problem with NETINSTALL rb 450g Kernel panic - not syncing:
Hi
I have problems with a 450G rb soon as you update with netinstall I have this error in the terminal.
sorry my english is bad
Oops[#1]:
Cpu 0
$ 0 : 00000000 00000001 cffe866c 00000048
$ 4 : c037687c 000012ad ffffffff c03bdbac
$ 8 : c03c1c7f c03c1c7f 00000008 2d646972
$12 : 6e672074 00060000 00060101 6f206164
$16 : cffe864c cff89360 cffe866c 00000001
$20 : cfe71c40 00000004 ffffffff c0344e10
$24 : 00000018 c025f49c
$28 : cfe70000 cfe71c10 c0380000 c01e1d50
Hi : 00000058
Lo : 00000016
epc : c01e1dd8 yaffs_AddObjectToDirectory+0x114/0x188
Tainted: P
ra : c01e1d50 yaffs_AddObjectToDirectory+0x8c/0x188
Status: 1800d203 KERNEL EXL IE
Cause : 0080000c
BadVA : 0000004c
PrId : 00019374 (MIPS 24Kc)
Process init (pid: 17, threadinfo=cfe70000, task=cfe6c000, tls=00000000)
Stack : cfc0f000 cffe864c 00000003 0000002d cfc0f000 00000000 00000000 c01e4a50
c0344331 00000001 cff13800 c0196a14 ffffffff 0000001c 000014af 00001658
00029e97 6183001f 00000000 00000043 00000000 000057da 00000000 cfc0f000
cffe8638 cffe864c cfc0f000 cfc0f000 0000000a 0000001c cfe7fafc 00000000
00000000 00000000 7fe96388 c01e7c58 cfe71d60 c0216e44 c0337bbd c020bbcc
Call Trace:
[] yaffs_AddObjectToDirectory+0x114/0x188
[] yaffs_CheckpointRestore+0x1f4/0x42c
[] yaffs_GutsInitialise+0x4f4/0x1e94
[] yaffs_internal_read_super+0x6e8/0x828
[] yaffs_internal_read_super_mtd+0x14/0x2c
[] get_sb_bdev+0x138/0x1b0
[] yaffs_read_super+0x20/0x2c
[] vfs_kern_mount+0x68/0x11c
[] do_kern_mount+0x48/0x100
[] do_mount+0x620/0x694
[] sys_mount+0x8c/0xf0
[] stack_done+0x20/0x3c
Code: ae00001c 8e230068 26020020 ae030020 26230068 ae030024 ae220068 8e020008
—[ end trace 435ea96eb7f66dfd ]—
Kernel panic - not syncing: Attempted to kill init!
other error
Other error
Kernel bug detected[#1]:
Cpu 0
$ 0 : 00000000 c03b0000 00000001 cfc252d8
$ 4 : cf420000 c11e8400 cf420000 c01e96bc
$ 8 : fff7ffff 0000002c 00200200 00100100
$12 : 00080000 00000001 00060101 00000000
$16 : cfc0f000 cfc252b8 00000000 cfe71f00
$20 : cfe71ef8 cfe71f00 cfe93018 00000000
$24 : 00000000 c016398c
$28 : cfe70000 cfe71e28 00412b04 c01e96bc
Hi : 00000019
Lo : 00000005
epc : c0187508 kfree+0x64/0xe4
Tainted: P
ra : c01e96bc yaffs_Deinitialise+0xc4/0x168
Cause : 10800034
Stack : 00000000 cfc0f000 cfc252c8 00000000 cfc0f000 c01e96bc 00000000 cfe71f00
cfe71ef8 cfe71f00 cfc0f000 cfe7f800 00000000 c01df478 00000000 cfe71f00
cfe71ef8 cfe71f00 cfe93018 cfe7f800 c037d0c0 c018cf94 cfe7f800 c01a335c
c03c0000 cfe71f00 cfe71ef8 cf8101a0 c037d344 c018d060 cfe93000 cfe7f800
00010000 c03b0000 00000003 c01a3974 cfe7f800 c018d6d0 cfe93000 c018dcd4
Call Trace:
[] kfree+0x64/0xe4
[] yaffs_Deinitialise+0xc4/0x168
[] yaffs_put_super+0x78/0xd4
[] generic_shutdown_super+0xb8/0x164
[] kill_block_super+0x20/0x40
[] deactivate_locked_super+0x88/0xbc
[] sys_umount+0x30c/0x354
Code: 8ca20000 3042c000 2c420001 <00028036> 8fbf0014 8fb00010 00a02021 08059d60 27bd0018
—[ end trace 1dff1810c76f7216 ]—
------------[ cut here ]------------
WARNING: at /home/build/5.14/kernel/linux6/kernel/exit.c:896 do_exit+0x58/0x5e8()
Call Trace:
[] dump_stack+0x8/0x34
[] warn_slowpath_common+0x78/0xa4
[] warn_slowpath_null+0x18/0x24
[] do_exit+0x58/0x5e8
[] default_cu2_call+0x0/0x4c
—[ end trace 1dff1810c76f7217 ]—
have you upgraded the bootloader ?? what was the LAST version and firmware on your router.
Hi
The version is 2.28 routerBoot as stated here
RouterBOARD 450G
CPU frequency: 680 MHz
Memory size: 256 MB
Press any key within The 2 seconds to enter setup
RouterBOOT-2.28
What do you want to configure?
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
u - cpu mode
f - cpu frequency
r - reset booter configuration
e - format nand
g - upgrade firmware
i - board info
p - boot protocol
b - booter options
t - do memory testing
x - exit setup
your choice:
thanks for answering
gnando
what version you have upgraded to RB…
You can upgrade the bootloader…
Had same problem with a 411 board. You need to download an xmodem server app, a few freebies out there. Yoy will also need Hyperterminal or similar like putty and netinstall.
Step.1 connect board to pc via serial cable and eth cable (do not power up yet)
step.2 Open Hyperlink and open a session to com1 with 115200 .8.1 no control
With finger poised over the spacebar, power up the RB and tap the spacebar within 2secs
use the menu options to set the RB to upgrade firmware via tftp
close terminal session but do not power off RB
connect to RB with Xmodem App and upload the firmware file available from www.routerboard.com
Close Xmodem app and open a new hyperterminal session as before
You should see the reboot option appear in the terminal window. sy yes to load firmware and reboot
Now you can go through the standard netinstall procedure
I am sure someone knows a simpler way but this worked for me fine
Just to clarity this is firmware we are reparing here not the Ros itself. Same as flashing a BIOS on a PC
Hi all:
The problem is solved as follows
-Download the netinstall-version 4.17 routerboard
-Perform the update procedure and it worked perfect!
-Update to version 5.14 once the home router
thank you all for the help
Hi all:
Nice… :slight_smile:
