problem with multiple gateways
hi. recently i have been installed mk2.8.15 with 3 different gateways from 3 different isp and 1 internal network, it work well but i had a problem to access mk from outside, from internal network i can access my mk but from outside i can’t reach my mk router and if i ping 1 of three public ip installed on that mk box the answer is request time out :frowning: , i use policy routing to split the load to each gateways. any one maybe have a suggestion?
It would be great, if you specify your configuration.
:unamused:
