it is working nice betwin MT to MT but not winxp to mt im geting error 619 on my win clients!!!
any one having the same problem
No. Works fine for me. Posting your configuration might yield some clues.
Regards
Andrew
here are my config of the pptp server.
regards
/ interface pptp-server server
set enabled=yes max-mtu=1460 max-mru=1460
authentication=pap,chap,mschap1,mschap2 keepalive-timeout=30
default-profile=default
/ ppp profile
set default name=“default” use-compression=default use-vj-compression=default
use-encryption=yes only-one=default change-tcp-mss=yes comment=“”
set default-encryption name=“default-encryption” local-address=0.0.0.0
remote-address=public use-compression=default use-vj-compression=default
use-encryption=yes only-one=default change-tcp-mss=default comment=“”
/ ppp secret
add name=“larre” service=any caller-id=“” password=“x” profile=default
local-address=10.106.0.1 remote-address=10.106.0.2 routes=“”
limit-bytes-in=0 limit-bytes-out=0 comment=“” disabled=no
Some differences in our configuration:
Local-address is set to the IP of the internal interface on the MT PPTP server. Use a dhcp pool for remote addresses. These addresses should be valid for your internal network.
/ppp profile
name=“default” local-address=192.168.1.253 remote-address=pptp_pool
use-compression=no use-vj-compression=no use-encryption=required
only-one=no change-tcp-mss=no dns-server=192.168.1.253
Don’t define addresses in ppp secret. Leave them as 0.0.0.0, that way DHCP is used for the remote address.
Having said that it works for me I’ve just remembered that I’m still using 2.9.8 which isn’t exactly what you asked for. Configuration will be the same though.
Regards
Andrew
The problem started with the upgrade to 2.9.10 from 2.9.8!!! I have now tested your config and it is NOT working on a 2.9.10!!! i think we have a real BUGG!!!
regards Leo
Just upgraded from 2.9.8 to 2.9.10 but it’s going to be a few days before I can test this.
Best send a supout file to MT support.
Regards
Andrew
Als upgrade from 2.9.8 to 2.9.10 and i have no problems here so far.
Im only using one pptp client at the moment ( WinXP Professional) to reach my internal network behind the mt box from outside.
I do how ever have a drop connection error on mij pptp client and on mij ADSL Connection but this problem was also there in 2.9.8
my mt are working now to and i havent done anything at all?!!!?
and i have the same problem as you with my adsl line but in my cace it is the adsl line that are the problem, i have drop outs eaven if i connect directly to my modem with my computer.
regards leo
hmmm maybe this is the problem with me to, but i`m not home these days so i cannot check this. The strange thing is that is only goes wrong when vpn clients are connected. im running a syslog deamon on another box for now that logs pptp and ppp messages but i cannot find errors. Only messages that the vpn client (winXP) connected is not responding. The speedtouch 716 modem is only reporting pptp connection openen and clossed but it also does this when i manualy drop the link. Its a dutch dsl link
The link is running for 19 hours now, and there are no clients connected
Had this problem today with 2.9.8. The only difference today was that I was running an NMAP scan on a remote system so had a large (very large) number of connections on the router. I wonder if this is related to connection tracking.
Once the scan had finished I could log back in again.
Regards
Andrew
I was downloading some stuff from my ftp server today and saw that the connection was lost (download fails/stops)
But this time i got a syslog report: Maybe some one find the error ??
The 10.0.0.138 is my Thomson Speedtouch 716 Modem.
The 10.0.0.150 is the MT WAN Interface
The 192.168.100.250 is MT LAN interface
7-4 XS4ALL-ADSL is the PPTP dial up thru the modem to the provider xs4all.nl
2006-01-05 13:52:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: rcvd Echo-Request from 10.0.0.138
2006-01-05 13:52:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: identifier=2251
2006-01-05 13:52:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: sent Echo-Reply to 10.0.0.138
2006-01-05 13:52:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: result-code=1
2006-01-05 13:52:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: error-code=0
2006-01-05 13:53:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: rcvd Echo-Request from 10.0.0.138
2006-01-05 13:53:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: identifier=2252
2006-01-05 13:53:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: sent Echo-Reply to 10.0.0.138
2006-01-05 13:53:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: result-code=1
2006-01-05 13:53:09 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: error-code=0
2006-01-05 13:53:13 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP EchoReq id=0x0
2006-01-05 13:53:13 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x7d5e18f8>
2006-01-05 13:53:14 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd LCP ConfReq id=0x1
2006-01-05 13:53:14 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0xf7ce675e>
2006-01-05 13:53:14 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP received dup ConfReq
2006-01-05 13:53:14 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP ConfAck id=0x1
2006-01-05 13:53:15 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP missed echo reply
2006-01-05 13:53:15 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP EchoReq id=0x1
2006-01-05 13:53:15 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x7d5e18f8>
2006-01-05 13:53:16 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP missed echo reply
2006-01-05 13:53:16 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP EchoReq id=0x2
2006-01-05 13:53:16 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x7d5e18f8>
2006-01-05 13:53:17 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP missed echo reply
2006-01-05 13:53:17 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP EchoReq id=0x3
2006-01-05 13:53:17 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x7d5e18f8>
2006-01-05 13:53:18 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP missed echo reply
2006-01-05 13:53:18 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP EchoReq id=0x4
2006-01-05 13:53:18 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x7d5e18f8>
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP missed echo reply
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP lowerdown
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP closed
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: CCP lowerdown
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: IPCP lowerdown
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: IPCP closed
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP down event in initial state
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,info xs4all: 7-4 XS4ALL-ADSL: terminating… - peer is not responding
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: PPP disconnected <>
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: PPP stopped
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,info xs4all: 7-4 XS4ALL-ADSL: disconnected
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: CCP down event in starting state
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: IPCP down event in starting state
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,info xs4all: 7-4 XS4ALL-ADSL: initializing…
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: PPP started
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,info xs4all: 7-4 XS4ALL-ADSL: dialing…
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: sent Start-Control-Connection-Request to 10.0.0.138
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: protocol-version=0x0100
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: framing-capabilities=2
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: bearer-capabilities=0
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: maximum-channels=0
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: firmware-revision=1
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: host-name=VuurMuur.van-der-meijden
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: vendor-name=MikroTik
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: rcvd Start-Control-Connection-Reply from 10.0.0.138
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: result-code=1
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: error-code=0
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: framing-capabilities=3
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: bearer-capabilities=3
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: maximum-channels=32
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: host-name=SpeedTouch
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: vendor-name=THOMSON
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: sent Outgoing-Call-Request to 10.0.0.138
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: call-id=1
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: call-serial-number=1
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: minimum-bps=2400
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: maximum-bps=10000000
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: bearer-type=3
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: framing-type=2
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: packet-recv-window-size=100
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: packet-processing-delay=0
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: phone-number-length=0
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: phone-number=
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: subaddress=
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: rcvd Outgoing-Call-Reply from 10.0.0.138
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: call-id=0
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: peers-call-id=1
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: cause-code=0
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: connect-speed=0
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: packet-recv-window-size=8
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: physical-channel-id=0
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: PPP connected
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP lowerup
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP open
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP ConfReq id=0x16
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <mru 1460>
2006-01-05 13:53:19 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x9daf632>
2006-01-05 13:53:20 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP timer
2006-01-05 13:53:20 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP ConfReq id=0x17
2006-01-05 13:53:20 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <mru 1460>
2006-01-05 13:53:20 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x9daf632>
2006-01-05 13:53:20 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd LCP ConfNak id=0x17
2006-01-05 13:53:20 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <mru 1500>
2006-01-05 13:53:20 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP ConfReq id=0x18
2006-01-05 13:53:20 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd LCP ConfAck id=0x18
2006-01-05 13:53:21 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP timer
2006-01-05 13:53:21 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP ConfReq id=0x19
2006-01-05 13:53:21 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x9daf632>
2006-01-05 13:53:21 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd LCP ConfAck id=0x19
2006-01-05 13:53:22 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP timer
2006-01-05 13:53:22 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP ConfReq id=0x1a
2006-01-05 13:53:22 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x9daf632>
2006-01-05 13:53:22 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd LCP ConfAck id=0x1a
2006-01-05 13:53:23 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP timer
2006-01-05 13:53:23 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP ConfReq id=0x1b
2006-01-05 13:53:23 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x9daf632>
2006-01-05 13:53:23 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd LCP ConfAck id=0x1b
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd LCP ConfReq id=0x3
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0xf7ce675e>
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP ConfAck id=0x3
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: LCP opened
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent PAP AuthReq id=0xa
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <user XXXXXXX@xs4all.nl>
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd PAP AuthAck id=0xa
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,info xs4all: 7-4 XS4ALL-ADSL: authenticated
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: IPCP lowerup
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent IPCP ConfReq id=0xf
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <addr 0.0.0.0>
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: IPCP open
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: CCP lowerup
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: CCP open
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd IPCP ConfReq id=0x1
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <addr 195.190.249.22>
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent IPCP ConfAck id=0x1
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd IPCP ConfNak id=0xf
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <addr 80.126.250.177>
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent IPCP ConfReq id=0x10
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd IPCP ConfAck id=0x10
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,debug xs4all: 7-4 XS4ALL-ADSL: IPCP opened
2006-01-05 13:53:24 Local7.Debug 192.168.100.250 pptp,ppp,info xs4all: 7-4 XS4ALL-ADSL: connected
2006-01-05 13:53:25 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: rcvd LCP EchoReq id=0x1
2006-01-05 13:53:25 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0xf7ce675e>
2006-01-05 13:53:25 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 32 f6 da 09
2006-01-05 13:53:25 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: 7-4 XS4ALL-ADSL: sent LCP EchoRep id=0x1
2006-01-05 13:53:25 Local7.Debug 192.168.100.250 pptp,ppp,debug,packet xs4all: <magic 0x9daf632>
2006-01-05 13:54:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: rcvd Echo-Request from 10.0.0.138
2006-01-05 13:54:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: identifier=1
2006-01-05 13:54:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: sent Echo-Reply to 10.0.0.138
2006-01-05 13:54:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: result-code=1
2006-01-05 13:54:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: error-code=0
2006-01-05 13:55:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: rcvd Echo-Request from 10.0.0.138
2006-01-05 13:55:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: identifier=2
2006-01-05 13:55:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: sent Echo-Reply to 10.0.0.138
2006-01-05 13:55:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: result-code=1
2006-01-05 13:55:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: error-code=0
2006-01-05 13:56:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: rcvd Echo-Request from 10.0.0.138
2006-01-05 13:56:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: identifier=3
2006-01-05 13:56:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: sent Echo-Reply to 10.0.0.138
2006-01-05 13:56:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: result-code=1
2006-01-05 13:56:19 Local7.Debug 192.168.100.250 pptp,debug,packet xs4all: error-code=0
