Problem with redirect to www from LAN
Hey,
I have problem with redirect www server to port 80. From WAN it work fine, but from LAN I see mikrotik web page. I don’t have idea what change in config.
Mikrotik CCR1009-7g-1c-1s+
first try NAT
add action=dst-nat chain=dstnat comment=HTTP disabled=yes dst-port=80 in-interface=WAN protocol=tcp to-addresses=10.1.1.1 to-ports=80
second try:
add action=dst-nat chain=dstnat comment="HTTP 80" dst-address=78.11.111.114 dst-port=80 protocol=tcp to-addresses=10.1.1.1 to-ports=80
https://wiki.mikrotik.com/wiki/Hairpin_NAT
it’s still not working. I try:
add chain=dstnat dst-address=78.11.111.114 protocol=tcp dst-port=80 action=dst-nat to-address=10.1.1.1
add chain=srcnat out-interface=WAN action=masquerade
add chain=srcnat src-address=10.1.0.0/16 dst-address=10.1.1.1 protocol=tcp dst-port=80 out-interface=LAN action=masquerade
moreover I cant access to any other device via www interface
@Edit
What I doing wrong?
Help?
Maybe other way around. Do you use MikroTik as DNS server? or do you have internal DNS server? If yes why not add static address to cache and problem resolved. If you don’t have internal DNS server try create rule without src-address just port and destination IP of server, I have that way and it works fine.
I dont have DNS server, use google. Rule without src-address was first try, doesnt work… Any idea?
chain=dstnat action=dst-nat to-addresses=10.1.1.1 to-ports=80 protocol=tcp in-interface=WAN dst-port=80
bump
Your hairpin nat rule should look like this :
add action=dst-nat chain=dstnat comment=“hairpin nat” dst-address=!10.1.0.0/16 dst-address-type=local log=yes log-prefix=hairpin to-addresses=10.1.1.1
Regards,
Now I have:
add action=dst-nat chain=dstnat comment="hairpin nat" dst-address=!10.1.0.0/16 dst-address-type=local log=yes log-prefix=hairpin to-addresses=10.1.1.1
I can view www from wan but from local network web page is not reachalbe, its some change but still not what I want. I try to disable masqarade but no result.
Disable the first rule : add chain=dstnat dst-address=78.11.111.114 protocol=tcp dst-port=80 action=dst-nat to-address=10.1.1.1
Ant try from WAN and LAN.
I try only this:
I can’t reach from WAN and LAN
