Problem with NAT with v7
Hello everyone,
I would like to report a strange behavior I am experiencing on two different MikroTik routers, running RouterOS v7.18.1 and v7.20.4.
Problem description
Under certain conditions, some traffic flows bypass the NAT rules that should be applied.
As a result, the traffic leaves the router without being NATed, even though the corresponding src-nat / masquerade rule exists and is correctly configured.
This does not happen consistently:
  • Most traffic is NATed correctly
  • Only some specific flows/sessions are affected
  • The issue appears intermittently
Expected behavior
All traffic matching the NAT rule should always be NATed before leaving the router.
Actual behavior
Some flows pass through the router without NAT being applied, causing:
  • Traffic to egress with private IP addresses
  • Connectivity issues on the upstream network
Environment
  • RouterOS versions affected:
    • v7.18.1
    • v7.20.4
  • The issue occurs on two different MikroTik devices
  • NAT rules are simple and standard (no fasttrack involved)
  • Firewall and NAT order has been verified
  • No policy routing is used for the affected traffic
Troubleshooting already done
  • Verified NAT rule order and matching
  • Checked connection tracking (/ip firewall connection print)
  • Disabled FastTrack to rule it out
  • Issue persists after reboot
  • Issue disappears temporarily if NAT rules are reloaded or connection tracking is flushed
Questions
  • Has anyone experienced a similar issue on RouterOS v7?
  • Could this be related to a connection tracking bug or NAT handling regression in recent v7 versions?
  • Is there any known workaround or fix?
Any feedback or guidance would be greatly appreciated.
With such small amount of info the only answer is:
Please choose the crystall ball we should use to guess the answer.
IMHO you should show us full configs to let check what could be wrong or write directly to the support.
Yeah sorry hahah.
I should have provided more details from the beginning. I was initially wondering whether other users had experienced the same behavior or a similar issue.
I have a router that terminates all PPPoE connections and works as a BRAS. Behind this router, I have two MikroTik routers. Using ACLs, I forward traffic from specific private IP ranges to these MikroTik routers so they can perform NAT.
After that, the MikroTik routers send the traffic back to the main router with NAT already applied (using public IPs instead of private IPs). However, the problem is that some traffic returns without NAT being applied.
Internet
                      \[ Upstream / Transit \]
                     (Public IP / BGP / GW)
                     |   ROUTER BRAS    |
                     | (PPPoE Server)    |
                     | Termina sesiones  |
           PPPoE clients (private IPs assigned on PPPoE)
     | MikroTik #1       |                          | MikroTik #2       |
     | RouterOS v7.18.1  |                          | RouterOS v7.20.4  |
     | "NAT Gateway"     |                          | "NAT Gateway"     |
            |  Receives private IP traffic from Main Router     |
            |  (source = customer private IP)              |
                           NAT applied here
                      (src-nat / masquerade)
                      Returns NATed traffic
                       back to Main Router BRAS
                                  v
                     |   Main router BRAS     |
                     | sends to Internet |
Here it is one of the mikrotik config:
/interface bonding
add mode=802.3ad name=bondingPBR slaves=sfp-sfpplus1,sfp-sfpplus2 transmit-hash-policy=layer-3-and-4
/interface vlan
add comment="LAN - Clientes" interface=bondingPBR name=vlan1204 vlan-id=1204
add comment="WAN - retorno" interface=bondingPBR name=vlan1304 vlan-id=1304
set tcp-established-timeout=7h
set discover-interface-list=none lldp-dcbx=no protocol=lldp
/ip settings
set tcp-syncookies=yes
add address=100.70.30.2/30 interface=vlan1204 network=100.70.30.0
add address=100.70.31.2/30 interface=vlan1304 network=100.70.31.0
/ip firewall address-list
add address=10.22.22.0/24 list=Allow-acess
add address=10.0.0.0/24 list=Allow-acess
add address=172.18.32.3 list=Allow-acess
add address=192.168.150.0/24 list=Allow-acess
add address=10.98.120.0/21 list=Privadas_200mb_CHhuawei3
add address=10.98.128.0/21 list=Privadas_200mb_CHhuawei3
add address=10.98.136.0/21 list=Privadas_200mb_CHhuawei3
add address=10.98.88.0/21 list=Privadas_200MB_Ch-Huawei1
add action=fasttrack-connection chain=forward comment=Fasttrack connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="Acepta conex establecidas" connection-state=established,related
add action=drop chain=input comment="WAN - INV" connection-state=invalid protocol=tcp
add action=drop chain=input comment="WAN - INV" connection-state=invalid protocol=udp
add action=drop chain=input comment="WAN - DROP Access" dst-port=8767,2789,8765 protocol=tcp src-address-list=!Allow-acess
add action=accept chain=input comment="WAN - REL,STAB" connection-state=established,related protocol=tcp
add action=accept chain=input comment="WAN - REL,STAB" connection-state=established,related protocol=udp
add action=accept chain=input comment="WAN - ICMP" protocol=icmp
add action=accept chain=forward comment=Server-Cache-games dst-address=10.150.1.19
add action=drop chain=forward comment="V41 Datos - Stop Forwarding Attacks" dst-port=445,25,139 protocol=tcp src-address=!10.241.9.247
add action=drop chain=forward comment="V41 Datos - Stop Forwarding Attacks" dst-port=445,25,139 protocol=udp
add action=drop chain=forward disabled=yes dst-address=10.0.0.0/8 log-prefix="DROP-PRIV->WAN " out-interface=vlan1304
add action=drop chain=forward dst-address=172.16.0.0/12 log-prefix="DROP-PRIV->WAN " out-interface=vlan1304
add action=drop chain=forward dst-address=192.168.0.0/16 log-prefix="DROP-PRIV->WAN " out-interface=vlan1304
add action=same chain=srcnat comment="Nat clientes Chasis Huawei 3" out-interface=vlan1304 same-not-by-dst=yes src-address-list=Privadas_200mb_CHhuawei3 to-addresses=
PUBLICS-IPSS!!
add action=same chain=srcnat comment="Nat clientes Chasis Huawei 3" log=yes same-not-by-dst=yes src-address-list=Privadas_200mb_CHhuawei3 to-addresses=PUBLICS-IPSS!!
add action=same chain=srcnat comment="Nat clientes Chasis Huawei 1" out-interface=vlan1304 same-not-by-dst=yes src-address-list=Privadas_200MB_Ch-Huawei1 to-addresses=
PUBLICS-IPSS!!
add action=same chain=srcnat comment="Nat clientes Chasis Huawei 1" log=yes same-not-by-dst=yes src-address-list=Privadas_200MB_Ch-Huawei1 to-addresses=PUBLICS-IPSS!!
add comment="Gateway a RT" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=100.70.31.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no dst-address=10.98.120.0/21 gateway=100.70.30.1 routing-table=main suppress-hw-offload=no
add disabled=no distance=1 dst-address=10.98.128.0/21 gateway=100.70.30.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=10.98.136.0/21 gateway=100.70.30.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=10.98.88.0/21 gateway=100.70.30.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
Here you can see when I do Torch, some traffic its going back with private ips, doenst aplly nat.:
Here a link to ascii drawing site:
https://asciiflow.com/
Isn't it possible that you see remainings packets of disconnected sessions?
There is 7h connection timeout set, so if client dissconets abnormally then connection still lives for a quite a long time however it has no matching end to do the proper nat.
Indeed there are known cases where some non-NATed packets may bleed out due to how connection tracking works. And the solution is to create a (raw?) firewall rule which drops such packets on WAN interface. If you're considering implementing such filters on ISP routers, then you probably should consider a blackhole route for such packets.
That is a possibility, however, even though the screenshot only shows a couple of connections, there are actually multiple clients experiencing connections that go outside of NAT.
These are active connections, not leftover packets from disconnected sessions. From what I was able to verify, the clients do not experience disconnections, and the sessions remain established while the traffic is being forwarded without NAT.
Hmm, interesting proposal.
What I had to do as a mitigation was to create an ACL on the main router to drop traffic returning from the MikroTik with private source IPs, meaning traffic that was not NATed. This helps mitigate the impact, but the issue itself still remains and seems to originate from the MikroTik behavior.
You mentioned that there are other known cases. Are you aware of other users reporting NAT-related issues in recent RouterOS v7 versions as well?
