Hi and Thank you for this post
I have tow problems with PCC.
We have 4 unequal WAN connection from different ISPs. I config our RB2011U for PCC loadBalancing according to the MikroTik website article (http://wiki.mikrotik.com/wiki/Manual:PCC) and everything is good.
But I have 2 questions :
How can I route the traffic of a specific host (192.168.1.50) from LAN to WAN1 link forever?
How can I force FTP traffic go through WAN2 link and use WAN3 link as failover link?
This is my config:
/interface
set name=LAN numbers=5
set name=WAN1 numbers=6
set name=WAN2 numbers=7
set name=WAN3 numbers=8
set name=WAN4 numbers=9
add address=192.168.1.1/24 network=192.168.1.0 broadcast=192.168.1.255 interface=LAN
add address=10.10.10.1/29 network=10.10.10.0 broadcast=10.10.10.7 interface=WAN1
add address=10.10.20.1/29 network=10.10.20.0 broadcast=10.10.20.7 interface=WAN2
add address=10.10.30.1/29 network=10.10.30.0 broadcast=10.10.30.7 interface=WAN3
add address=10.10.40.1/29 network=10.10.40.0 broadcast=10.10.40.7 interface=WAN4
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_Connection
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_Connection
add chain=input in-interface=WAN3 action=mark-connection new-connection-mark=WAN3_Connection
add chain=input in-interface=WAN4 action=mark-connection new-connection-mark=WAN4_Connection
add chain=output connection-mark=WAN1_Connection action=mark-routing new-routing-mark=Route_To_WAN1
add chain=output connection-mark=WAN2_Connection action=mark-routing new-routing-mark=Route_To_WAN2
add chain=output connection-mark=WAN3_Connection action=mark-routing new-routing-mark=Route_To_WAN3
add chain=output connection-mark=WAN4_Connection action=mark-routing new-routing-mark=Route_To_WAN4
add chain=prerouting in-interface=LAN dst-address=10.10.20.0/29 action=accept
add chain=prerouting in-interface=LAN dst-address=10.10.30.0/29 action=accept
add chain=prerouting in-interface=LAN dst-address=10.10.40.0/29 action=accept
add chain=prerouting in-interface=LAN dst-address=10.10.50.0/29 action=accept
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/0 action=mark-connection new-connection-mark=WAN1_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/1 action=mark-connection new-connection-mark=WAN1_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/2 action=mark-connection new-connection-mark=WAN1_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/3 action=mark-connection new-connection-mark=WAN1_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/4 action=mark-connection new-connection-mark=WAN2_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/5 action=mark-connection new-connection-mark=WAN2_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/6 action=mark-connection new-connection-mark=WAN2_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/7 action=mark-connection new-connection-mark=WAN2_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/8 action=mark-connection new-connection-mark=WAN3_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/9 action=mark-connection new-connection-mark=WAN3_Connection passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=LAN per-connection-classifier=both-addresses-and-ports:11/10 action=mark-connection new-connection-mark=WAN4_Connection passthrough=yes
add chain=prerouting connection-mark=WAN1_Connection in-interface=LAN action=mark-routing new-routing-mark=Route_To_WAN1
add chain=prerouting connection-mark=WAN2_Connection in-interface=LAN action=mark-routing new-routing-mark=Route_To_WAN2
add chain=prerouting connection-mark=WAN3_Connection in-interface=LAN action=mark-routing new-routing-mark=Route_To_WAN3
add chain=prerouting connection-mark=WAN4_Connection in-interface=LAN action=mark-routing new-routing-mark=Route_To_WAN4
add dst-address=0.0.0.0/0 routing-mark=Route_To_WAN1 gateway=10.10.10.6 check-gateway=ping
add dst-address=0.0.0.0/0 routing-mark=Route_To_WAN2 gateway=10.10.20.6 check-gateway=ping
add dst-address=0.0.0.0/0 routing-mark=Route_To_WAN3 gateway=10.10.30.6 check-gateway=ping
add dst-address=0.0.0.0/0 routing-mark=Route_To_WAN4 gateway=10.10.40.6 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.10.10.6 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.10.20.6 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.10.30.6 distance=3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.10.40.6 distance=4 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=srcnat out-interface=WAN3 action=masquerade
add chain=srcnat out-interface=WAN4 action=masquerade[code2=ros][/code2]
