Problem with mini pci SR2 (Atheros 5213A)
Problem with mini pci SR2 (Atheros 5213A) - “Problema com o mini pci SR2 ( Atheros 5213A )”
I bought a card sr2 and am having problem of slowness with in maximo of 8 the 10 customer ping I have moment that 2000ms arrives is using mikrotik 2.9.27 and would like to know the reason of this problem. Remembered that ja was made the exchange of antennas, pig tail and etc. I am of Brazil and descuple for the o my English who and horivel.
Portugues
“Eu comprei um cartão sr2 e estou tendo problema de lentidão com no maximo de 8 a 10 cliente os ping tem momento que chega a 2000ms estou usando o mikrotik 2.9.27 e gostaria de saber o motivo deste problema. Lembrado que ja foi feito a troca de antenas, pig tail e etc. Sou do Brasil e descuple pelo o meu inglês que e horivel.”
Configuração do Mikrotik
name=“local”
mtu=1500
mac-address=00:15:6D:10:3D:AE
arp=enabled
disable-running-check=no
interface-type=Atheros AR5213
radio-name=“00156D103DAE”
mode=ap-bridge
ssid=“PRO2”
area=“”
frequency-mode=superchannel
country=brazil
antenna-gain=15
frequency=2422
band=2.4ghz-b
scan-list=default
rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps
basic-rates-a/g=6Mbps
max-station-count=2007
ack-timeout=dynamic
tx-power-mode=default
noise-floor-threshold=default
periodic-calibration=default
burst-time=disabled
dfs-mode=none
antenna-mode=ant-a
wds-mode=disabled
wds-default-bridge=none
wds-ignore-ssid=no
update-stats-interval=disabled
default-authentication=yes
default-forwarding=yes
default-ap-tx-limit=0
default-client-tx-limit=0
hide-ssid=no
security-profile=default
disconnect-timeout=3s
on-fail-retry-time=100ms
preamble-mode=long
compression=no
allow-sharedkey=no
Paulo Roberto Oliveira
Bac. Sistema de Informação
Analsita de Sistemas
Programador Delphi
Fones (62) 3505-4567 / 8401-5999
http://www.atenassys.com.br
msn: proalfa[arobar]msn.com
gmail: proalfa[arobar]gmail.com
