Problem with port forwarding
Hello. I have a problem on a device:
I configured a nat-nat dst port 3389 for remote desktop.
In the event that I want at this point to connect an external connection to the server I have no problems and there I reach.
The problem to me is inversely namely:
if you want to access from under my network to a remote desktop devices, it does not make me leave. As soon as I disable the rule in the firwall mikrotik, I can do remote desktop outside of my network, but I no longer get into my server from outside. Could you help?
General hint: If you want to get help, provide as much info as possible. If you created a rule and it’s not doing what you expected, you have to tell us the exact rule. We are not mind readers, but I will try anyway. :slight_smile:
In this case, your rule is most likely too broad and catches all connections to port 3389, no matter what their destination is. In other words, you probably have:
add chain=dstnat protocol=tcp dst-port=3389 \
  to-addresses=<server IP> action=dst-nat
But you need one of the following (there are slight differences/limitations/side effects, but all three rules do basically the same thing):
add chain=dstnat protocol=tcp dst-port=3389 dst-address=<WAN IP> \
add chain=dstnat protocol=tcp dst-port=3389 in-interface=<WAN interface> \
  to-addresses=<server address> action=dst-nat
add chain=dstnat protocol=tcp dst-port=3389 dst-address-type=local \
