Problem with L2TP Firewall
I have a problem with L2TP firewall settings. Setup is okay and work well only when I disable “drop all not coming from LAN” rule.
Here is my config:
> /interface wireless security-profiles
> set [ find default=yes ] supplicant-identity=MikroTik
> /ip ipsec proposal
> set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc,3des \
>     pfs-group=none
> /ip pool
> add name=dhcp_pool1 ranges=192.168.1.10-192.168.1.252
> /ppp profile
> add change-tcp-mss=yes dns-server=192.168.1.100 local-address=192.168.1.1 \
>     name=vpn remote-address=dhcp_pool1 use-ipv6=default
> /interface l2tp-server server
> set authentication=mschap2 default-profile=vpn enabled=yes use-ipsec=yes
> /ip firewall filter
> add action=accept chain=input comment="accept established,related" \
>     connection-state=established,related
> add action=drop chain=input dst-port=22,80,443,2000,8291 in-interface=\
>     pppoe-out1 protocol=tcp
> add action=drop chain=input comment="drop invalid" connection-state=invalid \
>     in-interface=pppoe-out1
> add action=accept chain=input comment="accept ipsec" protocol=ipsec-esp
> add action=accept chain=input comment="accept ike, l2tp, ipsec" dst-port=\
>     500,1701,4500 protocol=udp
> add action=drop chain=input comment="drop all not coming from LAN" \
>     in-interface=!LAN in-interface-list=all
> add action=accept chain=forward comment="accept established,related" \
> add action=drop chain=forward comment="drop invalid" connection-state=invalid \
> add action=drop chain=forward comment="drop all from WAN not DSTNATed" \
>     connection-nat-state=!dstnat in-interface=pppoe-out1
> /ip firewall nat
> add action=masquerade chain=srcnat out-interface=pppoe-out1
> /ip firewall service-port
> set h323 disabled=yes
> /ip ipsec profile
> set [ find default=yes ] dh-group=modp2048 dpd-interval=2m \
>     dpd-maximum-failures=5 enc-algorithm=aes-256,aes-128,3des
I assume the problem is that L2TP connection is not treated as a part of LAN. How can I fix it, without removing the rule itself?
Services like L2TP create a dynamic interface per connection. These can be added automatically to an interface list - you set this up in the ppp profile.
If you want these clients to be treated the same as LAN, simply specify that they should be added to LAN.
Thanks. Can you guide me how can I add those clients to LAN?
I suggested you go to ppp->profile, select vpn, then set interface list to LAN.
This will add/remove the interfaces to the list automatically.
Is this somehow not working?
it works now. I set the default bridge and l2tp interface to use the same interface list. Thanks
