problem with msn and yahoo massenger
i have a problem with opening msn messenger and yahoo messenger ?
i don’t know why?
thanxxxxxxxxxxxxxxxx
Hi ;
Thats happened before to me and a friend
disable all the firewall filter rules , then bring them enable one by one and check with which rule you will have the problem again .
with best regards .
:laughing:
Do you use PPPoE? Could be an MTU issue.
carefully search for block port for Yahoo messenger(5050) or MSN messenger( MSN messenger choose dynamic port for Audio & Video usually 5004 to 65535, application sharing 1503, File Transfer 6891 to 6900).
Also try with changing TCP-MSS from mangle.
Rafiq…
Hi ;
I am using pppoe for my clients i don’t have problem with the messenger .
but when the traffic increase on the network the messenger takes longer time to be opened .
what i am looking for is making yahoo messenger first priority then the browsing and at last the download .
when i client doing download or browsing and then open the yahoo messenger , the messenger should take first priority .
with best regards .
hi, try to disable all your firewall filter on your MT Machine.
Then you must put three mangle rules…
:laughing:
Hi ;
I am not agree with you in this .
you will open many threats just to enable the messenger .
with best regards .
Which MT OS ver you are using? Ver 3 have L-7 filter and with it you can use yahoo and msn Prioritization better.
Hi ;
I am using 2.9.27 with level 6 .
can i control the priorty of yahoo messenger with it ?
with best regards
How to?
Can you give and example?
Thanks.
Why are you running 2.9.27? Upgrade to the newest version your license allows first. Many things have been fixed since then.
Hi ;
I will upgrade it today , i download 3.6 from the website and hope it will help .
thanks .
with best regards
