i am trying to use the mikrotik router to connect to german t-dsl-line (german telekom and strato) but cant get it to work.
both providers use long usernames with special characters e.g.
STRATO/001234XYZ0000012345678%STRATODSL
i configured a pppoe-out interface on an ethernet-port connected to an standard ethernet dsl-modem (teledat lan 430). on the pppoe-out interface i configured username and password and bound the pppoe-out interface to the ethernet-port connected to the modem.
the pppoe dials out, got connection to the access-concentrator (status shows name and MAC-address) but disconnects then, probably due to an authentication failure. i can see short traffic peeks (tx and rx) on the ethernet-port to the modem, too.
is there a way to see the pppoe handshaking and error messages?
is anyone running a mikrotik router on a t-dsl line/isp?
(i tested the line and user data with another router, everything is working)
meanwhile i wrote to mikrotik support and they were very helpful, but the problem could not be solved yet.
i did some further tests: set up an mikrotik router os (2.8.15) based PPPoE-server and tried to log in from a unix machine (macos x) using built-in PPPoE-client.
mt config, ppp users 1 and 2 are similar, besides the username:
user 1 can not log in with an authentication failure, but user 2 can!
so my question: could it possibly be, that the username-string is just too short, and might this be the same with the PPPoE-client username-string too?
the special characters “/” and “%” seemed to be working:-)
I am interested in any solutions too. I recently moved to Germany and am in the process of getting my Mikrotik box up and running. I guess one option would be to have a linksys or dlink router handle the pppoe and forward all ports to the Mikrotik. I would prefer not to go this way though.
(i got a test package from support and everything is now working!
we did this to of course, but it was much to complicated (to expensive and we have poor pppoe-results using the small linksys). another way would be using a dsl-modem with build-in pppoe (e.g. LG), but like to use the MT itself.
