Hi everyone ^^
First: Sorry if my english is bad
i will try to write correctly.
I i’m facing a problem with 2 mikrotiks.
I have a router RB951Ui-2HnD (this is configured with the load Balancing)
And i have a 5.8Ghz SXT Lite5 ac (this is connected to a government antenna that provide 100 mb download and upload speed but closed ports)
well i have in Wan 1 my ISP Arlink that provides me with 12 mb dowload and 4 mb upload, with open ports and static ip.
And Wan 2 (or ETH1) i have configured the 5.8 Ghz antenna and is working, but the problem is, if i connect the antenna directly to PC i can navigate, but if i connect this to Router (Load-Balancing) i can’t…
i was connecting a 2.4Ghz TP-Link that was configured and working in Wan2 and the load-balancing in the router works if i connect that antenna again, but if i change to the mikrotik 5.8 Ghz (having the same Pool Dhcp and IP) the load balancing fails…
i don’t know where i’m having the problem, with the 2.4Ghz works but when i plug the 5.8Ghz stop working.
PD: I can connect with winbox to 5.8Ghz antenna when is pluged in the RouterOS
