Hi there!
I’m trying to reset my MikroTik RB750 using Netinstall. I’m using Win XP, and I’m directly connected to the router with a Ethernet cable to port 2. I’ve set try-ethernet-once-then-nand in the settings, but when restart it by cycling the power, it doesn’t show up in the router/drives list in netinstall. I’ve also tested to power it up with the reset button pressed, until the ACT LED stops glowing. But it doesn’t help. I have no firewall or AV running or anything else that could block a connection. What am I doing wrong?
Thanks in advance!
Regards,
Smith
