Problem with NAT port forwarding
I have a problem with NAT port forwarding. My setup is very basic and maybe some rules are missing. I have redirected port 54321 to a LAN address, but it doesn’t work.
Please help where I may have a bug.
# jul/13/2022 15:23:24 by RouterOS 6.49.1
# software id = LWCZ-9ZUX
# model = 922UAGS-5HPacD
# serial number =
/interface lte
set [ find ] name=lte1
add admin-mac=B8 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=no_country_set disabled=no distance=indoors \
    frequency=5745 frequency-mode=manual-txpower mode=ap-bridge rx-chains=0,1 \
    ssid="MikroTik 5.8" tx-chains=0,1 tx-power=30 tx-power-mode=\
    all-rates-fixed
set [ find default-name=wlan2 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    country=no_country_set disabled=no frequency=auto mode=ap-bridge \
    rx-chains=0,1 ssid="MikroTik 2.4" tx-chains=0,1 tx-power=30 \
    tx-power-mode=all-rates-fixed
set [ find default=yes ] authentication-types=wpa2-psk,wpa2-eap mode=\
    dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=
add name=dhcp_pool0 ranges=192.168.1.100-192.168.1.254,192.168.1.2
add address-pool=dhcp_pool0 disabled=no interface=bridge lease-time=6h name=\
    dhcp1
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
/ip dhcp-client
add comment=defconf disabled=no interface=bridge
/ip dhcp-server lease
add address=192.168.1.2 client-id=1: mac-address=\
    00 server=dhcp1
add address=192.168.1.0/24 gateway=192.168.1.1
add action=dst-nat chain=dstnat dst-port=54321 in-interface=lte1 log=yes \
    log-prefix=wg protocol=udp to-addresses=192.168.1.2 to-ports=54321
/system clock
set time-zone-name=Europe/Warsaw
/system leds
add interface=wlan2 leds="wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-le\
    d,wlan2_signal4-led,wlan2_signal5-led" type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
in-interface=lte1
Changes are BIG that you are begind CGNAT (Carrier-Grade NAT) which is more & more used.
You cannot do port-forwarding with CGNAT because another NAT is done at the provider over which you do not have any control!
Please check which IP-address you received on your LTE1-interface.
CGNAT has its own reserved IP range between 100.64.0.0 and 100.127.255.255
Thank you for your response. You put me in the right way of thinking. My connection to the internet operator is via a usb dongle with an lte modem. I will see if it is possible to change the usb key to the bridge so that I can use Mikrotik as a router.
Apart from that CHECK IF YOU HAVE A REAL PUBLIC IP
If not, first fix that problem or port-forward will never work.
