Hi there,
I have set up my Mikrotik as a PPTP client to connect to a Draytek router (couldn’t get IPSec to work, will try again sometime later). The Draytek has the internal IP 192.168.2.1.
What I did so far:
- Set routing mark for packets with destination 192.168.2.0/24.
Chain: prerouting; Dst. Address: 192.168.2.0/24; Action: mark routing; New Routing Mark: Draytek; Passthrough: Off. It’s the first rule on the Mangle tab. - Create route:
Dst. Address: 192.168.2.0/24; Gateway: the PPTP connection; Type: unicast; Distance: 1; Scope: 30; Target Scope: 10; Routing Mark: Draytek
Everything works fine with the standard masquerade NAT rule.
To turn off NAT for traffic between my internal network and the internal network of the remote network I created the following NAT rule:
Chain: srcnat; Dst. Address: 192.168.2.0/24; Action: accept. It’s the first rule.
As soon as I turn on this rule no traffic between the networks will flow anymore. Action: return doesn’t work either. What am I doing wrong?
Thanks in advance,
iBlueDragon
