Hello ![]()
i have a problem with nagios plugin called NRPE for monitorng my LINUX SERVER. this plugin listen to port 5666..
and here’s my setup for now
INTERNET ==> ADSL MODEM ==Bridge==> MIKROTIK ==192.168.100.77==> LINUX SERVER
and the firewall setup for open port 5666
/ip firewall nat chain=dstnat action=dst-nat to-addresses=192.168.100.77 protocol=tcp
dst-address-list=public dst-port=5666
note : the public address list is update using script, and the script always delete the old IP, so in the public address list only have one IP Public.
the allow host on nrpe.cfg is already set
check_nrpe using localhost is working
and the problem is, everytime i use check_nrpe on my server (which is a dedicated server and have static IP Address) check NRPE will give me this error message
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
any help will be appreciated. thank you
