I have a mikrotik ros v5.22 box,and ISP1 is on eth3 as WAN1 and I setup a PPTP as WAN2
My purpose is routing some specified destination address which are set in address-list "DD" to eth3 WAN1
,other ip route to PPTP. My configure looks like below.
[admin@MikroTik] > /ip firewall mangle print
0 chain=prerouting action=mark-routing new-routing-mark=WAN-ETH3 passthrough=no dst-address-list=DD
1 chain=prerouting action=mark-routing new-routing-mark=WAN-PPTP passthrough=no dst-address-list=!DD
[admin@MikroTik] > /ip route print detail
0 A S dst-address=0.0.0.0/0 gateway=10.10.10.1 gateway-status=10.10.10.1 reachable via ether3 distance=1 scope=30
target-scope=10 routing-mark=WAN-ETH3
1 A S dst-address=0.0.0.0/0 gateway=pptp-out1 gateway-status=pptp-out1 reachable distance=1 scope=30 target-scope=10
2 ADC dst-address=10.10.10.0/24 pref-src=10.10.10.189 gateway=ether3 gateway-status=ether3 reachable distance=0
scope=10
3 ADC dst-address=10.85.x.x/32 pref-src=10.85.x.x gateway=pptp-out1 gateway-status=pptp-out1 reachable distance=0 //PPTP port
scope=10
4 A S dst-address=173.255../32 gateway=10.10.10.1 gateway-status=10.10.10.1 reachable via ether3 distance=1 //for PPTP server
5 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.1 gateway=ether1 gateway-status=ether1 reachable distance=0
scope=10
[admin@MikroTik] > /ip firewall address-list print
LIST ADDRESS
0 DD 119.167.151.251/32
1 DD 114.114.114.114/32
2 DD 31.13.0.0/16With above configure ,I can't route neither address-list "DD" or other IP from LAN,For example, PING 114.114.114.114 get timeout,and ping 8.8.4.4 get timeout too.
BUT.....
When I disable the second mangle rule
1 X chain=prerouting action=mark-routing new-routing-mark=WAN-PPTP passthrough=no dst-address-list=!DDNow I can ping the IP which in address-list "DD",for example,Ping 114.114.114.114 ok, Of course,ping 8.8.4.4 get timeout.
However,,I try to disable the fist mangle rule and enable the second mangle rule
0 X chain=prerouting action=mark-routing new-routing-mark=WAN-ETH3 passthrough=no dst-address-list=DD
1 chain=prerouting action=mark-routing new-routing-mark=WAN-PPTP passthrough=no dst-address-list=!DDI think I should can ping the ip out of address-list "DD",But I ping 114.114.114.114 timeout,ping 8.8.4.4 timeout.
Maybe some bugs with dst-address-list? Because I test with dst-address,,It's OK!
0 chain=prerouting action=mark-routing new-routing-mark=WAN-ETH3 passthrough=no dst-address=114.114.114.114
1 chain=prerouting action=mark-routing new-routing-mark=WAN-PPTP passthrough=no dst-address=8.8.4.4What's the reason,,somebody can give me identify problems!
