sorry re-post, because there is no answer in wireless category..
FYI: I already try the MikroTik 2.9.2, MikroTik 2.9.6, MikroTik 2.9.8 and MikroTik 2.9.10 but i still got the problem. Evaluation.
below is the log of MikroTik that i tested via wireless when i try to dial the PPPoE server from my laptop..
The PCMCIA Wireless MAC: STA 1 00:09:5B:0D:E9:83 associated 43% 26
11
don't worry about the signal (43%), average is more than 80% because the Access Point (as Bridge) just 1-2 meters to the laptop.
Connect Wireless
Jan 10 21:07:34 192.168.1.100 : sent LCP EchoReq id=0x0
Jan 10 21:07:34 192.168.1.100 : rcvd LCP EchoRep id=0x0
Jan 10 21:07:36 192.168.1.100 pppoe,debug,packet local: rcvd PADI from 00:09:5B:0D:E9:83
Jan 10 21:07:36 192.168.1.100 pppoe,debug,packet session-id=0x0000
Jan 10 21:07:36 192.168.1.100 pppoe,debug,packet service name=radius
Jan 10 21:07:36 192.168.1.100 pppoe,debug,packet host-uniq=15 00 00 00 29 00 00 00
Jan 10 21:07:36 192.168.1.100 pppoe,debug,packet local: sent PADO to 00:09:5B:0D:E9:83
Jan 10 21:07:36 192.168.1.100 pppoe,debug,packet ac-name=MikroTik
Jan 10 21:07:36 192.168.1.100 pppoe,debug,packet service-name=radius
--end of log--
the log just stop at there
from my investigation there is no rcvd PADR and so on.
below is the log of MikroTik that i tested via wire (UTP) when i try to dial the PPPoE server from PC (Laptop is no problem too but i don't log it). This is log of dial from PC and it's success.
Connect Wired
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet local: rcvd PADI from 00:0D:87:C7:13:81
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet session-id=0x0000
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet service name=radius
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet host-uniq=0f 00 00 00 1b 00 00 00
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet local: sent PADO to 00:0D:87:C7:13:81
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet ac-name=MikroTik
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet local: rcvd PADR from 00:0D:87:C7:13:81
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet host-uniq=0f 00 00 00 1c 00 00 00
Jan 10 21:07:04 192.168.1.100 pppoe,info PPPoE connection established from 00:0D:87:C7:13:81
Jan 10 21:07:04 192.168.1.100 : PPP started
Jan 10 21:07:04 192.168.1.100 : waiting for call...
Jan 10 21:07:04 192.168.1.100 : PPP connected
Jan 10 21:07:04 192.168.1.100 : LCP lowerup
Jan 10 21:07:04 192.168.1.100 : LCP open
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet local: sent PADS to 00:0D:87:C7:13:81
Jan 10 21:07:04 192.168.1.100 pppoe,debug,packet session-id=0x0c00
Jan 10 21:07:04 192.168.1.100 : rcvd LCP ConfReq id=0x0
Jan 10 21:07:04 192.168.1.100 <000c>: sent LCP ConfReq id=0x1
Jan 10 21:07:04 192.168.1.100 : sent LCP ConfRej id=0x0
Jan 10 21:07:04 192.168.1.100 <000c>: rcvd LCP ConfAck id=0x1
Jan 10 21:07:04 192.168.1.100 : rcvd LCP ConfReq id=0x1
Jan 10 21:07:04 192.168.1.100 : sent LCP ConfAck id=0x1
Jan 10 21:07:04 192.168.1.100 : LCP opened
Jan 10 21:07:04 192.168.1.100 : sent CHAP Challenge id=0x1
Jan 10 21:07:04 192.168.1.100 : rcvd LCP Ident id=0x2
Jan 10 21:07:04 192.168.1.100 pppoe,ppp,debug,packet MSRASV5.10
Jan 10 21:07:04 192.168.1.100 : rcvd LCP Ident id=0x3
Jan 10 21:07:04 192.168.1.100 pppoe,ppp,debug,packet MSRAS-0 HOKAGE
Jan 10 21:07:04 192.168.1.100 : rcvd CHAP Response id=0x1
Jan 10 21:07:04 192.168.1.100 : PPP interface name is
Jan 10 21:07:04 192.168.1.100 : PPP authenticated
Jan 10 21:07:04 192.168.1.100 : sent CHAP Success id=0x1
Jan 10 21:07:04 192.168.1.100 pppoe,ppp,debug,packet S=FED912C099E3634E3A134BB3BF9A93F1A058F06C
Jan 10 21:07:04 192.168.1.100 : authenticated
Jan 10 21:07:04 192.168.1.100 : IPCP lowerup
Jan 10 21:07:04 192.168.1.100 : IPCP open
Jan 10 21:07:04 192.168.1.100 : sent IPCP ConfReq id=0x1
Jan 10 21:07:04 192.168.1.100 : CCP lowerup
Jan 10 21:07:04 192.168.1.100 : CCP open
Jan 10 21:07:04 192.168.1.100 : sent CCP ConfReq id=0x1
Jan 10 21:07:04 192.168.1.100 : rcvd CCP ConfReq id=0x4
Jan 10 21:07:04 192.168.1.100 : sent CCP ConfNak id=0x4
Jan 10 21:07:04 192.168.1.100 : rcvd IPCP ConfReq id=0x5
Jan 10 21:07:04 192.168.1.100 : sent IPCP ConfRej id=0x5
Jan 10 21:07:04 192.168.1.100 : rcvd IPCP ConfAck id=0x1
Jan 10 21:07:04 192.168.1.100 : rcvd CCP ConfNak id=0x1
Jan 10 21:07:04 192.168.1.100 : sent CCP ConfReq id=0x2
Jan 10 21:07:04 192.168.1.100 : rcvd CCP ConfReq id=0x6
Jan 10 21:07:04 192.168.1.100 : sent CCP ConfAck id=0x6
Jan 10 21:07:04 192.168.1.100 : rcvd IPCP ConfReq id=0x7
Jan 10 21:07:04 192.168.1.100 : sent IPCP ConfNak id=0x7
Jan 10 21:07:04 192.168.1.100 : rcvd CCP ConfAck id=0x2
Jan 10 21:07:04 192.168.1.100 : CCP opened
Jan 10 21:07:04 192.168.1.100 : using encoding - MPPE128 statefull
Jan 10 21:07:04 192.168.1.100 : rcvd IPCP ConfReq id=0x8
Jan 10 21:07:04 192.168.1.100 : sent IPCP ConfAck id=0x8
Jan 10 21:07:04 192.168.1.100 : IPCP opened
Jan 10 21:07:04 192.168.1.100 : connected
Jan 10 21:07:04 192.168.1.100 pppoe,ppp,info,account skripsi logged in, 192.168.5.254
I create PPPoE Server under MikroTik then integrate it with FreeRADIUS 1 0.1 for AAA and use MySQL as RADIUS database, i test it with wire and wireless.
There is DHCP Server in MikroTik, so client must get DHCP IP before dial to PPPoE Server.
I use :
switch Compex DS2216
access point Compex WPE54G ( http://tinyurl.com/d3b62 )
pcmcia NetGear MA401 ( http://tinyurl.com/9q84p )
The topology is :
Internet
Internet Gateway (192.168.1.1/24)
(Internet Connection Sharing on Windows XP)
HUB -- My Neighbor PC (192.168.1.11/24)
| FreeRADIUS (192.168.1.200/24)
MikroTik (192.168.1.100/24) & (192.168.2.1/24)
Switch -- PC 1
/ Access Point
PC 2 Laptop
On PC 1, PC 2, Laptop already get DHCP IP from DHCP Server
(192.168.2.1), so:
PC 1 (192.168.3.10/29)
PC 2 (192.168.3.11/29)
Laptop (192.168.3.12/29)
I already setup the PPPoE Dial-Up Connection to PC 1, PC 2, and Laptop. I'm very sure PPPoE configuration in PC 1, PC 2, and Laptop already correct!!
Then i test the PPPoE Connection from PC 1 and PC 2, and it's working well! So PC 1 and PC 2 have two IP (from DHCP Server and PPPoE Server)
PC 1 (192.168.5.10/32)
PC 2 (192.168.5.11/32)
both can get access to the Internet (i test those with ping http://www.google.com and get reply).
But problem with the Laptop if on wireless, for your information the Laptop have onboard ethernet interface (wire), then i connect it to the switch, then the DHCP and PPPoE are working well! The problem is when i try use wireless, the laptop is already get the DHCP IP from DHCP Server (MikroTik) via wireless, but when i try to dial to PPPoE Server, there is an error: Error 676 Phone line is busy
I try google and found no solution for this problem (http://tinyurl.com/7qge4)
The facts are:
- From laptop i can connect to DHCP Server and PPPoE Server via wire.
- From laptop i can connect to DHCP Server, but can not connect to PPPoE Server via wireless.
- Then i bring my laptop tp my friend ISP and test it, i try connect to his Access Point, MikroTik and Radius Server, then not get any problem. So, i think there is no problem with pcmcia wireless NetGear.
I can't test too much to his ISP ![]()
I believe there are no problem with PPPoE Server (MikroTik) and RADIUS Server,.. I already set the Access Point type as "Access Point as Bridge" that's why i can get the DHCP IP from DHCP Server (MikroTik).
where is the problem?? please help me..
thank you so much!
