Hi
I have a problem with the login to winbox when I use my radius server.
There is a pc running windows 2k3 and on it there is a radius server as far every thing works fine.
When I uninstalled winradius and I insalleed IAS connected with active directory I had the above problem:
When I enter a wrong username/password I get a response from radius server “access-reject”
But as soon as I enter the right password then the radius server doesn’t respond
The problem is established only when trying to login to mikrotik either by winbox or by telnet.
For example in pptp (vpn) the authentication is running properly through the IAS
Do you know any possible solution to my problem??
