Problem with Netinstall
i have used netinstall a dozen times, but on two pieces of boardRB411 it just does not want to work right.
i followed the manual http://wiki.mikrotik.com/wiki/Netinstall to the letter.
oh npk version 4.11 stable
it hangs on “Waiting for installation server…”
in Netinstall the RB411 showed up and is ‘ready’ after selecting packages and clicking install nothing happens and the RB is “Waiting for installation server…”
serial output:
RouterBOOT booter 2.23
RouterBoard 411
CPU frequency: 300 MHz
Memory size: 64 MB
Press any key within 2 seconds to enter setup..
writing settings to flash… OK
trying bootp protocol… OK
Got IP address: 10.1.1.5
resolved mac address 00:1D:72:CC:04:B4
transfer started … transfer ok, time=2.36s
setting up elf image… OK
jumping to kernel code
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 0x:0x:4x:7x:2x:1x
software-id: blabla key:
blablabla ==
So taht`s all. Nothing happens. No RouterOS was loaded to RB. Where the problem is?
Bios of rb is newest (2.36). NAND of RB was formatted before above.
Thanks.
