Greetings everybody, i’m new user in this mikrotik routerOS, i met a verry persisting problem concerning pcc load balancing, briefly my hardware and software features are :
Hardware
Pc containes INTEL 3Ghz of CPU ,2 GB of RAM, 750 GB of HDD…
Operating System
Mikrotik routerOS v 5.18
Network
-The main internet connexion shared by 45 users in LAN
5 wan links with 8 Mbits/s for each ,2 out of 5 are Ethernet links and the 3 others are Wireless ATHEROS AR 9 links coming from modems.
Method used
I used the method of PCC LoadBalancing.
Persisting Problem
I already used this method, everything is well setted and users are well connecting but I have noticed that when I open the WINBOX i find the interfaces never reach the maximum debit expected,as for interface WAN1 with 8 Mbits/s that normally recieves the same as 8 Mbits/s or less a bit, doesn’t seize the maximum of its real debit and it is the same as for the 4 remaining WANS which normally gives the total 40 Mbits/s of transmitted to all users thus this problem affects the users while surfing or dowloading , I have to tell you also that this 40 mbts/s doesn’t even reach 24 Mbits/s, hereby I seek from you a practical solution to this persisting problem which I need to understand whether on the level of hardware that lacks a good physical setting that needed to be changed or is there any trick that I must add to PCC loadbalancing that will allow each interface to seize its maximum debit.
Ex : while downloading a video from youtube using internet download manager, the rate of transffering doesn’t exceed the rate of 3.2 Mo/s using the same previosuly setting already mentioned.
Hi, I have the same problem, I have 8 dsl lines coming into a RB493AH, each DSL line is 10Mb, total bandwtidh never reachs above 30Mb. Maybe thats how PCC works.
Have you verified you DSL line quality separately by putting it directly to PC and then do some test downloads and check the results?
If the lines are ok and you are able to download at full capacity on each WAN in testing, then do this for testing. Install IDM in your test PC, and download multiple 5-10 big files (Like ISO files , ubuntu images etc from reliable sources) using IDM and then post the WAN output result.
greetings,
I have done tests for each line seperately, i found the bandwith is good 8 Mbit/s, for the second stage I have replug them in the Mikrotik router and I have let multiple downloads from good resources (youtube…ect) I found that the total rate of download doesn’t exceed 3 Mo/s with internet download manager, so it is still the same problem which persists so I doubt that the PCC is not well functioning, I wish this problem will be solved soon.
