Hello.
I have a problem with policy routing
This is the router configuration:
add interface=ether1 address=200.10.x.2/24
add interface=ether2 address=200.20.x.2/24
add dst-address=0.0.0.0/0 gateway=200.10.x.1 pref-src=200.10.x.2
add dst-address=0.0.0.0/0 gateway=200.20.x.1 pref-src=200.20.x.2 routing-mark=policy
/ip firewall mangle
add chain=output action=mark-routing new-routing-mark=policy src-address=200.20.x.2
When the default route 200.10.x.1 is disabled, I have no connection to the router using 200.20.x.2.
Why the policy routing doesn’t work?
Thanks in advance.
cupis
February 15, 2013, 9:18pm
2
harryenlared:
/ip firewall mangle
You need to mark your traffic from 200.100.x.x/24 as having routing-mark “policy” otherwise it will not be allowed to use the second default route. Your mangle rule above will not do that, by the time you get to “output” it is too late to make this decision.
Something like:
/ip firewall mangle add chain=prerouting src-address=200.20.x.x/24 action=mark-routing new-routing-mark=policy
Thank you for your reply.
The prerouting rule works for forwarded packages, but I need to enter into the router:
e.g.: ssh 200.20.x.2
This is something like this:
—> input ----> Local process —> Output ----> Routing adjustment —> Routing decision —>
You can see in http://wiki.mikrotik.com/wiki/Manual:Packet_Flow#Automated_processes_and_decisions
“Routing adjustment: this is a workaround that allows to set-up policy routing in mangle chain output”
So, routing adjustment seems not to work in my configuration.
cupis
February 17, 2013, 3:58pm
4
And this doesn’t work when the main link is down, correct?
If so, add something like this:
/ip firewall mangle add chain=input interface=ether2 action=mark-connection new-connection-mark=policy
This will mark any traffic coming into the router on ether2, on the input chain (i.e. traffic to 200.20.x.2 specifically) so that it will use the second default route to send return traffic. I don’t have a device handy I can test this on at the moment, but that may resolve the issue for you.
miahac
October 21, 2015, 3:05am
5
I am having the same problem with packets initiated from the router i.e. l2tp connections. Did you find an answer?
http://forum.mikrotik.com/t/send-l2tp-over-secondary-wan-isp-100-bounty-moved/91934/1
