problem with mangle please help
hello guys, i have problem with mangle please help , the problem is if i ping from mikrotik to lan ip 192.168.x.x it present high ping 3++ ms from supposedly <=1 ms i think it using my isp connection.
here is the rule
;;; Local x
12 chain=prerouting action=mark-connection new-connection-mark=Local passthrough=yes src-address-list=LAN dst-address-list=LAN
13 chain=forward action=mark-connection new-connection-mark=Local passthrough=yes src-address-list=LAN dst-address-list=LAN
my src address list
172.0.0.0/8
192.168.0.0/16
10.0.0.0/8
100.10.1.0/30
thanks please reply
hi
your information that send , isn’t Enough.please send for me ip route export and ip firewall nat export.
my problem solved , thanks for your reply
