Help me. I have a big problem for me. I was type in terminal of my routerboard 3.30 “/system routerboard upgrade”, and now, my RB411U doesn’t turn up. The led on RJ45 PoE conector, blinks in green, and LD501, 502,503,504 and 505, doesn’t light, and don’t beep after 5-10 seconds.
That could have happened?.
There are a video thats show my problem:
http://www.youtube.com/watch?v=G79opeOudrI
Thanks.
fewi
March 8, 2011, 9:57pm
2
What does the console port say when you reboot by removing power and plugging power back in?
Sorry, but i don’t understand your question.
Thanks.
fewi
March 8, 2011, 10:11pm
4
Connect a serial cable to the serial port on the board: http://wiki.mikrotik.com/wiki/Manual:First_time_startup#Serial_Cable
Then boot the board. What output does the serial console show?
This is the data of screen:
RouterBOOT booter 2.20
RouterBoard 411U
CPU frequency: 300MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
kernetl not found
trying bootp protocol…failed
kernel loading failed
And this is all. Loop, loop, but my RB doesn’t boot.
Thanks.
fewi
March 8, 2011, 11:22pm
6
Thanks fewi. Their response has been helpful for me.
Thanks again.
janisk
March 9, 2011, 7:45am
8
perfect video of the board that tries to boot up from ethernet
there are 2 options - connect console and try to set it to boot from NAND and see if it boots up, or reinstall it using netinstall tool.
