Problem with mount point
When my router board 230 is initializing i get the next message:
mount: mount point /dev/pts does not exist
Generating SSH RSA key…
Generating SSH DSA key…
Starting services…[/color]
It stays there and doesn’t show the login request.
I need help : What is mount point/dev/pts???
How can i rewrite my preloaded Flash memory without loosing the licences i already paid???
Thanks.
User Manager Issue
MT guys any chance you will be fixing the disconnects soon?
Problems with new revision of RB711-5Hn
UDP to TCP stream transfer
MetaROUTER stability issues on certain MIPSBE and PPC boards
RB750UP - Issue
after upgrade to
Disk space
Known issues and bugs - a list
ip route cache BUG
CRS documentation
v6.10 released
Which hardware for Fiber 175/175 with QOS
v6.10 released
v6.10 released
v6.10 released
Script runs fine from CLI, but not webinterface or netwatch
So, RB850Gx2 and metarouter
v6.11 released
v6.11 released
v6.12 released
winbox pptp
v6.12 released
IP Tunnel Interface Disappears
v6.14 released
RB Metal AP stability
ipv6 on VPN: Not seeing link local address on l2tp interface
IPv6 link local address on vlan interfaces
RB850G and VPLS, as I do if Max L2MTU is 1506?
Something freezes mikrotik in v6 & frequent watchdog-reboot
RB850Gx2 IPSEC Kernel Failure
6.23 released!
RouterOS v6.27 released
v6.28 RC testing
RouterOS v6.28 released
v6.29 released
6.30 RC final fixes before release
Dynamic items unchangeable - why?
Cloud DNS is unavailable?
v6.33.5 [current] is released!
CHR feature requests
BUG: powerpc and wireless package
DFS Mode v6.38
Feature request for v7.x
Decline of Mikrotik?
Mode button on RB750r3
hEX mode button/switch next to usb port
IKEv2: IOS (10.2) and MacOSX (10.12.1) disconnect after 480 Sec
ROS 6.38 serious DHCP server problem
v6.38.3 [current]
Facebook Wifi
RouterOS 6.39.1 24h Trial Mode no Virtual-AP allowed?
v6.40rc [release candidate] is released!
Monitor tcp connection on Window client
v6.40.2 [current]
Feature request: OpenVPN compression LZO and UDP
v6.41rc [release candidate] is released! New bridge implementation!
Virtio-SCSI
LNS on Bell Canada (partially) Working
v6.42rc [release candidate] is released!
CHR disk resize
Feature Request: RAMDisk OR HTTP GET/POST Without Flash Writes
CHR suggestions for new functionality
CHR - problem with dhcp-client after reboot
CAP ac bad Antenna design?
hAP ac² LAN->WiFi 5GHz performance issue.
v6.43rc [release candidate] is released!
Significant improvement for wireless Nv2 PtMP
How to block neighbours Advertisment
*) winbox - added 160 MHz "channel-width" to wireless settings; ??
hAP ac^2 Problems---Extremely Poor Performance found in 2.4G and 5G WiFi
wAP 60G experience
RB3011UiAS password problem after upgrade
How to avoid Nstream Rate flicking?
mAP USB regulator?
ARM devices and NV2 protocol
v6.43.1 [stable] and v6.43.2 [stable] are released!
v6.43.11 [stable] is released!
v6.44 [stable] is released!
RouterOS v7.0 beta1 - when?
How to Mangle, Priority with HTB (Queue Tree) in ROS 3.16
v6.44.1 [stable] is released!
Feature requests
V6.45 on RB2011 /system health
CCR1072 vs Oem İ9-9900K
v6.45.1 [stable] is released!
ROS7: Requests for wireless features
Mikrotik CCR 1072 Hang
Mikrotik or NOT!!! Industry standarts say no!! Why?
v7.2.2 [stable] and v7.2.3 [stable] are released!
RouterOS v4.13 Released
It looks like there is a problem with the install of RouterOS on the CF. You can reinstall it There are serveral ways.
Probably easiest is to use netinstall on a Windows computer and set the RouterBIOS to boot with Etherboot.
You should read manual – the instructions are too long to write here.
http://www.mikrotik.com/docs/ros/2.8/guide/basic.main
John
