Problem With PPPoE and D-link 520+
Hi i have some problem with my PPP everything is Fine but only Hotmail.com and Camera in Msn messenger doesn’t work i dont know where is EXACTLY problem with Senao Brigde + PPP work very good but only with D-LINK 520+ Wireless Card + PPP hotmail and Camera in Msn Messenger doesnt work can anyone tell me whats the problem tanx for everything.
By Yllix
Check the history of this forum there are a lot reply of this problem
Change the MTU.
Check the faq
from the manual
I cannot surf some sites when I use PPPoE.
Use /ip firewall mangle to change MSS (maximum segment size) to a value less 40 bytes your connection MTU. For example, if you have encrypted PPPoE link with MTU=1492, set the mangle rule as follows:
/ ip firewall mangle
add chain=forward protocol=tcp tcp-flags=syn action=change-mss new-mss=1448
Maximiliano Dobladez
Intercity SRL
Wireless Internet Service Provider
the biggest canopys implementation of sudamerica.
http://www.intercity.net.ar
