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!mactel
add action=accept chain=srcnat dst-address=192.168.54.0/24 src-address=192.168.98.0/24
add action=accept chain=srcnat comment=NAT_Velletri dst-address=192.168.5.0/24 src-address=192.168.98.0/24
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface=pppoe-out1 out-interface-list=WAN
/ip firewall raw
add action=notrack chain=prerouting dst-address=192.168.54.0/24 dst-address-list=212.210.227.1 src-address=192.168.98.0/24 src-address-list=79.58.99.100
/ip ipsec peer
add address=xx/32 comment=VPN_Tivoli dh-group=modp1024 enc-algorithm=aes-256,aes-192,aes-128,3des nat-traversal=no
add address=xx/32 comment=VPN_Velletri dh-group=modp1024 enc-algorithm=aes-256,aes-192,aes-128,3des nat-traversal=no
add address=0.0.0.0/0 dh-group=modp1024 enc-algorithm=aes-256,aes-192,aes-128,3des exchange-mode=main-l2tp generate-policy=port-override
/ip ipsec policy
set 0 disabled=yes
add comment=VPN_Tivoli dst-address=192.168.54.0/24 sa-dst-address=xx sa-src-address=xx0 src-address=192.168.98.0/24 tunnel=yes
add comment=VPN_Velletri dst-address=192.168.5.0/24 sa-dst-address=xx sa-src-address=xx src-address=192.168.98.0/24 tunnel=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=pppoe-out1 type=external
/ppp secret
add name=fabio service=l2tp
/system clock
set time-zone-name=Europe/Rome
/system logging
add topics=ipsec
/system package update
set channel=release-candidate
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
