Problem with RouterBOARD 523
Hello!
I Have a problem with my RouterBOARD 523.
when i am turn on the router,i have receive a mesage NAND ERROR: waitForReady() timeout (1000 ms)
RouterBoard 532
CPU frequency: 330 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
How can i resolve them?
and what is the real problem?
I’am installed a new bios,Reinstalled MikroTik …
Which are MikroTik RouterOS and RouterBOARD firmware versions installed on the RouterBOARD?
Rotrer BOOT 2.18
And No OS installed currently i cannot install os…
I’am desoldered the NAND Chp :slight_smile:
And try to change it :slight_smile:
Booter 2.18
Currently No OS Installed
What do you see, when run Etherboot on board and run Netinstall?
Setting up ELF Image… OK
jumping to kernel code
after 15 minutes…
displays this :
Welcome to the MikroTik Remote instalation
… CTRL+ALT+Delete to abort
Software key = xxxxxxxxxxxx :slight_smile:
and stops on this message…
router cannot be displayed in list on netinstall…
Most likely NAND is damaged and there is no software fix for it.
… If i Am insert a CF Card and install to it??? Router will be work ??
or the router is dead??
RouterOS can’t boot from CF card on RB532, it’s only a secondary disk.
