Problem with RB750
Hi, I’m new to this forum and hope someone can assist me and also i’m not an expert in network. I’m upgrading my existing Linksys WRT54G2 to RB750 and i’m not able to connect to the internet. The Interface tab shows ether1-gateway Configuration in “Searching” state. I have some screenshot of my RB750 and appreciate if someone can assist me. Thanks
config.docx (875 KB)
what’s a docx file? I don’t use MS office products, why can’t you post screenshots in normal PNG or JPG format?
That’s an oxymoron. :slight_smile:
From your screenshots everything looks fine, but in your second screenshot the setting needs to be “Enabled”.
Also please go to terminal and post the output of
/ip addr pr
/ip route pr
/ip fire export
(In code tags please)
Thanks for the reply. I’ve tried to “enable” it but i still not able to connect to the internet.
This is my first time using the Mikrotik product and i’m not familiar with creating the code tag.
Appreciate if you could advice on this. I’m able to access Terminal mode through Winbox.
type these things into the console:
/ip addr pr
/ip route pr
/ip fire export
copy their outputs and paste them here. code tag was meant for forum, not RouterOS.
Here's the output and hoping to get my new RB750 working. Thanks
[admin@ccic-router] > /ip addr pr
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.138.188/24 192.168.138.0 192.168.138.255 ether2-local-master
1 D 124.106.31.56/32 124.107.109.254 0.0.0.0 pppoe-out1
[admin@ccic-router] > /ip route pr
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 ADS 0.0.0.0/0 reachable 124.107.109.254 1 pppoe-out1
1 ADC 124.107.109.254/32 124.106.31.56 0 pppoe-out1
2 ADC 192.168.138.0/24 192.168.138.188 0 ether2-local-master
[admin@ccic-router] > /ip fire export
feb/27/2010 03:29:11 by RouterOS 3.29
software id = IH35-9SC3
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s
tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established disabled=no
in-interface=ether1-gateway
add action=accept chain=input comment="default configuration" connection-state=related disabled=no in-interface=
ether1-gateway
add action=drop chain=input comment="default configuration" disabled=no in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=ether1-gateway
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1511 protocol=udp src-address=0.0.0.0
to-addresses=192.168.138.1 to-ports=1511
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1512 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.2 to-ports=1512
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1513 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.3 to-ports=1513
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1514 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.4 to-ports=1514
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1515 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.5 to-ports=1515
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1516 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.6 to-ports=1516
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1517 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.7 to-ports=1517
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1518 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.8 to-ports=1518
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1519 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.9 to-ports=1519
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1520 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.10 to-ports=1520
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1521 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.11 to-ports=1521
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1522 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.12 to-ports=1522
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1523 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.13 to-ports=1523
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1524 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.14 to-ports=1524
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1525 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.15 to-ports=1525
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1526 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.16 to-ports=1526
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1527 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.17 to-ports=1527
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1528 protocol=tcp src-address=0.0.0.0
to-addresses=192.168.138.18 to-ports=1528
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1512 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1513 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1514 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1515 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1516 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1517 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1518 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1519 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1520 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1521 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1522 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1523 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1524 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1525 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1526 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1527 protocol=udp src-address=0.0.0.0
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1528 protocol=udp src-address=0.0.0.0
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
Here is the output as u requested. Thanks :slight_smile:
ether1-gateway
In IP > Firewall > NAT:
That rule should be:
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=pppoe-out1
I have pppoe problem with same router except I do not have NAT.
It can connect with WRT54G2 over PPPoE on another provider, but can not connect to Mikrotik.
After “sniffing” the network here is the result
protocol: PPPoED
version… code… sessionId… payload length = 0c (12 decade).
Other routers… payload length = 10 (16 decade)
