Problem with load balans RB433AH
This is my current configuration:
WAN1 = Real Lan ip
WAN2 = ADSL
add name=Local
add name=WAN2
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g frequency=auto mode=ap-bridge \
    name=LocalWlan ssid=NotFree2
set [ find default-name=ether3 ] name=LocalLan
set [ find default-name=ether1 ] name=WAN1
set [ find default=yes ] authentication-types=wpa-psk,wpa-eap mode=\
    dynamic-keys supplicant-identity=Sapnet wpa-pre-shared-key=0000000000
add name=dhcp_pool1 ranges=192.168.2.20-192.168.2.254
add address-pool=dhcp_pool1 disabled=no interface=Local name=dhcp1
add bridge=WAN2 interface=ether2
add bridge=Local interface=LocalLan
add bridge=Local interface=LocalWlan
add address=88.87......./24 interface=WAN1 network=88.87.......
add address=192.168.1.2/24 interface=WAN2 network=192.168.1.0
add address=192.168.2.1/24 interface=Local network=192.168.2.0
add address=192.168.2.0/24 gateway=192.168.2.1
set allow-remote-requests=yes servers=88.87.......,88.87.......
    "Bruteforce login prevention(ftp: drop ftp brute forcers)" dst-port=21 \
    protocol=tcp src-address-list=ftp_blacklist
add chain=output comment="Bruteforce login prevention(ftp: 530 Login incorrect\
    \_to limit dst address)" content="530 Login incorrect" dst-limit=\
    1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist \
    address-list-timeout=3h chain=output comment=\
    "Bruteforce login prevention(ftp: 530 Login incorrect to ftp_blacklist)" \
    content="530 Login incorrect" protocol=tcp
    "Bruteforce login prevention(ssh: drop ssh brute forcers)" dst-port=22 \
    protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist \
    address-list-timeout=4w2d chain=input comment=\
    "Bruteforce login prevention(ssh: stage3 to blacklist)" connection-state=\
    new dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
    address-list-timeout=1h chain=input comment=\
    "Bruteforce login prevention(ssh: stage2 to stage3)" connection-state=new \
    dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
    address-list-timeout=6h chain=input comment=\
    "Bruteforce login prevention(ssh: stage1 to stage2)" connection-state=new \
    dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
    address-list-timeout=12h chain=input comment=\
    "Bruteforce login prevention(ssh: stage1)" connection-state=new dst-port=\
    22 protocol=tcp
    "Bruteforce login prevention(ssh: drop ssh brute downstream)" dst-port=22 \
    "Bruteforce login prevention(Telnet: droop telnet brute forcers)" \
    dst-port=23 protocol=tcp src-address-list=telnet_blacklist
add action=add-src-to-address-list address-list=telnet_blacklist \
    "Bruteforce login prevention(Telnet: stage3 to telnet_blacklist)" \
    connection-state=new dst-port=23 protocol=tcp src-address-list=\
    telnet_stage_3
add action=add-src-to-address-list address-list=telnet_stage_3 \
    "Bruteforce login prevention(Telnet: stage2 to stage3)" connection-state=\
    new dst-port=23 protocol=tcp src-address-list=telnet_stage_2
add action=add-src-to-address-list address-list=telnet_stage_2 \
    "Bruteforce login prevention(Telnet: stage1 to stage2)" connection-state=\
    new dst-port=23 protocol=tcp src-address-list=telnet_stage_1
add action=add-src-to-address-list address-list=telnet_stage_1 \
    "Bruteforce login prevention(Telnet: stage1)" connection-state=new \
    "Bruteforce login prevention(Winbox: droop Winbox brute forcers)" \
    dst-port=8291 protocol=tcp src-address-list=winbox_blacklist
add action=add-src-to-address-list address-list=winbox_blacklist \
    address-list-timeout=2w1d chain=input comment=\
    "Bruteforce login prevention(Winbox: stage3 to winbox_blacklist)" \
    connection-state=new dst-port=8291 protocol=tcp src-address-list=\
    winbox_stage_3
add action=add-src-to-address-list address-list=winbox_stage_3 \
    address-list-timeout=1m chain=input comment=\
    "Bruteforce login prevention(Winbox: stage2 to stage3)" connection-state=\
    new dst-port=8291 protocol=tcp src-address-list=winbox_stage_2
add action=add-src-to-address-list address-list=winbox_stage_2 \
    "Bruteforce login prevention(Winbox: stage1 to stage2)" connection-state=\
    new dst-port=8291 protocol=tcp src-address-list=winbox_stage_1
add action=add-src-to-address-list address-list=winbox_stage_1 \
    "Bruteforce login prevention(Winbox: stage1)" connection-state=new \
add action=add-src-to-address-list address-list="port scanners" \
    address-list-timeout=2w chain=input comment="Port scanners to list " \
    protocol=tcp psd=21,3s,3,1
    address-list-timeout=2w chain=input comment="NMAP FIN Stealth scan" \
    protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
    address-list-timeout=2w chain=input comment="SYN/FIN scan" protocol=tcp \
    tcp-flags=fin,syn
    address-list-timeout=2w chain=input comment="SYN/RST scan" protocol=tcp \
    tcp-flags=syn,rst
    address-list-timeout=2w chain=input comment="FIN/PSH/URG scan" protocol=\
    tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
    address-list-timeout=2w chain=input comment="ALL/ALL scan" protocol=tcp \
    tcp-flags=fin,syn,rst,psh,ack,urg
    address-list-timeout=2w chain=input comment="NMAP NULL scan" protocol=tcp \
    tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment="dropping port scanners" \
    src-address-list="port scanners"
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=\
    WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 log-prefix="" \
    new-connection-mark=WAN2_conn passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn \
    new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn \
    new-routing-mark=to_WAN2
add action=accept chain=prerouting dst-address=88.87......./23 in-interface=\
    Local
add action=accept chain=prerouting dst-address=192.168.1.0/24 in-interface=\
    Local
add action=mark-connection chain=prerouting dst-address-type=!local \
    in-interface=Local new-connection-mark=WAN1_conn passthrough=yes \
    per-connection-classifier=both-addresses-and-ports:2/0
    in-interface=Local new-connection-mark=WAN2_conn passthrough=yes \
    per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface=Local new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    in-interface=Local new-routing-mark=to_WAN2
add action=masquerade chain=srcnat log-prefix="" out-interface=WAN1
add action=masquerade chain=srcnat log-prefix="" out-interface=WAN2
add check-gateway=ping comment=Telnet distance=1 gateway=88.87....... \
add check-gateway=ping comment="ADSL" distance=1 gateway=192.168.1.1 \
add check-gateway=ping distance=1 gateway=88.87.......
add check-gateway=ping distance=2 gateway=192.168.1.1
add disabled=yes distance=1 gateway=88.87.......
But is WAN1 is down not going to the WAN2. Can someone help me and tell where is the problem?
If you want the system to fail over should one or the other WAN stop then you need to add a backup route for each WAN (being the other WAN and a higher distance.
You have done this for the main routing table but not for the to_WAN1 or to_WAN2 tables.
#Main Routes
Backup routes
add check-gateway=ping comment=Telnet distance=2 gateway=88.87.......
add check-gateway=ping comment="ADSL" distance=2 gateway=192.168.1.1
Thanks scampbell.
