problem with PCC and Hotspot .
i have to lines with load balance PCC but there is problem that hot spot doesn’t redirect automatic , i have to write 10.5.50.1 in my browser to login .
my config :
/ ip address
add address=10.5.50.1/24 network=10.5.50.0 broadcast=10.5.50.255 interface=Local
add address=192.168.1.5/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
add address=192.168.0.5/24 network=192.168.0.0 broadcast=192.168.0.255 interface=WAN2
/ ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=WAN2
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=Local action=mark-routing new-routing-mark=WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=Local action=mark-routing new-routing-mark=WAN2
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.0.1 routing-mark=WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.0.1 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
it’s same as example on Wiki .
Can some one help me ?
I think that’s because traffic going to an outside server is getting mangled in prerouting before the Hotspot has a change to intercept it.
Try replacing
With
add chain=prerouting dst-address-type=!local hotspot=auth in-interface=Local per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local hotspot=auth in-interface=Local per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
To only PCC authenticated Hotspot traffic. There may be other (better) workarounds.
thank u fewi
i will test it then i will replay again .
another problem
when i actived hotspot and made " hotspot=auth" i got only one line working
i tried to change auth to " From clients , http , local dst , to clients "
all the same
so is there anything wrong i did ?
or there is some settings i missed ?
help pls
Still waiting replay
Please, configure PCC like this: http://wiki.mikrotik.com/wiki/Advanced_Routing_Failover_without_Scripting
And then take 40 seconds to configure the hotspot ; ) easyer than repair your config.
I have same problem. and this rule is working. thanks FEWI
