Problem with mikrotik metal 2shpn
Hello, sorry for my bad english.
I have mikrotik metal 2shpn for get more power to my Antenna. I use a hotspost and the signal is very good (-70) but the mikrotik limit the bandiwth to 200 kbps. How can i remove this?
Why do you think that problems is in the Mikrotik. Have you checked your WiFi with different device as client and as AP? Could you post configuration? You need to give us more details.
At the moment i dont have a mikrotik here. But the tx7rx are 98% and the signal are -71 DB.
The wifi with other ap work correctly.
i have big issue with metal 2shpn. It connects to selected phones but not to laptops. it also browse at times and not browse at times.
