Problem with PCC + Hotspot
i got problem with my connection when hotspot enabled
i set my mikrotik to do PCC 4 ISP and worked, then i try add hotspot into port 5 (LOCAL NETWORK)
login page showed up and login success, but no internet
i already try add hotspot=auth, try add ip pool to user profile
172.16.0.1/21    172.16.0.0   ether-5-wifi-ged1
1   192.168.5.1/24   192.168.5.0  ether11
2 D 192.168.3.34/24  192.168.3.0  ether-3-internet
3 D 192.168.1.2/24   192.168.1.0  ether-1-internet-ged1
4 D 192.168.4.2/24   192.168.4.0  ether-4-internet
5 D 192.168.2.2/24   192.168.2.0  ether-2-internet
 2 X  chain=srcnat action=masquerade out-interface=ether-2-internet log=no log-prefix=""
 3 X  chain=srcnat action=masquerade out-interface=ether-3-internet log=no log-prefix=""
 4 X  chain=srcnat action=masquerade out-interface=ether-4-internet log=no log-prefix=""
 5 X  chain=srcnat action=masquerade out-interface=ether-1-internet-ged1 log=no log-prefix=""
21    ;;; LB PCC by buananet.com
      chain=prerouting action=accept src-address-list=LOCAL-IP
      dst-address-list=LOCAL-IP
22    ;;; LB PCC by buananet.com
      chain=postrouting action=accept src-address-list=LOCAL-IP
23    ;;; LB PCC by buananet.com
      chain=forward action=accept src-address-list=LOCAL-IP
24    ;;; LB PCC by buananet.com
      chain=input action=accept src-address-list=LOCAL-IP
25    ;;; LB PCC by buananet.com
      chain=output action=accept src-address-list=LOCAL-IP
26    ;;; LB PCC by buananet.com
      chain=input action=mark-connection
      new-connection-mark=cm-ether-1-internet-ged1 passthrough=yes
      in-interface=ether-1-internet-ged1
27    ;;; LB PCC by buananet.com
      new-connection-mark=cm-ether-2-internet passthrough=yes
      in-interface=ether-2-internet
28    ;;; LB PCC by buananet.com
      new-connection-mark=cm-ether-3-internet passthrough=yes
      in-interface=ether-3-internet
29    ;;; LB PCC by buananet.com
      new-connection-mark=cm-ether-4-internet passthrough=yes
      in-interface=ether-4-internet
30    ;;; LB PCC by buananet.com
      chain=output action=mark-routing
      new-routing-mark=to-ether-1-internet-ged1 passthrough=yes
31    ;;; LB PCC by buananet.com
      chain=output action=mark-routing new-routing-mark=to-ether-2-internet
      passthrough=yes connection-mark=cm-ether-2-internet
32    ;;; LB PCC by buananet.com
      chain=output action=mark-routing new-routing-mark=to-ether-3-internet
      passthrough=yes connection-mark=cm-ether-3-internet
33    ;;; LB PCC by buananet.com
      chain=output action=mark-routing new-routing-mark=to-ether-4-internet
      passthrough=yes connection-mark=cm-ether-4-internet
34    ;;; LB PCC by buananet.com
      chain=prerouting action=mark-connection
      dst-address-type=!local hotspot=auth in-interface=ether-5-wifi-ged1
      per-connection-classifier=both-addresses-and-ports:4/0 log=no
      log-prefix=""
35    ;;; LB PCC by buananet.com
      per-connection-classifier=both-addresses-and-ports:4/1 log=no
      log-prefix=""
36    ;;; LB PCC by buananet.com
      per-connection-classifier=both-addresses-and-ports:4/2 log=no
      log-prefix=""
37    ;;; LB PCC by buananet.com
      per-connection-classifier=both-addresses-and-ports:4/3 log=no
      log-prefix=""
38    ;;; LB PCC by buananet.com
      chain=prerouting action=mark-routing
      connection-mark=cm-ether-1-internet-ged1 in-interface=ether-5-wifi-ged1
39    ;;; LB PCC by buananet.com
      new-routing-mark=to-ether-2-internet passthrough=yes
      connection-mark=cm-ether-2-internet in-interface=ether-5-wifi-ged1
40    ;;; LB PCC by buananet.com
      new-routing-mark=to-ether-3-internet passthrough=yes
      connection-mark=cm-ether-3-internet in-interface=ether-5-wifi-ged1
41    ;;; LB PCC by buananet.com
      new-routing-mark=to-ether-4-internet passthrough=yes
      connection-mark=cm-ether-4-internet in-interface=ether-5-wifi-ged1
