Problem with ROS 7.1 and CAPSMAN / wireless
Dear all,
I have a Routerboard RB4011iGS+ and directly connected a wAP ac (RBwAPG-5HacT2HnD).
Routerboard hosts CAPSMAN as well as a hotspot - wAP is only used as “antenna”.
Both Boards using FW 6.49.2 (all other before also worked as well for nearly 2 years).
Now I updated both devices to ROS 7.1 - the wAP ac couldn’t connect to capsman anymore (logfiles told me about timeout).
I downgraded wAP ac back to 6.49.2 (RB4011 still 7.1) and it could connect to CAPSMAN immediatelly. Only the wireless internet connection drops after half a minute (I tested with my cellphone and started playback of a youtube video - it stuck after some minutes and the android wlan icon showed me no connection to internet (but still to wlan).
I also downgraded RB4011 to 6.49.2 and everything worked fine, just as before the upgrade - wlan & internet connection is stable.
I tested to upgrade wAP ac again to 7.1 (RB4011 still 6.49.2) and immediatelly no connection to CAPSMAN anymore - after downgrade it worked again.
I doesn’t change anything else in configuration - only upgrade and downgrade procedure. So I think there is still something broken.
(just to become weird - at home I use also an wAP ac and a CAPSMAN on a CHR running on VMWare ESXi - there the update worked without problems).
RB4011:
# dec/12/2021 15:12:28 by RouterOS 6.49.2
# software id = XXX
# model = RB4011iGS+
# serial number = XXX
/caps-man channel
add band=2ghz-g/n name=2GHz
add band=5ghz-a/n/ac extension-channel=Ce name=5GHz
add name="bridge - HotSpot"
add name=bridge_WLAN_APs
set [ find default-name=ether1 ] name="ether1 - XXX"
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] name="ether6 - Uplink Modem"
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] name="ether10 - wAP ac Marktplatz" \
    power-cycle-ping-address=172.16.0.10 power-cycle-ping-enabled=yes \
    power-cycle-ping-timeout=30m
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/caps-man datapath
add bridge="bridge - HotSpot" client-to-client-forwarding=no name=\
    Datapath_Bridge_HotSpot
/caps-man security
add name=free_wifi
/caps-man configuration
add channel=2GHz country=germany datapath=Datapath_Bridge_HotSpot \
    installation=outdoor mode=ap name=free_wifi_2GHz security=free_wifi ssid=\
    XXX
add channel=5GHz country=germany datapath=Datapath_Bridge_HotSpot \
    installation=outdoor mode=ap name=free_wifi_5GHz security=free_wifi ssid=\
    XXXXX
/caps-man interface
add configuration=free_wifi_2GHz disabled=no l2mtu=1600 mac-address=\
    XXX master-interface=none name=WLAN_Marktplatz1_2GHz \
    radio-mac=XXX radio-name=XXX
add configuration=free_wifi_5GHz disabled=no l2mtu=1600 mac-address=\
    XXX master-interface=none name=WLAN_Marktplatz1_5GHz \
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add name=Management_Interfaces
/ip hotspot profile
add dns-name=hotspot.atgl hotspot-address=172.20.0.1 html-directory=\
    hotspot_atgl http-cookie-lifetime=12h1m login-by=cookie,http-pap name=\
    HS_Marktplatz
/ip ipsec mode-config
add connection-mark=VPN_Pflicht name=NordVPN responder=no
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
add dh-group=modp8192,modp6144,modp4096,modp3072,modp2048 enc-algorithm=\
    aes-256,aes-192 hash-algorithm=sha512 name=NordVPN
/ip ipsec peer
add address=ch137.nordvpn.com disabled=yes exchange-mode=ike2 name=\
    NordVPN_Peer_2_Schweiz profile=NordVPN
add address=de1008.nordvpn.com exchange-mode=ike2 name=\
    NordVPN_Peer_1_Deutschland profile=NordVPN
add address=de743.nordvpn.com comment="Phase 1 IPSec zu NordVPN" disabled=yes \
    exchange-mode=ike2 name=NordVPN_Peer_Deutschland profile=NordVPN
/ip ipsec proposal
add auth-algorithms=sha512,sha256 enc-algorithms=aes-256-cbc,aes-192-cbc \
    name=NordVPN pfs-group=none
add name=hs-pool-12 ranges=172.20.0.2-172.20.15.254
add address-pool=hs-pool-12 disabled=no interface="bridge - HotSpot" \
    lease-time=1h name=dhcp1
/ip hotspot
add address-pool=hs-pool-12 disabled=no interface="bridge - HotSpot" name=\
    "HotSpot Marktplatz" profile=HS_Marktplatz
/ip hotspot user profile
add address-pool=hs-pool-12 mac-cookie-timeout=12h30m name=\
    Marktplatz_BenutzerProfil rate-limit=1000k/2500k shared-users=unlimited
/system logging action
set 3 bsd-syslog=yes remote=10.1.0.100
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
/caps-man access-list
add allow-signal-out-of-range=10s ap-tx-limit=70000 comment=\
    "XXX" disabled=no mac-address=\
    10:44:00:DC:88:D9 ssid-regexp=""
    00:18:41:0B:F3:4D ssid-regexp=""
add allow-signal-out-of-range=10s ap-tx-limit=100000 comment=\
    "Test Stefan S10 - Telefon-MAC" disabled=yes mac-address=\
    6C:C7:EC:AD:6C:C8 ssid-regexp=""
/caps-man manager
set ca-certificate="CapsMan Zertifikat CA" certificate="CapsMan Zertifikat" \
    enabled=yes require-peer-certificate=yes
/caps-man manager interface
add disabled=no interface=bridge_WLAN_APs
add bridge=bridge_WLAN_APs interface="ether10 - wAP ac Marktplatz"
/interface bridge settings
set use-ip-firewall=yes
set discover-interface-list=!Management_Interfaces
add interface="ether1 - XXX" list=Management_Interfaces
add address=172.20.0.1/20 interface="bridge - HotSpot" network=172.20.0.0
add address=172.16.0.1/24 interface=bridge_WLAN_APs network=172.16.0.0
/ip dhcp-client
add add-default-route=no !dhcp-options disabled=no interface=\
    "ether1 - XXX" use-peer-dns=no use-peer-ntp=no
add !dhcp-options disabled=no interface="ether6 - Uplink Modem"
add address=172.20.0.0/20 comment="hotspot network" gateway=172.20.0.1
set allow-remote-requests=yes
/ip firewall address-list
add address=10.28.30.1-10.28.30.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=private_IPs
add address=172.16.0.0/12 comment=RFC6890 list=private_IPs
add address=192.168.0.0/16 comment=RFC6890 list=private_IPs
add address=10.0.0.0/8 comment=RFC6890 list=private_IPs
add address=169.254.0.0/16 comment=RFC6890 list=private_IPs
add address=127.0.0.0/8 comment=RFC6890 list=private_IPs
add address=224.0.0.0/4 comment=Multicast list=private_IPs
add address=198.18.0.0/15 comment=RFC6890 list=private_IPs
add address=192.0.0.0/24 comment=RFC6890 list=private_IPs
add address=192.0.2.0/24 comment=RFC6890 list=private_IPs
add address=198.51.100.0/24 comment=RFC6890 list=private_IPs
add address=203.0.113.0/24 comment=RFC6890 list=private_IPs
add address=100.64.0.0/10 comment=RFC6890 list=private_IPs
add address=240.0.0.0/4 comment=RFC6890 list=private_IPs
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
    private_IPs
add address=172.20.0.0/20 list=HotSpot_Subnet
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
add action=drop chain=forward comment="Drop SMTP" dst-port=25 in-interface=\
    "bridge - HotSpot" protocol=tcp
add action=drop chain=forward comment="Drop invalid" connection-state=invalid \
    log-prefix=invalid
    "Established, Related - Antwortpakete zulassen" connection-state=\
    established,related
add action=drop chain=forward dst-address-list=private_IPs in-interface=\
    "bridge - HotSpot"
add action=accept chain=forward dst-address-list=!private_IPs in-interface=\
    "bridge - HotSpot"
add action=accept chain=forward in-interface="ether1 - XXX" \
    out-interface=bridge_WLAN_APs
add action=accept chain=forward comment="erlaubt NTP Client" dst-port=123 \
    in-interface=bridge_WLAN_APs protocol=udp
add action=accept chain=forward comment="diese Regel erlaubt Zugriff von WLAN_\
    APs zu anderen Netzen! (z.B. Updates)" disabled=yes in-interface=\
    bridge_WLAN_APs
add action=accept chain=forward comment="erlaubt Emailversand" dst-port=25 \
    in-interface=bridge_WLAN_APs protocol=tcp
add action=reject chain=forward in-interface="ether1 - XX" \
    reject-with=icmp-network-unreachable
add action=reject chain=forward in-interface="ether6 - Uplink Modem" \
add action=reject chain=forward reject-with=icmp-network-unreachable
add action=drop chain=input comment="Drop Winbox !ManagementInterface" \
    dst-port=8291 in-interface-list=!Management_Interfaces protocol=tcp
add action=drop chain=input comment="Drop SSH !ManagementInterface" dst-port=\
    2200 in-interface-list=!Management_Interfaces protocol=tcp
add action=accept chain=input in-interface="ether1 - X"
add action=accept chain=input dst-address=172.16.0.1 in-interface=\
    bridge_WLAN_APs
add action=accept chain=input dst-address=172.20.0.1 in-interface=\
    "bridge - HotSpot"
add action=accept chain=input connection-state=established,related
add action=accept chain=output comment=syslog dst-address=10.1.0.100 \
    dst-port=514 protocol=udp
/ip firewall mangle
add action=change-mss chain=forward comment="MTU Workaround f\FCr IPSec" \
    new-mss=1200 passthrough=yes protocol=tcp tcp-flags=syn tcp-mss=\
    1201-65535
add action=mark-connection chain=forward hotspot=from-client \
    new-connection-mark=VPN_Pflicht passthrough=yes
add action=masquerade chain=srcnat comment=\
    "masquerade hotspot network ; l\E4uft gegen IPSec" disabled=yes log=yes \
    log-prefix=MASQ src-address=172.20.0.0/20
add action=masquerade chain=srcnat src-address=172.16.0.0/24
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip hotspot user
add name=admin
add name=freewifi profile=Marktplatz_BenutzerProfil server=\
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=\
    port-strict mode-config=NordVPN peer=NordVPN_Peer_1_Deutschland \
    policy-template-group=NordVPN username=XXX
/ip ipsec policy
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=\
    0.0.0.0/0 template=yes
add distance=1 dst-address=10.1.0.100/32 gateway=192.168.56.254
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
/system identity
set name=MikroTik_Router_Marktplatz
/system logging
set 0 action=remote prefix=Mikrotik-Marktplatz
set 1 action=remote prefix=Mikrotik-Marktplatz
set 2 action=remote prefix=Mikrotik-Marktplatz
/system ntp client
set enabled=yes primary-ntp=192.53.103.108 secondary-ntp=192.53.103.104
/system scheduler
add interval=12h name=schedule1 on-event="Usage Report" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=mar/07/2020 start-time=09:00:00
add interval=2w name="Backup and Update" on-event=\
    "/system script run BackupAndUpdate;" policy=\
    start-date=dec/10/2021 start-time=01:00:00
/system script
add dont-require-permissions=no name="Usage Report" owner=st.wiessalla \
    policy=ftp,reboot,read,write,test,password,sniff,sensitive,romon source=":\
    local date ([:pick [/system clock get date] 0 3] [:pick [/system clock get\
    \_date] 4 6] [:pick [/system clock get date] 7 11]);\r\
    \n:local fileName (.\$date.\"Usage Report.txt\")\r\
    \n:local logger [/log warning message=\"Creating Usage Report\"]\r\
    \n:local usage [/ip hotspot user print bytes file=\"\$fileName\"]\r\
    \n:local contents [/file get \$fileName contents]\r\
    \n:local usage [/ip hotspot cookie print file=\"\$fileName\"]\r\
    \n:local contents1 [/file get \$fileName contents]\r\
    \n:local usage [/ip ipsec active-peers print file=\"\$fileName\"]\r\
    \n:local contents2 [/file get \$fileName contents]\r\
    \n:set contents (\$contents . \$contents1 . \$contents2)\r\
    \n/file set \$fileName contents=\$contents\r\
    \n:delay 5s\r\
    \n:local logd [/log warning message=\"Usage Report Complete,Sending Email\
    \"]\r\
    \n:local time [/system clock get time]\r\
    \n:local dater [/system clock get date]\r\
    \n/tool e-mail send to=\"XXX\" subject=\"D\
    aily Usage report\" file=\"\$fileName\" body=\"Site Usage report  Runtime:\
    \_\$dater \$time\r\
    \n\
    \n Usage Report is attached,Old Statistics have been cleared.\
    \n\r\
    \nRegards,\r\
    \nChris@broadnetworks.co.za\"\r\
    \n:delay 5s\r\
    \n:local ecomplete [/log warning message=\"Email Sent\"]\r\
    \n:local logclear [/log warning message=\"Clearing Usage Statistics\"]\r\
    \n:local clearsession [/ip hotspot user reset-counters]\r\
    \n:delay 5s\r\
    \n:local sescomplete [/log warning message=\"Usage Statistics Cleared\"]"
add dont-require-permissions=no name=BackupAndUpdate owner=st.wiessalla \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="# Script name: BackupAndUpdate\r\
    \n#\r\
    \n#----------SCRIPT INFORMATION-------------------------------------------\
    --------\r\
    \n#\r\
    \n# Script:  Mikrotik RouterOS automatic backup & update\r\
    \n# Version: 21.09.27\r\
    \n# Created: 07/08/2018\r\
    \n# Updated: 27/09/2021\r\
    \n# Author:  Alexander Tebiev\r\
    \n# Website: https://github.com/beeyev\r\
    \n# You can contact me by e-mail at tebiev@mail.com\r\
    \n#\r\
    \n# IMPORTANT!\r\
    \n# Minimum supported RouterOS version is v6.43.7\r\
    \n#\r\
    \n#----------MODIFY THIS SECTION AS NEEDED--------------------------------\
    --------\r\
    \n## Notification e-mail\r\
    \n## (Make sure you have configurated Email settings in Tools -> Email)\r\
    \n:local emailAddress \"XXX\";\r\
    \n\r\
    \n## Script mode, possible values: backup, osupdate, osnotify.\r\
    \n# backup \t- \tOnly backup will be performed. (default value, if none pr\
    ovided)\r\
    \n#\r\
    \n# osupdate \t- \tThe Script will install a new RouterOS if it is availab\
    le.\r\
    \n#\t\t\t\tIt will also create backups before and after update process (do\
    es not matter what value is set to `forceBackup`)\r\
    \n#\t\t\t\tEmail will be sent only if a new RouterOS version is available.\
    \r\
    \n#\t\t\t\tChange parameter `forceBackup` if you need the script to create\
    \_backups every time when it runs (even when no updates).\r\
    \n#\r\
    \n# osnotify \t- \tThe script will send email notification only (without b\
    ackups) if a new RouterOS is available.\r\
    \_backups every time when it runs.\r\
    \n:local scriptMode \"backup\";\r\
    \n\r\
    \n## Additional parameter if you set `scriptMode` to `osupdate` or `osnoti\
    fy`\r\
    \n# Set `true` if you want the script to perform backup every time it's fi\
    red, whatever script mode is set.\r\
    \n:local forceBackup false;\r\
    \n\r\
    \n## Backup encryption password, no encryption if no password.\r\
    \n:local backupPassword \"\"\r\
    \n\r\
    \n## If true, passwords will be included in exported config.\r\
    \n:local sensetiveDataInConfig true;\r\
    \n\r\
    \n## Update channel. Possible values: stable, long-term, testing, developm\
    ent\r\
    \n:local updateChannel \"stable\";\r\
    \n\r\
    \n## Install only patch versions of RouterOS updates.\r\
    \n## Works only if you set scriptMode to \"osupdate\"\r\
    \n## Means that new update will be installed only if MAJOR and MINOR versi\
    on numbers remained the same as currently installed RouterOS.\r\
    \n## Example: v6.43.6 => major.minor.PATCH\r\
    \n## Script will send information if new version is greater than just patc\
    h.\r\
    \n:local installOnlyPatchUpdates\tfalse;\r\
    \n\r\
    \n##----------------------------------------------------------------------\
    --------------------##\r\
    \n#  !!!! DO NOT CHANGE ANYTHING BELOW THIS LINE, IF YOU ARE NOT SURE WHAT\
    \_YOU ARE DOING !!!!  #\r\
    \n\r\
    \n#Script messages prefix\r\
    \n:local SMP \"Bkp&Upd:\"\r\
    \n\r\
    \n:log info \"\\r\\n\$SMP script \\\"Mikrotik RouterOS automatic backup & \
    update\\\" started.\";\r\
    \n:log info \"\$SMP Script Mode: \$scriptMode, forceBackup: \$forceBackup\
    \";\r\
    \n\r\
    \n#Check proper email config\r\
    \n:if ([:len \$emailAddress] = 0 or [:len [/tool e-mail get address]] = 0 \
    or [:len [/tool e-mail get from]] = 0) do={\r\
    \n\t:log error (\"\$SMP Email configuration is not correct, please check T\
    ools -> Email. Script stopped.\");   \r\
    \n\t:error \"\$SMP bye!\";\r\
    \n}\r\
    \n\r\
    \n#Check if proper identity name is set\r\
    \nif ([:len [/system identity get name]] = 0 or [/system identity get name\
    ] = \"MikroTik\") do={\r\
    \n\t:log warning (\"\$SMP Please set identity name of your device (System \
    -> Identity), keep it short and informative.\");  \r\
    \n};\r\
    \n\r\
    \n############### vvvvvvvvv GLOBALS vvvvvvvvv ###############\r\
    \n# Function converts standard mikrotik build versions to the number.\r\
    \n# Possible arguments: paramOsVer\r\
    \n# Example:\r\
    \n# :put [\$buGlobalFuncGetOsVerNum paramOsVer=[/system routerboard get cu\
    rrent-RouterOS]];\r\
    \n# result will be: 64301, because current RouterOS version is: 6.43.1\r\
    \n:global buGlobalFuncGetOsVerNum do={\r\
    \n\t:local osVer \$paramOsVer;\r\
    \n\t:local osVerNum;\r\
    \n\t:local osVerMicroPart;\r\
    \n\t:local zro 0;\r\
    \n\t:local tmp;\r\
    \n\t\r\
    \n\t# Replace word `beta` with dot\r\
    \n\t:local isBetaPos [:tonum [:find \$osVer \"beta\" 0]];\r\
    \n\t:if (\$isBetaPos > 1) do={\r\
    \n\t\t:set osVer ([:pick \$osVer 0 \$isBetaPos] . \".\" . [:pick \$osVer (\
    \$isBetaPos + 4) [:len \$osVer]]);\r\
    \n\t}\r\
    \n\t# Replace word `rc` with dot\r\
    \n\t:local isRcPos [:tonum [:find \$osVer \"rc\" 0]];\r\
    \n\t:if (\$isRcPos > 1) do={\r\
    \n\t\t:set osVer ([:pick \$osVer 0 \$isRcPos] . \".\" . [:pick \$osVer (\$\
    isRcPos + 2) [:len \$osVer]]);\r\
    \n\t}\r\
    \n\t\r\
    \n\t:local dotPos1 [:find \$osVer \".\" 0];\r\
    \n\r\
    \n\t:if (\$dotPos1 > 0) do={ \r\
    \n\r\
    \n\t\t# AA\r\
    \n\t\t:set osVerNum  [:pick \$osVer 0 \$dotPos1];\r\
    \n\t\t\r\
    \n\t\t:local dotPos2 [:find \$osVer \".\" \$dotPos1];\r\
    \n\t\t\t\t#Taking minor version, everything after first dot\r\
    \n\t\t:if ([:len \$dotPos2] = 0) \tdo={:set tmp [:pick \$osVer (\$dotPos1+\
    1) [:len \$osVer]];}\r\
    \n\t\t#Taking minor version, everything between first and second dots\r\
    \n\t\t:if (\$dotPos2 > 0) \t\t\tdo={:set tmp [:pick \$osVer (\$dotPos1+1) \
    \$dotPos2];}\r\
    \n\t\t\r\
    \n\t\t# AA 0B\r\
    \n\t\t:if ([:len \$tmp] = 1) \tdo={:set osVerNum \"\$osVerNum\$zro\$tmp\";\
    }\r\
    \n\t\t# AA BB\r\
    \n\t\t:if ([:len \$tmp] = 2) \tdo={:set osVerNum \"\$osVerNum\$tmp\";}\r\
    \n\t\t\r\
    \n\t\t:if (\$dotPos2 > 0) do={ \r\
    \n\t\t\t:set tmp [:pick \$osVer (\$dotPos2+1) [:len \$osVer]];\r\
    \n\t\t\t# AA BB 0C\r\
    \n\t\t\t:if ([:len \$tmp] = 1) do={:set osVerNum \"\$osVerNum\$zro\$tmp\";\
    }\r\
    \n\t\t\t# AA BB CC\r\
    \n\t\t\t:if ([:len \$tmp] = 2) do={:set osVerNum \"\$osVerNum\$tmp\";}\r\
    \n\t\t} else={\r\
    \n\t\t\t# AA BB 00\r\
    \n\t\t\t:set osVerNum \"\$osVerNum\$zro\$zro\";\r\
    \n\t\t}\r\
    \n\t} else={\r\
    \n\t\t# AA 00 00\r\
    \n\t\t:set osVerNum \"\$osVer\$zro\$zro\$zro\$zro\";\r\
    \n\t}\r\
    \n\r\
    \n\t:return \$osVerNum;\r\
    \n}\r\
    \n\r\
    \n# Function creates backups (system and config) and returns array with na\
    mes\r\
    \n# Possible arguments: \r\
    \n#\t`backupName` \t\t\t| string\t| backup file name, without extension!\r\
    \n#\t`backupPassword`\t\t| string \t|\r\
    \n#\t`sensetiveDataInConfig`\t| boolean \t|\r\
    \n# Example:\r\
    \n# :put [\$buGlobalFuncCreateBackups name=\"daily-backup\"];\r\
    \n:global buGlobalFuncCreateBackups do={\r\
    \n\t:log info (\"\$SMP Global function \\\"buGlobalFuncCreateBackups\\\" w\
    as fired.\");  \r\
    \n\t\r\
    \n\t:local backupFileSys \"\$backupName.backup\";\r\
    \n\t:local backupFileConfig \"\$backupName.rsc\";\r\
    \n\t:local backupNames {\$backupFileSys;\$backupFileConfig};\r\
    \n\r\
    \n\t## Make system backup\r\
    \n\t:if ([:len \$backupPassword] = 0) do={\r\
    \n\t\t/system backup save dont-encrypt=yes name=\$backupName;\r\
    \n\t} else={\r\
    \n\t\t/system backup save password=\$backupPassword name=\$backupName;\r\
    \n\t}\r\
    \n\t:log info (\"\$SMP System backup created. \$backupFileSys\");   \r\
    \n\r\
    \n\t## Export config file\r\
    \n\t:if (\$sensetiveDataInConfig = true) do={\r\
    \n\t\t/export compact file=\$backupName;\r\
    \n\t} else={\r\
    \n\t\t/export compact hide-sensitive file=\$backupName;\r\
    \n\t}\r\
    \n\t:log info (\"\$SMP Config file was exported. \$backupFileConfig\");   \
    \r\
    \n\r\
    \n\t#Delay after creating backups\r\
    \n\t:delay 5s;\t\r\
    \n\t:return \$backupNames;\r\
    \n}\r\
    \n\r\
    \n:global buGlobalVarUpdateStep;\r\
    \n############### ^^^^^^^^^ GLOBALS ^^^^^^^^^ ###############\r\
    \n\r\
    \n#Current date time in format: 2020jan15-221324 \r\
    \n:local dateTime ([:pick [/system clock get date] 7 11] . [:pick [/system\
    \_clock get date] 0 3] . [:pick [/system clock get date] 4 6] . \"-\" . [:\
    pick [/system clock get time] 0 2] . [:pick [/system clock get time] 3 5] \
    . [:pick [/system clock get time] 6 8]);\r\
    \n\r\
    \n:local deviceOsVerInst \t\t\t[/system package update get installed-versi\
    on];\r\
    \n:local deviceOsVerInstNum \t\t[\$buGlobalFuncGetOsVerNum paramOsVer=\$de\
    viceOsVerInst];\r\
    \n:local deviceOsVerAvail \t\t\"\";\r\
    \n:local deviceOsVerAvailNum \t\t0;\r\
    \n:local deviceRbModel\t\t\t[/system routerboard get model];\r\
    \n:local deviceRbSerialNumber \t[/system routerboard get serial-number];\r\
    \n:local deviceRbCurrentFw \t\t[/system routerboard get current-firmware];\
    \r\
    \n:local deviceRbUpgradeFw \t\t[/system routerboard get upgrade-firmware];\
    \r\
    \n:local deviceIdentityName \t\t[/system identity get name];\r\
    \n:local deviceIdentityNameShort \t[:pick \$deviceIdentityName 0 18]\r\
    \n:local deviceUpdateChannel \t\t[/system package update get channel];\r\
    \n\r\
    \n:local isOsUpdateAvailable \tfalse;\r\
    \n:local isOsNeedsToBeUpdated\tfalse;\r\
    \n\r\
    \n:local isSendEmailRequired\ttrue;\r\
    \n\r\
    \n:local mailSubject   \t\t\"\$SMP Device - \$deviceIdentityNameShort.\";\
    \r\
    \n:local mailBody \t \t\t\"\";\r\
    \n\r\
    \n:local mailBodyDeviceInfo\t\"\\r\\n\\r\\nDevice information: \\r\\nIdent\
    ity: \$deviceIdentityName \\r\\nModel: \$deviceRbModel \\r\\nSerial number\
    : \$deviceRbSerialNumber \\r\\nCurrent RouterOS: \$deviceOsVerInst (\$[/sy\
    stem package update get channel]) \$[/system resource get build-time] \\r\
    \\nCurrent routerboard FW: \$deviceRbCurrentFw \\r\\nDevice uptime: \$[/sy\
    stem resource get uptime]\";\r\
    \n:local mailBodyCopyright \t\"\\r\\n\\r\\nMikrotik RouterOS automatic bac\
    kup & update \\r\\nhttps://github.com/beeyev/Mikrotik-RouterOS-automatic-b\
    ackup-and-update\";\r\
    \n:local changelogUrl\t\t\t(\"Check RouterOS changelog: https://mikrotik.c\
    om/download/changelogs/\" . \$updateChannel . \"-release-tree\");\r\
    \n\r\
    \n:local backupName \t\t\t\"\$deviceIdentityName.\$deviceRbModel.\$deviceR\
    bSerialNumber.v\$deviceOsVerInst.\$deviceUpdateChannel.\$dateTime\";\r\
    \n:local backupNameBeforeUpd\t\"backup_before_update_\$backupName\";\r\
    \n:local backupNameAfterUpd\t\"backup_after_update_\$backupName\";\r\
    \n\r\
    \n:local backupNameFinal\t\t\$backupName;\r\
    \n:local mailAttachments\t\t[:toarray \"\"];\r\
    \n\r\
    \n:local updateStep \$buGlobalVarUpdateStep;\r\
    \n:do {/system script environment remove buGlobalVarUpdateStep;} on-error=\
    {}\r\
    \n:if ([:len \$updateStep] = 0) do={\r\
    \n\t:set updateStep 1;\r\
    \n}\r\
    \n\r\
    \n\r\
    \n## \tSTEP ONE: Creating backups, checking for new RouterOs version and s\
    ending email with backups,\r\
    \n## \tsteps 2 and 3 are fired only if script is set to automatically upda\
    te device and if new RouterOs is available.\r\
    \n:if (\$updateStep = 1) do={\r\
    \n\t:log info (\"\$SMP Performing the first step.\");   \r\
    \n\r\
    \n\t# Checking for new RouterOS version\r\
    \n\tif (\$scriptMode = \"osupdate\" or \$scriptMode = \"osnotify\") do={\r\
    \n\t\tlog info (\"\$SMP Checking for new RouterOS version. Current version\
    \_is: \$deviceOsVerInst\");\r\
    \n\t\t/system package update set channel=\$updateChannel;\r\
    \n\t\t/system package update check-for-updates;\r\
    \n\t\t:delay 5s;\r\
    \n\t\t:set deviceOsVerAvail [/system package update get latest-version];\r\
    \n\r\
    \n\t\t# If there is a problem getting information about available RouterOS\
    \_from server\r\
    \n\t\t:if ([:len \$deviceOsVerAvail] = 0) do={\r\
    \n\t\t\t:log warning (\"\$SMP There is a problem getting information about\
    \_new RouterOS from server.\");\r\
    \n\t\t\t:set mailSubject\t(\$mailSubject . \" Error: No data about new Rou\
    terOS!\")\r\
    \n\t\t\t:set mailBody \t\t(\$mailBody . \"Error occured! \\r\\nMikrotik co\
    uldn't get any information about new RouterOS from server! \\r\\nWatch add\
    itional information in device logs.\")\r\
    \n\t\t} else={\r\
    \n\t\t\t#Get numeric version of OS\r\
    \n\t\t\t:set deviceOsVerAvailNum [\$buGlobalFuncGetOsVerNum paramOsVer=\$d\
    eviceOsVerAvail];\r\
    \n\r\
    \n\t\t\t# Checking if OS on server is greater than installed one.\r\
    \n\t\t\t:if (\$deviceOsVerAvailNum > \$deviceOsVerInstNum) do={\r\
    \n\t\t\t\t:set isOsUpdateAvailable true;\r\
    \n\t\t\t\t:log info (\"\$SMP New RouterOS is available! \$deviceOsVerAvail\
    \");\r\
    \n\t\t\t} else={\r\
    \n\t\t\t\t:set isSendEmailRequired false;\r\
    \n\t\t\t\t:log info (\"\$SMP System is already up to date.\");\r\
    \n\t\t\t\t:set mailSubject (\$mailSubject . \" No new OS updates.\");\r\
    \n\t\t\t\t:set mailBody \t (\$mailBody . \"Your system is up to date.\");\
    \r\
    \n\t\t\t}\r\
    \n\t\t};\r\
    \n\t} else={\r\
    \n\t\t:set scriptMode \"backup\";\r\
    \n\t};\r\
    \n\r\
    \n\tif (\$forceBackup = true) do={\r\
    \n\t\t# In this case the script will always send email, because it has to \
    create backups\r\
    \n\t\t:set isSendEmailRequired true;\r\
    \n\t}\r\
    \n\r\
    \n\t# if new OS version is available to install\r\
    \n\tif (\$isOsUpdateAvailable = true and \$isSendEmailRequired = true) do=\
    {\r\
    \n\t\t# If we only need to notify about new available version\r\
    \n\t\tif (\$scriptMode = \"osnotify\") do={\r\
    \n\t\t\t:set mailSubject \t(\$mailSubject . \" New RouterOS is available! \
    v.\$deviceOsVerAvail.\")\r\
    \n\t\t\t:set mailBody \t\t(\$mailBody . \"New RouterOS version is availabl\
    e to install: v.\$deviceOsVerAvail (\$updateChannel) \\r\\n\$changelogUrl\
    \")\r\
    \n\t\t}\r\
    \n\r\
    \n\t\t# if we need to initiate RouterOs update process\r\
    \n\t\tif (\$scriptMode = \"osupdate\") do={\r\
    \n\t\t\t:set isOsNeedsToBeUpdated true;\r\
    \n\t\t\t# if we need to install only patch updates\r\
    \n\t\t\t:if (\$installOnlyPatchUpdates = true) do={\r\
    \n\t\t\t\t#Check if Major and Minor builds are the same.\r\
    \n\t\t\t\t:if ([:pick \$deviceOsVerInstNum 0 ([:len \$deviceOsVerInstNum]-\
    2)] = [:pick \$deviceOsVerAvailNum 0 ([:len \$deviceOsVerAvailNum]-2)]) do\
    ={\r\
    \n\t\t\t\t\t:log info (\"\$SMP New patch version of RouterOS firmware is a\
    vailable.\");   \r\
    \n\t\t\t\t} else={\r\
    \n\t\t\t\t\t:log info (\"\$SMP New major or minor version of RouterOS firm\
    ware is available. You need to update it manually.\");\r\
    \n\t\t\t\t\t:set mailSubject \t(\$mailSubject . \" New RouterOS: v.\$devic\
    eOsVerAvail needs to be installed manually.\");\r\
    \n\t\t\t\t\t:set mailBody \t\t(\$mailBody . \"New major or minor RouterOS \
    version is available to install: v.\$deviceOsVerAvail (\$updateChannel). \
    \\r\\nYou chose to automatically install only patch updates, so this major\
    \_update you need to install manually. \\r\\n\$changelogUrl\");\r\
    \n\t\t\t\t\t:set isOsNeedsToBeUpdated false;\r\
    \n\t\t\t\t}\r\
    \n\t\t\t}\r\
    \n\r\
    \n\t\t\t#Check again, because this variable could be changed during checki\
    ng for installing only patch updats\r\
    \n\t\t\tif (\$isOsNeedsToBeUpdated = true) do={\r\
    \n\t\t\t\t:log info (\"\$SMP New RouterOS is going to be installed! v.\$de\
    viceOsVerInst -> v.\$deviceOsVerAvail\");\r\
    \n\t\t\t\t:set mailSubject\t(\$mailSubject . \" New RouterOS is going to b\
    e installed! v.\$deviceOsVerInst -> v.\$deviceOsVerAvail.\");\r\
    \n\t\t\t\t:set mailBody \t\t(\$mailBody . \"Your Mikrotik will be updated \
    to the new RouterOS version from v.\$deviceOsVerInst to v.\$deviceOsVerAva\
    il (Update channel: \$updateChannel) \\r\\nFinal report with the detailed \
    information will be sent when update process is completed. \\r\\nIf you ha\
    ve not received second email in the next 5 minutes, then probably somethin\
    g went wrong. (Check your device logs)\");\r\
    \n\t\t\t\t#!! There is more code connected to this part and first step at \
    the end of the script.\r\
    \n\t\t\t}\r\
    \n\t\t\r\
    \n\t\t}\r\
    \n\t}\r\
    \n\r\
    \n\t## Checking If the script needs to create a backup\r\
    \n\t:log info (\"\$SMP Checking If the script needs to create a backup.\")\
    ;\r\
    \n\tif (\$forceBackup = true or \$scriptMode = \"backup\" or \$isOsNeedsTo\
    \n\t\t:log info (\"\$SMP Creating system backups.\");\r\
    \n\t\tif (\$isOsNeedsToBeUpdated = true) do={\r\
    \n\t\t\t:set backupNameFinal \$backupNameBeforeUpd;\r\
    \n\t\t};\r\
    \n\t\tif (\$scriptMode != \"backup\") do={\r\
    \n\t\t\t:set mailBody (\$mailBody . \"\\r\\n\\r\\n\");\r\
    \n\t\t};\r\
    \n\r\
    \n\t\t:set mailSubject\t(\$mailSubject . \" Backup was created.\");\r\
    \n\t\t:set mailBody\t\t(\$mailBody . \"System backups were created and att\
    ached to this email.\");\r\
    \n\r\
    \n\t\t:set mailAttachments [\$buGlobalFuncCreateBackups backupName=\$backu\
    pNameFinal backupPassword=\$backupPassword sensetiveDataInConfig=\$senseti\
    veDataInConfig];\r\
    \n\t} else={\r\
    \n\t\t:log info (\"\$SMP There is no need to create a backup.\");\r\
    \n\t}\r\
    \n\r\
    \n\t# Combine fisrst step email\r\
    \n\t:set mailBody (\$mailBody . \$mailBodyDeviceInfo . \$mailBodyCopyright\
    );\r\
    \n}\r\
    \n\r\
    \n## \tSTEP TWO: (after first reboot) routerboard firmware upgrade\r\
    \n:if (\$updateStep = 2) do={\r\
    \n\t:log info (\"\$SMP Performing the second step.\");   \r\
    \n\t## RouterOS is the latest, let's check for upgraded routerboard firmwa\
    re\r\
    \n\tif (\$deviceRbCurrentFw != \$deviceRbUpgradeFw) do={\r\
    \n\t\t:set isSendEmailRequired false;\r\
    \n\t\t:delay 10s;\r\
    \n\t\t:log info \"\$SMP Upgrading routerboard firmware from v.\$deviceRbCu\
    rrentFw to v.\$deviceRbUpgradeFw\";\r\
    \n\t\t## Start the upgrading process\r\
    \n\t\t/system routerboard upgrade;\r\
    \n\t\t## Wait until the upgrade is completed\r\
    \n\t\t:delay 5s;\r\
    \n\t\t:log info \"\$SMP routerboard upgrade process was completed, going t\
    o reboot in a moment!\";\r\
    \n\t\t## Set scheduled task to send final report on the next boot, task wi\
    ll be deleted when is is done. (That is why you should keep original scrip\
    t name)\r\
    \n\t\t/system schedule add name=BKPUPD-FINAL-REPORT-ON-NEXT-BOOT on-event=\
    \":delay 5s; /system scheduler remove BKPUPD-FINAL-REPORT-ON-NEXT-BOOT; :g\
    lobal buGlobalVarUpdateStep 3; :delay 10s; /system script run BackupAndUpd\
    ate;\" start-time=startup interval=0;\r\
    \n\t\t## Reboot system to boot with new firmware\r\
    \n\t\t/system reboot;\r\
    \n\t} else={\r\
    \n\t\t:log info \"\$SMP It appers that your routerboard is already up to d\
    ate, skipping this step.\";\r\
    \n\t\t:set updateStep 3;\r\
    \n\t};\r\
    \n}\r\
    \n\r\
    \n## \tSTEP THREE: Last step (after second reboot) sending final report\r\
    \n:if (\$updateStep = 3) do={\r\
    \n\t:log info (\"\$SMP Performing the third step.\");   \r\
    \n\t:log info \"Bkp&Upd: RouterOS and routerboard upgrade process was comp\
    leted. New RouterOS version: v.\$deviceOsVerInst, routerboard firmware: v.\
    \$deviceRbCurrentFw.\";\r\
    \n\t## Small delay in case mikrotik needs some time to initialize connecti\
    ons\r\
    \n\t:log info \"\$SMP The final email with report and backups of upgraded \
    system will be sent in a minute.\";\r\
    \n\t:delay 1m;\r\
    \n\t:set mailSubject\t(\$mailSubject . \" RouterOS Upgrade is completed, n\
    ew version: v.\$deviceOsVerInst!\");\r\
    \n\t:set mailBody \t  \t\"RouterOS and routerboard upgrade process was com\
    pleted. \\r\\nNew RouterOS version: v.\$deviceOsVerInst, routerboard firmw\
    are: v.\$deviceRbCurrentFw. \\r\\n\$changelogUrl \\r\\n\\r\\nBackups of th\
    e upgraded system are in the attachment of this email.  \$mailBodyDeviceIn\
    fo \$mailBodyCopyright\";\r\
    \n\t:set mailAttachments [\$buGlobalFuncCreateBackups backupName=\$backupN\
    ameAfterUpd backupPassword=\$backupPassword sensetiveDataInConfig=\$senset\
    iveDataInConfig];\r\
    \n}\r\
    \n\r\
    \n# Remove functions from global environment to keep it fresh and clean.\r\
    \n:do {/system script environment remove buGlobalFuncGetOsVerNum;} on-erro\
    r={}\r\
    \n:do {/system script environment remove buGlobalFuncCreateBackups;} on-er\
    ror={}\r\
    \n\r\
    \n##\r\
    \n## SENDING EMAIL\r\
    \n##\r\
    \n# Trying to send email with backups in attachment.\r\
    \n\r\
    \n:if (\$isSendEmailRequired = true) do={\r\
    \n\t:log info \"\$SMP Sending email message, it will take around half a mi\
    nute...\";\r\
    \n\t:do {/tool e-mail send to=\$emailAddress subject=\$mailSubject body=\$\
    mailBody file=\$mailAttachments;} on-error={\r\
    \n\t\t:delay 5s;\r\
    \n\t\t:log error \"\$SMP could not send email message (\$[/tool e-mail get\
    \_last-status]). Going to try it again in a while.\"\r\
    \n\r\
    \n\t\t:delay 5m;\r\
    \n\r\
    \n\t\t:do {/tool e-mail send to=\$emailAddress subject=\$mailSubject body=\
    \$mailBody file=\$mailAttachments;} on-error={\r\
    \n\t\t\t:delay 5s;\r\
    \n\t\t\t:log error \"\$SMP could not send email message (\$[/tool e-mail g\
    et last-status]) for the second time.\"\r\
    \n\r\
    \n\t\t\t\t:set isOsNeedsToBeUpdated false;\r\
    \n\t\t\t\t:log warning \"\$SMP script is not going to initialise update pr\
    ocess due to inability to send backups to email.\"\r\
    \n\t\t\t}\r\
    \n\t\t}\r\
    \n\t}\r\
    \n\r\
    \n\t:delay 30s;\r\
    \n\t\r\
    \n\t:if ([:len \$mailAttachments] > 0 and [/tool e-mail get last-status] =\
    \_\"succeeded\") do={\r\
    \n\t\t:log info \"\$SMP File system cleanup.\"\r\
    \n\t\t/file remove \$mailAttachments; \r\
    \n\t\t:delay 2s;\r\
    \n\t}\r\
    \n\t\r\
    \n}\r\
    \n\r\
    \n\r\
    \n# Fire RouterOs update process\r\
    \nif (\$isOsNeedsToBeUpdated = true) do={\r\
    \n\r\
    \n\t## Set scheduled task to upgrade routerboard firmware on the next boot\
    , task will be deleted when upgrade is done. (That is why you should keep \
    original script name)\r\
    \n\t/system schedule add name=BKPUPD-UPGRADE-ON-NEXT-BOOT on-event=\":dela\
    y 5s; /system scheduler remove BKPUPD-UPGRADE-ON-NEXT-BOOT; :global buGlob\
    alVarUpdateStep 2; :delay 10s; /system script run BackupAndUpdate;\" start\
    \n   \r\
    \n   :log info \"\$SMP everything is ready to install new RouterOS, going \
    to reboot in a moment!\"\r\
    \n\t## command is reincarnation of the \"upgrade\" command - doing exactly\
    \_the same but under a different name\r\
    \n\t/system package update install;\r\
    \n}\r\
    \n\r\
    \n:log info \"\$SMP script \\\"Mikrotik RouterOS automatic backup & update\
    \\\" completed it's job.\\r\\n\";\r\
    \n"
/tool bandwidth-server
set authenticate=no enabled=no
/tool e-mail
set address=smtp.ionos.de from=XXX start-tls=yes \
    user=XXX
/tool mac-server
set allowed-interface-list=Management_Interfaces
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
wAP ac:
# dec/12/2021 15:13:10 by RouterOS 6.49.2
# software id = XXX
# model = RBwAPG-5HacT2HnD
add comment=defconf name=bridge
/interface wireless
# managed by CAPsMAN
# channel: 2442/20-eC/gn(18dBm), SSID: XX, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=germany distance=indoors frequency=auto installation=outdoor \
    mode=ap-bridge ssid=MikroTik-1BB8A8 station-roaming=enabled \
    wireless-protocol=802.11
# channel: 5660/20-Ce/ac/DP(25dBm), SSID: XXXXX, CAPsMAN forwarding
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=germany distance=indoors frequency=auto \
    installation=outdoor mode=ap-bridge ssid=MikroTik-1BB8A7 station-roaming=\
    enabled wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/user group
add bridge=bridge interface=ether1
set discover-interface-list=!none
/interface wireless cap
set caps-man-addresses=172.16.0.1 caps-man-certificate-common-names=\
    "CapsMan Zertifikat" certificate="cert_export_wAP ac Marktplatz 1.crt_0" \
    enabled=yes interfaces=wlan1,wlan2 lock-to-caps-man=yes
add address=172.16.0.10/24 comment=defconf interface=bridge network=\
    172.16.0.0
set servers=172.16.0.1
/ip dns static
add distance=1 gateway=172.16.0.1
/ip service
set ssh port=2200
/system clock
/system identity
set name="wAP ac Marktplatz 1"
/system logging
add topics=debug
/system ntp client
set enabled=yes primary-ntp=192.53.103.108 secondary-ntp=192.53.103.108
set channel=upgrade
/system scheduler
    start-date=dec/10/2021 start-time=02:00:00
/system script
    \n#\r\
    --------\r\
    \n#\r\
    \n#\r\
    \n# IMPORTANT!\r\
    \n#\r\
    --------\r\
    \n\r\
    ovided)\r\
    \n#\r\
    le.\r\
    \r\
    \n#\r\
    \n\r\
    fy`\r\
    \n\r\
    \n\r\
    \n\r\
    ent\r\
    \n\r\
    h.\r\
    \n\r\
    \n\r\
    \n\r\
    \";\r\
    \n\r\
    \n}\r\
    \n\r\
    \n};\r\
    \n\r\
    \n# Example:\r\
    \n\t:local tmp;\r\
    \n\t\r\
    \n\t}\r\
    \n\t}\r\
    \n\t\r\
    \n\r\
    \n\r\
    \n\t\t# AA\r\
    \n\t\t\r\
    \$dotPos2];}\r\
    \n\t\t\r\
    \n\t\t# AA 0B\r\
    }\r\
    \n\t\t# AA BB\r\
    \n\t\t\r\
    }\r\
    \n\t\t} else={\r\
    \n\t\t}\r\
    \n\t} else={\r\
    \n\t\t# AA 00 00\r\
    \n\t}\r\
    \n\r\
    \n}\r\
    \n\r\
    mes\r\
    \n# Example:\r\
    as fired.\");  \r\
    \n\t\r\
    \n\r\
    \n\t} else={\r\
    \n\t}\r\
    \n\r\
    \n\t} else={\r\
    \n\t}\r\
    \r\
    \n\r\
    \n\t:delay 5s;\t\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    on];\r\
    viceOsVerInst];\r\
    \r\
    \r\
    \n\r\
    \n\r\
    \n\r\
    \r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    {}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n\t\t:delay 5s;\r\
    \n\r\
    \_from server\r\
    terOS!\")\r\
    \n\t\t} else={\r\
    \n\r\
    \");\r\
    \n\t\t\t} else={\r\
    \r\
    \n\t\t\t}\r\
    \n\t\t};\r\
    \n\t} else={\r\
    \n\t};\r\
    \n\r\
    create backups\r\
    \n\t}\r\
    \n\r\
    {\r\
    \")\r\
    \n\t\t}\r\
    \n\r\
    ={\r\
    vailable.\");   \r\
    \n\t\t\t\t}\r\
    \n\t\t\t}\r\
    \n\r\
    \n\t\t\t}\r\
    \n\t\t\r\
    \n\t\t}\r\
    \n\t}\r\
    \n\r\
    ;\r\
    \n\t\t};\r\
    \n\t\t};\r\
    \n\r\
    \n\r\
    veDataInConfig];\r\
    \n\t} else={\r\
    \n\t}\r\
    \n\r\
    );\r\
    \n}\r\
    \n\r\
    re\r\
    \n\t\t:delay 5s;\r\
    t name)\r\
    \n\t} else={\r\
    \n\t};\r\
    \n}\r\
    \n\r\
    ons\r\
    \n\t:delay 1m;\r\
    \n}\r\
    \n\r\
    r={}\r\
    ror={}\r\
    \n\r\
    \n##\r\
    \n##\r\
    \n\r\
    nute...\";\r\
    \n\t\t:delay 5s;\r\
    \n\r\
    \n\t\t:delay 5m;\r\
    \n\r\
    \n\r\
    \n\t\t\t}\r\
    \n\t\t}\r\
    \n\t}\r\
    \n\r\
    \n\t:delay 30s;\r\
    \n\t\r\
    \n\t\t:delay 2s;\r\
    \n\t}\r\
    \n\t\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n   \r\
    \n}\r\
    \n\r\
    \n"
/tool e-mail
set address=smtp.ionos.de from=XX start-tls=yes \
    user=XX
Please post config under 7.1 as this is where the issue occurs.
I have a lab setup with mAP as capsman and maplite as caps, both 7.1 and functioning, so it does work.
Here Config of wapAC which doesn’t work.
I don’t think that there is a difference (inhouse unit still 6.49.2 and it doesn’t connect - therefore I didn’t upgrade and post an export of RB4011) - i’m only dialed in via VPN and don’t want to do a upgrade/downgrade session because it can broke both devices and I have to travel there to repair it. I just upgraded and downgraded wapAC for you to demonstrate configfile.
# dec/12/2021 15:40:12 by RouterOS 7.1
# software id = XXX
/interface wireless
/interface lte apn
set [ find default=yes ] ip-type=ipv4
/user group
    sword,web,sniff,sensitive,api,romon,dude,tikapp,rest-api"
add bridge=bridge ingress-filtering=no interface=ether1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
    172.16.0.0
/ip dns static
add disabled=no dst-address=0.0.0.0/0 gateway=172.16.0.1
/ip service
set ssh port=2200
/system clock
/system identity
/system logging
add topics=debug
/system ntp client
set enabled=yes
/system ntp client servers
add address=192.53.103.108
/system scheduler
/system script
    \n#\r\
    --------\r\
    \n#\r\
    \n#\r\
    \n# IMPORTANT!\r\
    \n#\r\
    --------\r\
    \n\r\
    ovided)\r\
    \n#\r\
    le.\r\
    \r\
    \n#\r\
    \n\r\
    fy`\r\
    \n\r\
    \n\r\
    \n\r\
    ent\r\
    \n\r\
    h.\r\
    \n\r\
    \n\r\
    \n\r\
    \";\r\
    \n\r\
    \n}\r\
    \n\r\
    \n};\r\
    \n\r\
    \n# Example:\r\
    \n\t:local tmp;\r\
    \n\t\r\
    \n\t}\r\
    \n\t}\r\
    \n\t\r\
    \n\r\
    \n\r\
    \n\t\t# AA\r\
    \n\t\t\r\
    \$dotPos2];}\r\
    \n\t\t\r\
    \n\t\t# AA 0B\r\
    }\r\
    \n\t\t# AA BB\r\
    \n\t\t\r\
    }\r\
    \n\t\t} else={\r\
    \n\t\t}\r\
    \n\t} else={\r\
    \n\t\t# AA 00 00\r\
    \n\t}\r\
    \n\r\
    \n}\r\
    \n\r\
    mes\r\
    \n# Example:\r\
    as fired.\");  \r\
    \n\t\r\
    \n\r\
    \n\t} else={\r\
    \n\t}\r\
    \n\r\
    \n\t} else={\r\
    \n\t}\r\
    \r\
    \n\r\
    \n\t:delay 5s;\t\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    on];\r\
    viceOsVerInst];\r\
    \r\
    \r\
    \n\r\
    \n\r\
    \n\r\
    \r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    {}\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n\t\t:delay 5s;\r\
    \n\r\
    \_from server\r\
    terOS!\")\r\
    \n\t\t} else={\r\
    \n\r\
    \");\r\
    \n\t\t\t} else={\r\
    \r\
    \n\t\t\t}\r\
    \n\t\t};\r\
    \n\t} else={\r\
    \n\t};\r\
    \n\r\
    create backups\r\
    \n\t}\r\
    \n\r\
    {\r\
    \")\r\
    \n\t\t}\r\
    \n\r\
    ={\r\
    vailable.\");   \r\
    \n\t\t\t\t}\r\
    \n\t\t\t}\r\
    \n\r\
    \n\t\t\t}\r\
    \n\t\t\r\
    \n\t\t}\r\
    \n\t}\r\
    \n\r\
    ;\r\
    \n\t\t};\r\
    \n\t\t};\r\
    \n\r\
    \n\r\
    veDataInConfig];\r\
    \n\t} else={\r\
    \n\t}\r\
    \n\r\
    );\r\
    \n}\r\
    \n\r\
    re\r\
    \n\t\t:delay 5s;\r\
    t name)\r\
    \n\t} else={\r\
    \n\t};\r\
    \n}\r\
    \n\r\
    ons\r\
    \n\t:delay 1m;\r\
    \n}\r\
    \n\r\
    r={}\r\
    ror={}\r\
    \n\r\
    \n##\r\
    \n##\r\
    \n\r\
    nute...\";\r\
    \n\t\t:delay 5s;\r\
    \n\r\
    \n\t\t:delay 5m;\r\
    \n\r\
    \n\r\
    \n\t\t\t}\r\
    \n\t\t}\r\
    \n\t}\r\
    \n\r\
    \n\t:delay 30s;\r\
    \n\t\r\
    \n\t\t:delay 2s;\r\
    \n\t}\r\
    \n\t\r\
    \n}\r\
    \n\r\
    \n\r\
    \n\r\
    \n   \r\
    \n}\r\
    \n\r\
    \n"
/tool e-mail
set address=smtp.ionos.de from=XXX tls=starttls \
    user=XXX
I also didn’t use netinstall to downgrade - I only uploaded older firmware and hit “downgrade” button in packages therefor I think the configurations are identical,.
Config of CAPSMAN device please …
THATs the one handling the setup of the caps. If something is wrong, it will most likely be there.
wAP doesn’t work (ROS 7.1) independendly from ROS (7.1 or 6.49.2) on CAPSMAN:
wAP 6.49.2 ↔ RB4011 6.49.2 works perfectly
wap 7.1 ↔ RB4011 7.1 timeout of wap
wap 7.1 ↔ RB4011 6.49.2 timeout of wap
wap 6.49.2 ↔ RB4011 7.1 CAP works but looses internet connectivity after some seconds/minutes
Strange that it’s that particular combo causing this problem.
Then there is no other option right now then staying on 6.49.2 for that setup.
Already send a problem description to support@mikrotik to flag the problem ?
… no, I hope they’re reading here also or should I sent it directly to them?
It’s best to do so. They read a lot of stuff but not everything.
As long as you skipped the WAVE 2 packages…
I put 3 cAP XL ACs on one hAP AC2 on 7.1 Thursday. Nothing out of the ordinary. Been working for 4 days now
I didn’t change neither configuration nor packages.
Just click ->System->packages->Check Updates->upgrade to ROS 7.1
To downgrade ->Tools->Fetch->“Downloadlink ROS 6.49.2 from Mikrotik Homepage” ;;; System->Packages->Downgrade
No config change, no Wave2
I can repeat it as many times as I want - everytime the same problems.
(And yes - at home I have a virtualized CHR with CAPSMAN and 2 wAP ac as well as one hap ac as CAPS and upgrade worked like a charm - so I don’t know what’s the difference.)
Did you make an changes to the firewall?
How about making a blank accept rule for anything in the right IP scope?
I also disabled all firewall rules (except hotspot rules which were created automatically) on RB4011. It doesn’t solved the problem.
You could also see that firewall rules aren’t the problem because FW-Upgrade at wAP ac to ROS 7.1 triggers the problem. wAP ac has an empty firewall section.
Had another install today…
hAP AC2 + 3 cAP AC. Worked just like every other caps-man job I ever did.
Here I has same problem, in both V7.1.
CAPSMAN : RB4011iGS+5HacQ2HnD-IN
CAPS : 2 x wlan in RB4011iGS+5HacQ2HnD-IN
2 x wlan in cAP XL ac
CAPs on RB4011iGS+5HacQ2HnD-IN works fine.
CAPs on cAP XL ac can’t connect CAPSMAN.
But they were fine in V6.49.2.
Sorry, that it is wrong information.
In my case, it doesn’t work both V6.49.2 and V7.1.
@gotsprings: thanks for the reply but on my end the error still persists
Lorsk…
I have to admit… Anytime I read that firewall in someone’s config… I stop reading.
Try placing an input rule at the every top of your firewall chain, that accepts your caps. Then log into a cap an make sure it reaches the caps-man.
Try create enable and enable local forwarding.
See if that connects and takes a config.
Check if the CAP is using certificates… I had an issue there…
… yes, it should use certificates. What was your problem with certificates?
In debug-log on CAP I can only read about a timeout (no certifiacte entries in debug-log).
I’ll also try to place an allow input rule - but I think this isn’t related to my problem (why should the firewall have another behavior in 7.1 vs. 6.49.2)
Can you test without certificates ?
My setup doesn’t have them.
I don’t have REQUIRE set for Certificates.
