Thanks, I didn’t know that “print” didn’t put everything. I wish some ports were open from the outside.
I succeeded with 2 ports, but if I try others or the upnp ports it always gives me that the nat is closed.
Here is my full configuration
# may/17/2023 12:13:42 by RouterOS 7.9
# software id = xxx
# model = RB5009UG+S+
# serial number = xxx
/container mounts
add dst=/etc/pihole name=etc_pihole src=\
/usb1-part1/container_pihole/etc-pihole
add dst=/etc/dnsmasq.d name=dnsmasq_pihole src=\
/usb1-part1/container_pihole/etc-dnsmasq.d
add dst=/ name=root_pihole src=/usb1-part1/container_pihole/root
/disk
set usb1 type=hardware
add parent=usb1 partition-number=1 partition-offset="1 048 576" \
partition-size="500 106 788 864" type=partition
add comment="VLAN bridge" name=br-VLANs protocol-mode=none
set [ find default-name=sfp-sfpplus1 ] advertise=\
10M-half,10M-full,100M-full,1000M-full,2500M-full
/interface veth
add address=192.168.0.8/20 gateway=192.168.0.1 name=veth1
/interface vlan
add comment=Mamma interface=br-VLANs mtu=1450 name=VLAN200 vlan-id=200
add comment=Guests interface=br-VLANs mtu=1450 name=VLAN300 vlan-id=300
add interface=sfp-sfpplus1 name=dimensione-vlan vlan-id=xxx
/interface pppoe-client
add add-default-route=yes disabled=no interface=dimensione-vlan name=\
dimensione-pppoe use-peer-dns=yes user=xxx
add name=WAN
add name=LAN
/interface wifiwave2 channel
add band=2ghz-ax disabled=no frequency=2462 name=silent width=20/40mhz-eC
add disabled=no name=guest
add band=2ghz-ax disabled=no name=home2ghz skip-dfs-channels=all
add band=5ghz-ax disabled=no name=home5ghz skip-dfs-channels=all
/interface wifiwave2 datapath
add bridge=br-VLANs disabled=no name=Wifi_Main
add bridge=br-VLANs disabled=no name=Wifi_Mamma vlan-id=200
add bridge=br-VLANs disabled=no name=Wifi_Guest vlan-id=300
/interface wifiwave2 security
add authentication-types=wpa2-psk name=home
add authentication-types=wpa2-psk disabled=no name=guest
add authentication-types=wpa2-psk disabled=no name=silent
/interface wifiwave2 configuration
add antenna-gain=1 channel=home2ghz country=Italy datapath=Wifi_Main \
disabled=no name=home2ghz security=home ssid=xxx1
add channel=guest country=Italy datapath=Wifi_Guest disabled=no name=guest \
security=guest ssid=xxx2
add channel=silent country=Italy datapath=Wifi_Mamma disabled=no hide-ssid=\
yes name=silent security=silent ssid=xxx3
add antenna-gain=0 channel=home5ghz country=Italy datapath=Wifi_Main \
disabled=no name=home5ghz security=home ssid=xxx1
add configuration=home5ghz disabled=no name=cap-wifi1
add configuration=home5ghz disabled=no name=cap-wifi2
add configuration=home2ghz disabled=no name=cap-wifi3
add configuration=home5ghz disabled=no name=cap-wifi4
add configuration=home5ghz disabled=no name=cap-wifi5
add configuration=home2ghz disabled=no name=cap-wifi6
add configuration=home2ghz disabled=no name=cap-wifi7
add configuration=home2ghz disabled=no name=cap-wifi8
add configuration=silent disabled=no mac-address=xxx \
master-interface=cap-wifi8 name=cap-wifi9
add configuration=guest disabled=no mac-address=xxx \
master-interface=cap-wifi8 name=cap-wifi10
master-interface=cap-wifi7 name=cap-wifi11
master-interface=cap-wifi3 name=cap-wifi12
master-interface=cap-wifi6 name=cap-wifi13
master-interface=cap-wifi5 name=cap-wifi14
master-interface=cap-wifi2 name=cap-wifi15
master-interface=cap-wifi1 name=cap-wifi16
master-interface=cap-wifi4 name=cap-wifi17
/ip kid-control
add fri=0s-1d mon=0s-1d name=system-dummy sat=0s-1d sun=0s-1d thu=0s-1d tue=\
0s-1d tur-fri=0s-1d tur-mon=0s-1d tur-sat=0s-1d tur-sun=0s-1d tur-thu=\
0s-1d tur-tue=0s-1d tur-wed=0s-1d wed=0s-1d
add name=CasaPool ranges=192.168.0.100-192.168.15.200
add name=MammaPool ranges=10.255.255.100-10.255.255.200
add name=GuestsPool ranges=172.16.0.2-172.16.15.254
add add-arp=yes address-pool=CasaPool interface=br-VLANs lease-script="# When \
\"1\" all DNS entries with IP address of DHCP lease are removed\r\
\n:local dnsRemoveAllByIp \"1\"\r\
\n# When \"1\" all DNS entries with hostname of DHCP lease are removed\r\
\n:local dnsRemoveAllByName \"1\"\r\
\n# When \"1\" addition and removal of DNS entries is always done also for\
\_non-FQDN hostname\r\
\n:local dnsAlwaysNonfqdn \"1\"\r\
\n# DNS domain to add after DHCP client hostname\r\
\n:local dnsDomain \"home.local\"\r\
\n# DNS TTL to set for DNS entries\r\
\n:local dnsTtl \"01:00:00\"\r\
\n# Source of DHCP client hostname, can be \"lease-hostname\" or any other\
\_lease attribute, like \"host-name\" or \"comment\"\r\
\n:local leaseClientHostnameSource \"comment\"\r\
\n\r\
\n:local leaseComment \"dhcp-lease-script_\$leaseServerName_\$leaseClientH\
ostnameSource\"\r\
\n:local leaseClientHostname\r\
\n:if (\$leaseClientHostnameSource = \"lease-hostname\") do={\r\
\n :set leaseClientHostname \$\"lease-hostname\"\r\
\n} else={\r\
\n :set leaseClientHostname ([:pick \\\r\
\n [/ip dhcp-server lease print as-value where server=\"\$leaseServerNa\
me\" address=\"\$leaseActIP\" mac-address=\"\$leaseActMAC\"] \\\r\
\n 0]->\"\$leaseClientHostnameSource\")\r\
\n}\r\
\n:local leaseClientHostnames \"\$leaseClientHostname\"\r\
\n:if ([:len [\$dnsDomain]] > 0) do={\r\
\n :if (\$dnsAlwaysNonfqdn = \"1\") do={\r\
\n :set leaseClientHostnames \"\$leaseClientHostname.\$dnsDomain,\$leas\
\n } else={\r\
\n :set leaseClientHostnames \"\$leaseClientHostname.\$dnsDomain\"\r\
\n }\r\
\n}\r\
\n:if (\$dnsRemoveAllByIp = \"1\") do={\r\
\n /ip dns static remove [/ip dns static find comment=\"\$leaseComment\" \
and address=\"\$leaseActIP\"]\r\
\n}\r\
\n:foreach h in=[:toarray value=\"\$leaseClientHostnames\"] do={\r\
\n :if (\$dnsRemoveAllByName = \"1\") do={\r\
\" and name=\"\$h\"]\r\
\n }\r\
and address=\"\$leaseActIP\" and name=\"\$h\"]\r\
\n :if (\$leaseBound = \"1\") do={\r\
\n :delay 1\r\
\n /ip dns static add comment=\"\$leaseComment\" address=\"\$leaseActIP\
\" name=\"\$h\" ttl=\"\$dnsTtl\"\r\
\n }\r\
\n}" lease-time=1d name=Casa_dchp
add add-arp=yes address-pool=MammaPool interface=VLAN200 lease-time=1d name=\
Mamma_dchp
add add-arp=yes address-pool=GuestsPool interface=VLAN300 lease-time=8h name=\
Guests_dhcp
/container
add envlist=pihole_envs interface=veth1 mounts=etc_pihole,dnsmasq_pihole \
root-dir=usb1-part1/container_pihole/pihole start-on-boot=yes
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1-part1/pull
/container envs
add key=TZ name=pihole_envs value=Europe/Rome
add key=WEBPASSWORD name=pihole_envs value="xxx"
add key=DNSMASQ_USER name=pihole_envs value=xxx
add bridge=br-VLANs interface=veth1
add bridge=br-VLANs interface=ether1
add bridge=br-VLANs interface=VLAN200
add bridge=br-VLANs interface=VLAN300
set discover-interface-list=all
/ipv6 settings
set disable-ipv6=yes forward=no
/interface bridge vlan
add bridge=br-VLANs comment="Mamma VLAN" tagged=br-VLANs,ether1 vlan-ids=200
add bridge=br-VLANs comment="Guest VLAN" tagged=br-VLANs,ether1 vlan-ids=300
add interface=dimensione-pppoe list=WAN
add interface=ether1 list=LAN
add interface=br-VLANs list=LAN
/interface wifiwave2 capsman
set enabled=yes interfaces=LAN package-path="" require-peer-certificate=no \
upgrade-policy=none
add channel=*8 country=Italy datapath=Wifi_Main disabled=yes name=home \
/interface wifiwave2 provisioning
add action=create-enabled disabled=no master-configuration=home2ghz \
radio-mac=xxx slave-configurations=guest
add action=create-enabled disabled=no master-configuration=home5ghz \
radio-mac=xxx slave-configurations=silent,guest
add address=192.168.0.1/20 interface=br-VLANs network=192.168.0.0
add address=172.16.0.1/20 interface=VLAN300 network=172.16.0.0
add address=10.255.255.1/24 interface=VLAN200 network=10.255.255.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1d
add address=192.168.0.4 comment="AP Esterno" mac-address=xxx \
server=Casa_dchp use-src-mac=yes
add address=192.168.0.3 comment="AP Centro" mac-address=xxx \
add address=192.168.0.10 client-id=xxx comment=Server-Rosae \
mac-address=xxx server=Casa_dchp use-src-mac=yes
add address=192.168.0.9 client-id=xxx comment=Server-Downless \
add address=192.168.0.6 comment="AP Studio" mac-address=xxx \
add address=192.168.0.14 client-id=xxx comment=\
"Harmony Soggiorno" mac-address=xxx server=Casa_dchp
add address=192.168.0.30 comment="Media GoogleHome Taverna" disabled=yes \
add address=192.168.0.22 comment="Telecamera Netatmo Garage" mac-address=\
add address=192.168.0.23 comment="Telecamera Netatmo Retro" mac-address=\
add address=192.168.0.26 comment="Termostato Netatmo Taverna" mac-address=\
add address=192.168.0.25 comment="Termostato Netatmo Terra" mac-address=\
add address=192.168.0.24 comment="Termostato Netatmo Sopra" mac-address=\
add address=192.168.0.27 comment="MCZ Caminetto" mac-address=\
add address=192.168.0.12 client-id=xxx comment=\
"Inverter Fronius" mac-address=xxx server=Casa_dchp
add address=192.168.0.13 comment="Shelly Button" mac-address=\
add address=192.168.0.17 client-id=xxx comment="PC Workbook" \
add address=192.168.0.18 client-id=xxx comment="PC SteamOS" \
mac-address=v server=Casa_dchp
add address=192.168.0.40 client-id=xxx comment="PC Macbook" \
add address=192.168.0.19 client-id=xxx comment="Phone ROG5" \
add address=10.255.255.3 client-id=xxx comment=\
"OLD Inverter Mamma" disabled=yes mac-address=xxx server=\
Mamma_dchp
add address=192.168.0.21 client-id=v comment=\
"Telecamera Netatmo Taverna" mac-address=xxx server=\
Casa_dchp
add address=192.168.0.20 client-id=xxx comment=\
"Telecamera Netatmo Terra" mac-address=xxx server=Casa_dchp
add address=192.168.0.36 client-id=xxx comment=\
"Media TV Cucina" mac-address=xxx server=Casa_dchp
add address=192.168.0.37 client-id=xxx comment=\
"Media Shield Soggiorno" mac-address=xxx server=Casa_dchp
add address=192.168.0.34 client-id=xxx comment="Media TVHDR" \
add address=192.168.0.38 client-id=xxx comment=\
"Media GoogleTV Cucina" disabled=yes mac-address=xxx \
server=Casa_dchp
add address=192.168.0.41 comment="Termometro Shelly Sopra" mac-address=\
add address=192.168.0.39 client-id=xxx comment=\
"Media GoogleTV Cucina-WLAN" disabled=yes mac-address=xxx \
server=Casa_dchp
add address=192.168.0.90 client-id=xxx comment=ICIA-Nuc \
add address=192.168.0.52 client-id=xxx comment=\
"Tablet Nvidia Shield" mac-address=xxx server=Casa_dchp
add address=192.168.0.70 comment="Climatizzatore Daikin Notte" mac-address=\
add address=192.168.0.28 client-id=xxx comment=\
"MCZ Stufa Sopra" mac-address=xxx server=Casa_dchp
add address=192.168.0.62 comment="Media GoogleNest Cucina" disabled=yes \
add address=192.168.0.42 comment="Termometro Shelly Terra" mac-address=\
add address=192.168.0.48 client-id=xxx comment=\
"Robot Neato Terrra" mac-address=xxx server=Casa_dchp
add address=192.168.0.60 client-id=xxx comment="ICIA Redmi" \
add address=192.168.0.29 client-id=xxx comment=\
"Watch Galaxy4" mac-address=xxx server=Casa_dchp
add address=10.255.255.5 client-id=xxx comment=\
"Climatizzatore Mamma Camera" mac-address=xxx server=\
Mamma_dchp
add address=10.255.255.4 client-id=xxx comment=\
"Climatizzatore Mamma Soggiorno" mac-address=xxx server=\
Mamma_dchp
add address=192.168.0.46 comment="Media Denon" mac-address=xxx \
server=Casa_dchp
add address=192.168.0.47 comment="Robot Neato Taverna" mac-address=\
add address=192.168.0.50 comment="Printer Canon" mac-address=\
add address=192.168.0.51 comment="PC MameCAB" mac-address=xxx \
server=Casa_dchp
add address=192.168.0.53 comment="Media Shield Studio" mac-address=\
add address=192.168.0.55 comment="Media GoogleHome Studio" disabled=yes \
add address=192.168.0.15 comment="Harmony Studio" mac-address=\
add address=192.168.0.16 comment="Harmony Taverna" mac-address=\
add address=192.168.0.56 comment="Media TV Studio" mac-address=\
add address=192.168.0.57 comment="Media TV Taverna" mac-address=\
add address=192.168.0.58 comment="Media TV Soggiorno" mac-address=\
add address=192.168.0.59 comment="ICIA Portatile" mac-address=\
add address=192.168.0.61 comment="Media GoogleTV Studio" mac-address=\
add address=192.168.0.63 comment="OLD Console Nintendo Switch" mac-address=\
add address=192.168.0.64 comment="Console Nintendo3DS" mac-address=\
add address=192.168.0.65 comment="Console NintendoWII" mac-address=\
add address=192.168.0.66 comment="PC SteamDeck" mac-address=xxx \
server=Casa_dchp
add address=192.168.0.67 comment="Console Xbox360" mac-address=\
add address=192.168.0.68 comment="Console XboxOne" mac-address=\
add address=192.168.0.89 comment="Phone ROG3" mac-address=xxx \
server=Casa_dchp
add address=192.168.0.87 comment="Presa Meross Station" mac-address=\
add address=192.168.0.75 comment="Presa Meross ITA" mac-address=\
add address=192.168.0.76 comment="Presa Merros SteamOS" mac-address=\
add address=192.168.0.77 comment="Presa Meross Lavatrice" mac-address=\
add address=192.168.0.78 comment="Presa Meross MameCAB" mac-address=\
add address=192.168.0.79 comment="Presa Meross Flipper" mac-address=\
add address=192.168.0.80 comment="Presa Meross MediaStudio" mac-address=\
add address=192.168.0.81 comment="Presa Meross AccessoryStudio" mac-address=\
add address=192.168.0.82 comment="Presa Meross Lavastoviglie" mac-address=\
add address=192.168.0.83 comment="Presa Meross MediaTaverna" mac-address=\
add address=192.168.0.84 comment="Presa Meross Workbook" mac-address=\
add address=192.168.0.85 comment="Presa Meross Asciugatrice" mac-address=\
add address=192.168.0.86 comment="Presa Meross Screen" mac-address=\
add address=192.168.0.71 comment="Climatizzatore Daikin Mansarda" \
add address=192.168.0.72 comment="Climatizzatore Daikin Soggiorno" \
add address=192.168.0.73 comment="Climatizzatore Daikin Taverna" mac-address=\
add address=192.168.0.44 comment="Allagamento Shelly" mac-address=\
add address=192.168.0.91 comment="Media CastAudio" mac-address=\
add address=10.255.255.10 comment="ZIO Notebook" mac-address=\
xxx server=Mamma_dchp
add address=10.255.255.11 comment="ZIO Honor6X" mac-address=xxx \
server=Mamma_dchp
add address=10.255.255.12 comment="ZIO TabletSamsung" mac-address=\
add address=10.255.255.13 comment="ZIO Redmi11" mac-address=xxx \
server=Mamma_dchp
add address=192.168.0.43 comment="Termometro Shelly Taverna" mac-address=\
add address=192.168.0.49 client-id=xxx comment=\
"Robot Neato Primo" mac-address=xxx server=Casa_dchp
add address=192.168.0.92 comment="Shelly Button HTC" mac-address=\
add address=192.168.0.93 comment="Robot Braava Lavapavimenti" mac-address=\
add address=192.168.0.96 comment="Alexa Camera Matrimoniale" mac-address=\
add address=192.168.0.97 comment="Alexa Mansarda" mac-address=\
add address=192.168.0.99 comment="Alexa Taverna" mac-address=\
add address=192.168.0.95 comment="Alexa Salotto" mac-address=\
add address=192.168.0.94 client-id=xxx comment=\
"Alexa View Studio" mac-address=xxx server=Casa_dchp
add address=192.168.0.98 comment=Ring mac-address=xxx server=\
Casa_dchp
add address=192.168.0.101 client-id=xxx comment=\
"Alexa View Cucina" mac-address=xxx server=Casa_dchp
add address=192.168.0.100 client-id=xxx comment=\
"PC Surface WLAN" mac-address=xxx server=Casa_dchp
add address=10.255.255.2 comment="AP Mamma" mac-address=xxx \
server=Mamma_dchp
add address=192.168.0.5 comment="AP Taverna" mac-address=xxx \
add address=192.168.0.102 client-id=xxx comment=\
"Media Shield Taverna" mac-address=xxx server=Casa_dchp
add address=192.168.0.104 client-id=xxx comment=\
"Media FIreStick Mansarda" mac-address=xxx server=Casa_dchp
add address=10.255.255.6 client-id=xxx comment=\
"Inverter Mamma" mac-address=xxx server=Mamma_dchp
add address=192.168.0.103 client-id=xxx comment=\
"Media FIreStick Cucina" mac-address=xxx server=Casa_dchp
add address=10.255.255.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.255.255.1 \
netmask=24
add address=172.16.0.0/20 dns-server=1.1.1.1,1.0.0.1 gateway=172.16.0.1 \
netmask=20
add address=192.168.0.0/20 dns-server=192.168.0.8,192.168.0.8 gateway=\
192.168.0.1 netmask=20
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.27 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=Printer-Canon.dynamic.example.local ttl=15m
name=Printer-Canon ttl=15m
add address=192.168.0.31 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=SonyTV-Soggiorno.dynamic.example.local ttl=15m
name=SonyTV-Soggiorno ttl=15m
add address=192.168.0.26 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=PC-Workbook.dynamic.example.local ttl=15m
name=PC-Workbook ttl=15m
add address=192.168.0.123 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=.dynamic.example.local ttl=15m
add address=192.168.15.191 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=MAMMA-Clima.casa ttl=15m
name=MAMMA-Clima ttl=15m
add address=192.168.0.14 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=Harmony-Soggiorno.casa ttl=15m
name=Harmony-Soggiorno ttl=15m
add address=192.168.0.15 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=Harmony-Taverna.casa ttl=15m
name=Harmony-Taverna ttl=15m
add address=192.168.0.13 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=Harmony-Studio.casa ttl=15m
name=Harmony-Studio ttl=15m
add address=192.168.0.18 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=Shelly-Terra.casa ttl=15m
name=Shelly-Terra ttl=15m
add address=192.168.0.19 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=Shelly-Taverna.casa ttl=15m
name=Shelly-Taverna ttl=15m
add address=192.168.0.20 comment=dhcp-lease-script_DHCP_SRV_Casa_comment \
name=Shelly-Primo.casa ttl=15m
name=Shelly-Primo ttl=15m
add address=192.168.0.3 comment=dhcp-lease-script_Casa_DHCP_SRV_comment name=\
"AP Centrale.lan" ttl=15m
"AP Centrale" ttl=15m
add address=192.168.0.4 comment=dhcp-lease-script_Casa_DHCP_SRV_comment name=\
"AP Esterno.casa" ttl=15m
"AP Esterno" ttl=15m
add address=192.168.0.30 comment=dhcp-lease-script_Casa_DHCP_SRV_comment \
name=NvidiaTV-Soggiorno.casa ttl=15m
name=NvidiaTV-Soggiorno ttl=15m
add address=192.168.0.9 comment=dhcp-lease-script_Casa_DHCP_SRV_comment name=\
Server-Downless.casa ttl=15m
Server-Downless ttl=15m
add address=192.168.0.31 comment=dhcp-lease-script_Casa_DHCP_SRV_comment \
name=SonyTV-Soggiorno.casa ttl=15m
add address=192.168.0.17 comment=dhcp-lease-script_Casa_DHCP_SRV_comment \
name=Shelly-Button.casa ttl=15m
name=Shelly-Button ttl=15m
add address=192.168.0.22 comment=dhcp-lease-script_Casa_DHCP_SRV_comment \
name=MCZ-Stufa.casa ttl=15m
name=MCZ-Stufa ttl=15m
add address=192.168.0.21 comment=dhcp-lease-script_Casa_DHCP_SRV_comment \
name=MCZ-Caminetto.casa ttl=15m
name=MCZ-Caminetto ttl=15m
add address=192.168.0.12 comment=dhcp-lease-script_Casa_DHCP_SRV_comment \
name=Inverter-Fronius.casa ttl=15m
name=Inverter-Fronius ttl=15m
add address=192.168.0.120 comment=dhcp-lease-script_Casa_DHCP_SRV_comment \
name=.casa ttl=15m
add address=192.168.0.10 comment=dhcp-lease-script_dchpCasa_comment name=\
Server-Rosae.casa ttl=15m
Server-Rosae ttl=15m
add address=192.168.0.111 comment=dhcp-lease-script_dchpCasa_comment name=\
.casa ttl=15m
add address=192.168.0.20 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=Netatmo-Welcome.home ttl=15m
name=Netatmo-Welcome ttl=15m
add address=192.168.0.10 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=Rosae.home ttl=15m
name=Rosae ttl=15m
add address=192.168.0.34 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=HDHR.home ttl=15m
name=HDHR ttl=15m
add address=192.168.0.22 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=Netatmo-Presence.home ttl=15m
name=Netatmo-Presence ttl=15m
add address=192.168.0.23 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
add address=192.168.0.80 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=Meross_Smart_Switch.home ttl=15m
name=Meross_Smart_Switch ttl=15m
add address=192.168.0.28 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=espressif.home ttl=15m
name=espressif ttl=15m
add address=192.168.0.27 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=MCZ-RemoteService.home ttl=15m
name=MCZ-RemoteService ttl=15m
add address=192.168.0.85 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name="Meross Smart Plug.home" ttl=15m
name="Meross Smart Plug" ttl=15m
add address=192.168.0.26 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name="Netatmo Relay.home" ttl=15m
name="Netatmo Relay" ttl=15m
add address=192.168.0.12 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=Inverter-Fronius.home ttl=15m
add address=192.168.0.93 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=iRobot.home ttl=15m
name=iRobot ttl=15m
add address=192.168.0.36 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=LGwebOSTV.home ttl=15m
name=LGwebOSTV ttl=15m
add address=192.168.0.9 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=Downless.home ttl=15m
name=Downless ttl=15m
add address=192.168.0.30 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=Google-Home.home ttl=15m
name=Google-Home ttl=15m
add address=192.168.0.55 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=Google-Home-Mini.home ttl=15m
name=Google-Home-Mini ttl=15m
add address=192.168.0.92 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=shellybutton1.home ttl=15m
name=shellybutton1 ttl=15m
add address=192.168.0.60 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=Redmi-Note-9-Pro.home ttl=15m
name=Redmi-Note-9-Pro ttl=15m
add address=192.168.0.19 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=ROG-Phone-5.home ttl=15m
name=ROG-Phone-5 ttl=15m
add address=192.168.0.29 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=SM-R890.home ttl=15m
name=SM-R890 ttl=15m
add address=192.168.0.49 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=VacuumRobot.home ttl=15m
name=VacuumRobot ttl=15m
add address=192.168.0.17 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=WorkBook.home ttl=15m
name=WorkBook ttl=15m
add address=192.168.0.44 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=shellyflood.home ttl=15m
name=shellyflood ttl=15m
add address=192.168.0.41 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name=shellyht.home ttl=15m
name=shellyht ttl=15m
add address=192.168.0.42 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
add address=192.168.0.6 comment=dhcp-lease-script_Casa_dchp_lease-hostname \
name="Studio AP.home" ttl=15m
name="Studio AP" ttl=15m
add address=192.168.0.31 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Media GoogleHome Mansarda.dynamic.casa.local" ttl=15m
"Media GoogleHome Mansarda" ttl=15m
add address=192.168.0.62 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Media GoogleNest Cucina.dynamic.casa.local" ttl=15m
"Media GoogleNest Cucina" ttl=15m
add address=192.168.0.93 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Robot Braava Lavapavimenti..casa" ttl=1h
"Robot Braava Lavapavimenti" ttl=1h
add address=192.168.0.19 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Phone ROG5.home.local" ttl=1h
"Phone ROG5" ttl=1h
add address=192.168.0.20 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Telecamera Netatmo Terra.home.local" ttl=1h
"Telecamera Netatmo Terra" ttl=1h
add address=192.168.0.81 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Presa Meross AccessoryStudio.home.local" ttl=1h
"Presa Meross AccessoryStudio" ttl=1h
add address=192.168.0.79 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Presa Meross Flipper.home.local" ttl=1h
add address=192.168.0.97 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Alexa Mansarda.home.local" ttl=1h
add address=192.168.0.75 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Presa Meross ITA.home.local" ttl=1h
"Presa Meross Flipper" ttl=1h
"Alexa Mansarda" ttl=1h
"Presa Meross ITA" ttl=1h
add address=192.168.0.95 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Alexa Salotto.home.local" ttl=1h
"Alexa Salotto" ttl=1h
add address=192.168.0.15 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Harmony Studio.home.local" ttl=1h
add address=192.168.0.96 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Alexa Camera Matrimoniale.home.local" ttl=1h
"Harmony Studio" ttl=1h
"Alexa Camera Matrimoniale" ttl=1h
add address=192.168.0.23 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Telecamera Netatmo Retro.home.local" ttl=1h
add address=192.168.0.22 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Telecamera Netatmo Garage.home.local" ttl=1h
"Telecamera Netatmo Retro" ttl=1h
"Telecamera Netatmo Garage" ttl=1h
add address=192.168.0.21 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Telecamera Netatmo Taverna.home.local" ttl=1h
add address=192.168.0.16 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Harmony Taverna.home.local" ttl=1h
"Telecamera Netatmo Taverna" ttl=1h
"Harmony Taverna" ttl=1h
add address=192.168.0.87 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Presa Meross Station.home.local" ttl=1h
"Presa Meross Station" ttl=1h
add address=192.168.0.85 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Presa Meross Asciugatrice.home.local" ttl=1h
"Presa Meross Asciugatrice" ttl=1h
add address=192.168.0.86 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Presa Meross Screen.home.local" ttl=1h
"Presa Meross Screen" ttl=1h
add address=192.168.0.25 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Termostato Netatmo Terra.home.local" ttl=1h
add address=192.168.0.26 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Termostato Netatmo Taverna.home.local" ttl=1h
"Termostato Netatmo Terra" ttl=1h
add address=192.168.0.103 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Media FIreStick Cucina.home.local" ttl=1h
"Termostato Netatmo Taverna" ttl=1h
"Media FIreStick Cucina" ttl=1h
add address=192.168.0.104 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Media FIreStick Mansarda.home.local" ttl=1h
"Media FIreStick Mansarda" ttl=1h
add address=192.168.0.47 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Robot Neato Taverna.home.local" ttl=1h
"Robot Neato Taverna" ttl=1h
add address=192.168.0.49 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Robot Neato Primo.home.local" ttl=1h
"Robot Neato Primo" ttl=1h
add address=192.168.0.70 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Climatizzatore Daikin Notte.home.local" ttl=1h
"Climatizzatore Daikin Notte" ttl=1h
add address=192.168.0.71 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Climatizzatore Daikin Mansarda.home.local" ttl=1h
"Climatizzatore Daikin Mansarda" ttl=1h
add address=192.168.0.76 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Presa Merros SteamOS.home.local" ttl=1h
"Presa Merros SteamOS" ttl=1h
add address=192.168.0.66 comment=dhcp-lease-script_Casa_dchp_comment name=\
"PC SteamDeck.home.local" ttl=1h
"PC SteamDeck" ttl=1h
add address=192.168.0.29 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Watch Galaxy4.home.local" ttl=1h
"Watch Galaxy4" ttl=1h
add address=192.168.0.98 comment=dhcp-lease-script_Casa_dchp_comment name=\
Ring.home.local ttl=1h
Ring ttl=1h
add address=192.168.0.72 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Climatizzatore Daikin Soggiorno.home.local" ttl=1h
"Climatizzatore Daikin Soggiorno" ttl=1h
add address=192.168.0.48 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Robot Neato Terrra.home.local" ttl=1h
"Robot Neato Terrra" ttl=1h
add address=192.168.0.44 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Allagamento Shelly.home.local" ttl=1h
"Allagamento Shelly" ttl=1h
add address=192.168.0.77 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Presa Meross Lavatrice.home.local" ttl=1h
"Presa Meross Lavatrice" ttl=1h
add address=192.168.0.42 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Termometro Shelly Terra.home.local" ttl=1h
"Termometro Shelly Terra" ttl=1h
add address=192.168.0.41 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Termometro Shelly Sopra.home.local" ttl=1h
"Termometro Shelly Sopra" ttl=1h
add address=192.168.0.43 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Termometro Shelly Taverna.home.local" ttl=1h
"Termometro Shelly Taverna" ttl=1h
add address=192.168.0.50 comment=dhcp-lease-script_Casa_dchp_comment name=\
"Printer Canon.home.local" ttl=1h
"Printer Canon" ttl=1h
/ip firewall address-list
add address=192.168.0.0/20 comment="Casa NET" list=net_casa
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=bogons
add address=224.0.0.0/4 comment=\
"MC, Class D, IANA # Check if you need this subnet before enable it" \
list=bogons
add address=xxx.mynetname.net list=WAN
add address=10.255.255.0/24 comment="Mamma NET" list=net_mamma
add address=172.16.0.0/20 comment="Guest NET" list=net_guest
add action=add-src-to-address-list address-list=Syn_Flooder \
address-list-timeout=30m chain=input comment=\
"Add Syn Flood IP to the list" connection-xxxit=30,32 protocol=tcp \
tcp-flags=syn
add action=drop chain=forward comment="DROP traffico da Guest a -Casa" \
dst-address-list=net_casa src-address-list=net_guest
add action=drop chain=forward comment="DROP traffico da Mamma a Casa" \
dst-address-list=net_casa src-address-list=net_mamma
add action=drop chain=input comment="Drop to syn flood list" \
src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner \
address-list-timeout=1w chain=input comment="Port Scanner Detect" \
protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" \
src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=\
ICMP protocol=icmp
add action=drop chain=input comment="Block all access to the winbox - except t\
o support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUP\
PORT ADDRESS LIST" dst-port=8291 protocol=tcp src-address-list=!net_casa
add action=jump chain=forward comment="Jump for icmp forward flow" \
jump-target=ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
bogons
add action=add-src-to-address-list address-list=spammers \
address-list-timeout=3h chain=forward comment=\
"Add Spammers to the list for 3 hours" connection-xxxit=30,32 dst-port=\
25,587 xxxit=30/1m,0 protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 \
protocol=tcp src-address-list=spammers
add action=accept chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input comment="Accept to established connections" \
connection-state=established
add action=accept chain=input comment="Accept to related connections" \
connection-state=related
add action=accept chain=input comment="Full access to net_casa address list" \
src-address-list=net_casa
add action=accept chain=input comment="Full access to net_mamma address list" \
add action=accept chain=input comment="Full access to net_guest address list" \
add action=drop chain=input comment="Drop anything else! # DO NOT ENABLE THIS \
RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED"
add action=accept chain=ICMP comment=\
"Echo request - Avoiding Ping Flood, adjust the xxxit as needed" \
icmp-options=8:0 xxxit=2,5 protocol=icmp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=\
icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 \
protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=\
3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP \
protocol=icmp
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
"Mark connections for hairpin NAT" dst-address-list=WAN dst-xxxit=\
1,5,dst-address/1m40s xxxit=1,5:packet new-connection-mark="Hairpin NAT" \
passthrough=yes psd=21,3s,3,1 src-address-list=net_casa
add action=masquerade chain=srcnat src-address=192.168.0.0/20
add action=masquerade chain=srcnat src-address=172.16.0.0/20
add action=masquerade chain=srcnat src-address=10.255.255.0/24
add action=masquerade chain=srcnat comment="HARPIN NAT" connection-mark=\
"Hairpin NAT"
add action=dst-nat chain=dstnat comment="DNS Redirect to PI-Hole" \
dst-address=!192.168.0.8 dst-port=53 protocol=udp src-address-list=\
192.168.0.0/24 to-addresses=192.168.0.8 to-ports=53
dst-address=!192.168.0.8 dst-port=53 protocol=tcp src-address-list=\
add action=masquerade chain=srcnat out-interface=dimensione-pppoe
add action=dst-nat chain=dstnat comment="Port forward: HASSIO" disabled=yes \
dst-address-list=net_casa dst-port=8123 protocol=tcp to-addresses=\
192.168.0.10 to-ports=8123
add action=dst-nat chain=dstnat comment="Port forward: HASSIO" \
dst-address-list=WAN dst-port=8123 protocol=tcp to-addresses=192.168.0.10 \
to-ports=8123
add action=masquerade chain=srcnat comment="Port forward: HASSIO" disabled=\
yes dst-address=192.168.0.10 dst-port=8123 out-interface=br-VLANs \
protocol=tcp src-address=192.168.0.0/20
add action=dst-nat chain=dstnat comment="Port Online: PLEX" dst-port=32400 \
in-interface=dimensione-pppoe protocol=tcp to-addresses=192.168.0.10 \
to-ports=32400
add action=dst-nat chain=dstnat comment="Port Online: HASSIO" dst-port=8123 \
to-ports=8123
add action=dst-nat chain=dstnat comment="Port Online: INVERTERT MAMMA" \
dst-port=10000 in-interface=dimensione-pppoe protocol=tcp to-addresses=\
10.255.255.6 to-ports=10000
/ip firewall service-port
set ftp disabled=yes
set h323 disabled=yes
set pptp disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add disabled=yes interface=ether1 type=internal
add interface=dimensione-pppoe type=external
add interface=VLAN200 type=internal
add interface=br-VLANs type=internal
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
established,related,untracked
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
connection-state=invalid
add action=drop chain=forward comment="defconf: rfc4890 drop hop-xxxit=1" \
hop-xxxit=equal:1 protocol=icmpv6
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=RB-Router
/system note
set show-at-login=no
